I am yet to receive my RockPi E board - my main use case is to set it up as a wireless router + firewall device, I have ordered 5GHz variant that has RTL8821CU chip.
I was wondering I will be able to use the wlan chip in dual-band AP mode with hostapd - i.e. simultaneous 2.4 GHz and 5GHz dual channel AP.
According to output of iw list I was able to find somewhere on internet it seems like “interface combinations are not supported” - this will terribly affect my intended use case - I do not want to use separate USB adapter for the other band.
Can someone who has the device share the iw list output and confirm if this indeed is a case ?
This is from my Rocpi E eng. Sample, kernel 5.9.0-rc8 . Note there are several RTL8821CU sources around the internet, but basically the same port… But I would not rely solely on this output:.
What I can say is that RTL8821CU is superior to most of the broadcom/cypress i have tested so far.
ubuntu@rockpie:~$ sudo iw list
[sudo] password for ubuntu:
Wiphy phy0
max # scan SSIDs: 9
max scan IEs length: 2304 bytes
max # sched scan SSIDs: 0
max # match sets: 0
max # scan plans: 1
max scan plan interval: -1
max scan plan iterations: 0
Retry short limit: 7
Retry long limit: 4
Coverage class: 0 (up to 0m)
Supported Ciphers:
* WEP40 (00-0f-ac:1)
* WEP104 (00-0f-ac:5)
* TKIP (00-0f-ac:2)
* CCMP-128 (00-0f-ac:4)
Available Antennas: TX 0 RX 0
Supported interface modes:
* IBSS
* managed
* AP
* monitor
* P2P-client
* P2P-GO
Band 1:
Capabilities: 0x1962
HT20/HT40
Static SM Power Save
RX HT20 SGI
RX HT40 SGI
RX STBC 1-stream
Max AMSDU length: 7935 bytes
DSSS/CCK HT40
Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
Minimum RX AMPDU time spacing: 16 usec (0x07)
HT Max RX data rate: 150 Mbps
HT TX/RX MCS rate indexes supported: 0-7
Bitrates (non-HT):
* 1.0 Mbps
* 2.0 Mbps
* 5.5 Mbps
* 11.0 Mbps
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 2412 MHz [1] (20.0 dBm)
* 2417 MHz [2] (20.0 dBm)
* 2422 MHz [3] (20.0 dBm)
* 2427 MHz [4] (20.0 dBm)
* 2432 MHz [5] (20.0 dBm)
* 2437 MHz [6] (20.0 dBm)
* 2442 MHz [7] (20.0 dBm)
* 2447 MHz [8] (20.0 dBm)
* 2452 MHz [9] (20.0 dBm)
* 2457 MHz [10] (20.0 dBm)
* 2462 MHz [11] (20.0 dBm)
* 2467 MHz [12] (20.0 dBm) (no IR)
* 2472 MHz [13] (20.0 dBm) (no IR)
* 2484 MHz [14] (disabled)
Band 2:
Capabilities: 0x1862
HT20/HT40
RX HT20 SGI
RX HT40 SGI
No RX STBC
DSSS/CCK HT40
VHT Capabilities (0x03c00122):
Max MPDU length: 11454
Supported Channel Width: neither 160 nor 80+80
short GI (80 MHz)
+HTC-VHT
VHT RX MCS set:
1 streams: MCS 0-9
2 streams: not supported
3 streams: not supported
4 streams: not supported
5 streams: not supported
6 streams: not supported
7 streams: not supported
8 streams: not supported
VHT RX highest supported: 434 Mbps
VHT TX MCS set:
1 streams: MCS 0-9
VHT TX highest supported: 434 Mbps
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 5180 MHz [36] (17.0 dBm)
* 5200 MHz [40] (17.0 dBm)
* 5220 MHz [44] (17.0 dBm)
* 5240 MHz [48] (17.0 dBm)
* 5260 MHz [52] (24.0 dBm) (no IR, radar detection)
* 5280 MHz [56] (24.0 dBm) (no IR, radar detection)
* 5300 MHz [60] (24.0 dBm) (no IR, radar detection)
* 5320 MHz [64] (24.0 dBm) (no IR, radar detection)
* 5500 MHz [100] (24.0 dBm) (no IR, radar detection)
* 5520 MHz [104] (24.0 dBm) (no IR, radar detection)
* 5540 MHz [108] (24.0 dBm) (no IR, radar detection)
* 5560 MHz [112] (24.0 dBm) (no IR, radar detection)
* 5580 MHz [116] (24.0 dBm) (no IR, radar detection)
* 5600 MHz [120] (24.0 dBm) (no IR, radar detection)
* 5620 MHz [124] (24.0 dBm) (no IR, radar detection)
* 5640 MHz [128] (24.0 dBm) (no IR, radar detection)
* 5660 MHz [132] (24.0 dBm) (no IR, radar detection)
* 5680 MHz [136] (24.0 dBm) (no IR, radar detection)
* 5700 MHz [140] (24.0 dBm) (no IR, radar detection)
* 5720 MHz [144] (disabled)
* 5745 MHz [149] (30.0 dBm)
* 5765 MHz [153] (30.0 dBm)
* 5785 MHz [157] (30.0 dBm)
* 5805 MHz [161] (30.0 dBm)
* 5825 MHz [165] (30.0 dBm)
* 5845 MHz [169] (disabled)
* 5865 MHz [173] (disabled)
* 5885 MHz [177] (disabled)
Supported commands:
* new_interface
* set_interface
* new_key
* start_ap
* new_station
* set_bss
* join_ibss
* set_pmksa
* del_pmksa
* flush_pmksa
* remain_on_channel
* frame
* set_channel
* connect
* disconnect
Supported TX frame types:
* IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
Supported RX frame types:
* IBSS: 0xd0
* managed: 0x40 0xd0
* AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* P2P-client: 0x40 0xd0
* P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
WoWLAN support:
* wake up on anything (device continues operating normally)
software interface modes (can always be added):
* monitor
Device supports scan flush.
Supported extended features:
There is no other way. All dual-band routers have separate radio for 2.4 and 5Ghz. If you have one device - you can choose where to have AP, but you can’t run it simultaneously.
It’s my fault - I didn’t research on the chipset prior. It’s alright. I have limited use of 2.4GHz band and I can probably use the USB adapter for that.
