I noticed the light ring on my E25 suddenly changed to green rather than cycling through the various colors. The radax-led service is still running okay. I am seeing this error repeat in the journal log
Jan 23 05:37:21 radxa-e25 radxa-e25-led.sh[372]: /usr/local/bin/radxa-e25-led.sh: line 37: /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
Jan 23 05:37:21 radxa-e25 radxa-e25-led.sh[372]: /usr/local/bin/radxa-e25-led.sh: line 38: /sys/class/pwm/pwmchip1/pwm0/duty_cycle: No such file or directory
Jan 23 05:37:21 radxa-e25 radxa-e25-led.sh[372]: /usr/local/bin/radxa-e25-led.sh: line 39: /sys/class/pwm/pwmchip2/pwm0/duty_cycle: No such file or directory
I think it happened after the last apt update / upgrade command. The pwmchip 0 / 1 / 2 part of the path exists but not the /pwm0 part.
I noticed this happens when you stop the radxa-led service: it disables the PWM.
To fix:
killall radxa-e25-led.sh
Then
/usr/local/bin/radxa-e25-led.sh start
And if you run this script, what happens?
for i in 0 1 2
do
echo 0 > /sys/class/pwm/pwmchip${i}/export
echo 255000 > /sys/class/pwm/pwmchip${i}/pwm0/period
echo normal > /sys/class/pwm/pwmchip${i}/pwm0/polarity
echo 127000 > /sys/class/pwm/pwmchip${i}/pwm0/duty_cycle
echo 1 > /sys/class/pwm/pwmchip${i}/pwm0/enable
done
./test.sh: line 3: echo: write error: Device or resource busy
./test.sh: line 4: /sys/class/pwm/pwmchip0/pwm0/period: No such file or directory
./test.sh: line 5: /sys/class/pwm/pwmchip0/pwm0/polarity: No such file or directory
./test.sh: line 6: /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
./test.sh: line 7: /sys/class/pwm/pwmchip0/pwm0/enable: No such file or directory
./test.sh: line 4: /sys/class/pwm/pwmchip1/pwm0/period: No such file or directory
./test.sh: line 5: /sys/class/pwm/pwmchip1/pwm0/polarity: No such file or directory
./test.sh: line 6: /sys/class/pwm/pwmchip1/pwm0/duty_cycle: No such file or directory
./test.sh: line 7: /sys/class/pwm/pwmchip1/pwm0/enable: No such file or directory
./test.sh: line 4: /sys/class/pwm/pwmchip2/pwm0/period: No such file or directory
./test.sh: line 5: /sys/class/pwm/pwmchip2/pwm0/polarity: No such file or directory
./test.sh: line 6: /sys/class/pwm/pwmchip2/pwm0/duty_cycle: No such file or directory
./test.sh: line 7: /sys/class/pwm/pwmchip2/pwm0/enable: No such file or directory
