I’m seeing the output below when attempting to execute ./configure whereby to install the rkdeveloptool on my laptop running Linux Mint 20.1:
checking for a BSD-compatible install… /usr/bin/install -c
checking whether build environment is sane… yes
checking for a thread-safe mkdir -p… /bin/mkdir -p
checking for gawk… gawk
checking whether make sets $(MAKE)… yes
checking whether make supports nested variables… yes
checking whether make supports the include directive… yes (GNU style)
checking for gcc… gcc
checking whether the C compiler works… yes
checking for C compiler default output file name… a.out
checking for suffix of executables…
checking whether we are cross compiling… no
checking for suffix of object files… o
checking whether we are using the GNU C compiler… yes
checking whether gcc accepts -g… yes
checking for gcc option to accept ISO C89… none needed
checking whether gcc understands -c and -o together… yes
checking dependency style of gcc… gcc3
checking how to run the C preprocessor… gcc -E
checking for g++… no
checking for c++… no
checking for gpp… no
checking for aCC… no
checking for CC… no
checking for cxx… no
checking for cc++… no
checking for cl.exe… no
checking for FCC… no
checking for KCC… no
checking for RCC… no
checking for xlC_r… no
checking for xlC… no
checking whether we are using the GNU C++ compiler… no
checking whether g++ accepts -g… no
checking dependency style of g++… none
checking how to run the C++ preprocessor… /lib/cpp
configure: error: in /home/username/rkdeveloptool': configure: error: C++ preprocessor "/lib/cpp" fails sanity check See config.log’ for more details
