First of all congratulations to the Radxa team for this awesome little board.
I have a 4GB/32GB Zero with the Radxa Debian installed.
I’m using it as a daily driver for programming and browsing and it works perfectly… A less than 5 watt fully working PC! ![]()
I see in the emmc docs that it can reach a max read speed of 200MB/s. Testing the read speed with hdparm only reaches 131MB/s.
The Foresee 32GB emmc supports HS400 but it seems that it is not enabled by Debian.
Here is what I found in dmesg:
rock@radxa-zero:~$ dmesg | grep mmc
[ 3.141608] meson-gx-mmc ffe05000.sd: Got CD GPIO
[ 3.461728] meson-gx-mmc ffe03000.sd: allocated mmc-pwrseq
[ 3.476567] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
[ 3.542928] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.545073] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.551489] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.558599] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.565868] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 3.639199] mmc2: new ultra high speed SDR50 SDIO card at address 0001
[ 3.642926] mmc0: new **HS200 MMC** card at address 0001
[ 3.652493] mmcblk0: mmc0:0001 SLD32G 28.9 GiB
[ 3.656531] mmcblk0boot0: mmc0:0001 SLD32G partition 1 4.00 MiB
[ 3.662371] mmcblk0boot1: mmc0:0001 SLD32G partition 2 4.00 MiB
[ 3.667986] mmcblk0rpmb: mmc0:0001 SLD32G partition 3 4.00 MiB, chardev (242:0)
[ 3.702215] mmcblk0: p1 p2
[ 4.006031] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 4.908317] EXT4-fs (mmcblk0p2): re-mounted. Opts: discard
[ 6.529007] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac43456-sdio.radxa,zero.txt failed with error -2
Is HS400 really disabled? If it is so, what should I do to enable HS400?
Thank you! ![]()
