I need DSI displays that are verified to work with either the CM3 or CM5, I see people having problems but I would like to know if there’es been any success. Preferably the display should be 5.5inches or smaller.
Thank you
Thank you
Continuing the discussion from DSI Displays for CM3 or CM5:
regarding your need for a DSI display …
You might not be able or willing to try this for various reasons, but AliExpress has a 3-1/2" HDMI touch display with (I think) 1080p resolution for cheap. Since you already have HDMI output it might work out to be the simplest… then again maybe not. I have one of these and it is quite a display. They also have a ton of other unbelievably cheap touch or not touch displays running on HDMI, USB, etc. It might not be what you’re looking for, but I would feel remiss if I didn’t mention this to you. Good Luck.
