Jack can u pls confirm if emmc works with rockpi-s on the emmc socket pins? I have designed my own baseboard for the rockpi-s SoM D4W but emmc is not working on it… is there a separate image for that? I get “write lba failed” error from the rkdevtools… after failing to run emmc there i started this topic as a workaround. But i want emmc to work directly and i have the baseboard for the emmc module as well
The image for SD Nand and eMMC is the same one. The loader will detect the storage media in defined order to write the image. Please paste your full log when you run the
rkdeveloptool db rk3308_loader_uart0_m0_emmc_port_support_sd_20190717.bin
