This is my second eMMC that has been gone in a short time. The first one became unusable in ~3 weeks and this one (the new one) wore off in a month. Although i can still read it, or i think i can read the contents, it is still a disaster if you need to redo everything repeatedly. I am sure it was not completely full, i had 4GB left, but suddenly the controller assumed it was filled up. “It was at this moment i knew i was f* up”.
Filesystem Size Used Avail Use% Mounted on
/dev/mmcblk1p2 28G 28G 0 100% /
devtmpfs 4.0M 0 4.0M 0% /dev
tmpfs 7.7G 0 7.7G 0% /dev/shm
tmpfs 3.1G 19M 3.1G 1% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 1.6G 44K 1.6G 1% /run/user/109
tmpfs 1.6G 44K 1.6G 1% /run/user/1000
/dev/mmcblk1p1 511M 122M 390M 24% /boot
This Foresee chip (or the controller) can’t really be trusted. Taking apart the usual “do a backup”, and “cross compile in your host computer”, “buy cheap, buy twice”, etc, etc, i would like to know how good is your experience with the current BSP kernel with nvm2 SSD, SATA hat, or SATA USB.
Please, rate the reliability, speed, lifetime expectation, and model/maker/size you currently use.
I know it is a relative question but consider it for heavy usage.
