Hi there, new to this board and Radxa.
I’m trying to use the serial port on the 40 pin GPIO header at pins 8 and 10, but I do NOT want the linux console there. I just want to be able to open the serial port and use it normally.
I’ve tried modify the kernel boot parameters, but I’m flying a little blind here.
# Execute "update_extlinux.sh" after changing file /boot/config.txt.
#cmdline: earlycon=uart8250,mmio32,0xfeb50000 console=ttyFIQ0 console=tty1 consoleblank=0 loglevel=0
cmdline: earlycon=uart8250,mmio32,0xfeb50000 loglevel=0
dtoverlay=rk3588-uart7-m2
Do I comment out the dtoverlay? Use a different one? Can I find a mapping of what uart7 and m2 mean? The dtoverlay page doesn’t even list the rk3588 overlays.
I should mention that I am trying to bring up a gpio “hat” that I had previously developed for the pi devices. This had communicates over serial at 1Mb/s. I have noticed that I can see garbled communications from my device on /dev/ttsyFIQ0. It looks like it is running at the wrong speed. I have tried using stty and other methods to set the speed to 1000000, but it fails. It looks like the speed of this port is somehow locked at 115200?
Thanks!
