I have installed a fresh Windows 10 x64 from USB stick. I choosed to wipe all partitions present on the eMMC module. This also has wiped the recovery partition with working drivers.
After the installation was finished some drivers where missing. Most of them could be installed by Windows Update. But the WLAN driver could not be found. It would be cool if RADXA would provide the drivers used to build the recovery image on eMMC as a download link?
All drivers found in a Google search didn’t work. I also used Snappy Driver Installer but the driver SDI provides did not work either.
This seems to be only the firmware, looked into the archive.
I just restored the Install.wim found to the original partition using dism (after formatting it) and extracted the drivers to external USB. Now after fresh reinstall I can install them again.
Would be easier too if the original driver could be provided directly. Even better a image containing the whole eMMC raw disk so one can at least recover their eMMC drive if needed.
regarding the audio driver, better to ask @jack
Ok, thank you for the hint.
