I’m using a newly flashed SD card (same result for both debian and ubuntu images) on an Radxa E25 board. Only when plugged into my laptop via USB C does it boot successfully, all other times (5 different power supplies tried, including one designed to charge the laptop itself) the unit’s lights will turn green, then off, then green, then off repeatedly.
I can connect via serial console (115200 baud rate), but can never identify what causes the boot loop.
Can anyone please advise a solution or at least some troubleshooting steps?
@giggls Ironically it is ONLY when I connect via my computer’s USB port that I can run the device without a boot loop. so I CAN connect over serial.
After the last few days I’ve had SOME success with other devices (if left long enough, it seems to boot stable, but only after cycling a handful of times.)
is there any info I could collect from the boot logs that could help identify the issue?
Oooh and to get serial console and power over the same port… I use a usbc hub with power delivery input attached to my laptop… It gets the power it needs and it shows up as a serial service for watching the boot sequence…
Same sort of problem for me, sorted with a proper PD psu. I was trying to power my rock3a with a regulated ‘bench’ 5v supply which just ended up with consistent boot failures and boot loops.
