Hi Radxa team,
I am opening a new topic regarding the IMX219 camera on the Dragon Q6A.
I have been debugging this for quite some time and wanted to share the results of my testing.
Test 1: Basic libcamera Preview
gst-launch-1.0 libcamerasrc ! videoconvert ! autovideosink
Result:
WARN IPAManager ipa_manager.cpp:154 No IPA found in '/usr/lib/aarch64-linux-gnu/libcamera'
WARN CameraSensor camera_sensor.cpp:248 'imx219 20-0010': Recommended V4L2 control 0x009a0922 not supported
WARN CameraSensor camera_sensor.cpp:315 'imx219 20-0010': The sensor kernel driver needs to be fixed
ERROR:
streaming stopped, reason not-negotiated (-4)
The IMX219 sensor is detected, but the stream fails immediately.
Test 2: Direct V4L2 Bayer Test
gst-launch-1.0 v4l2src device=/dev/video0 ! \
video/x-bayer,format=bggr10,width=640,height=480 ! \
bayer2rgb ! videoconvert ! waylandsink
Result:
WARNING: erroneous pipeline:
could not link v4l2src0 to bayer2rgb0,
neither element can handle caps
video/x-bayer, format=(string)bggr10
This suggests the Bayer format exposed by the camera cannot be handled by the pipeline.
Test 3: libcamera Debug Logging
LIBCAMERA_LOG_LEVELS=Camera:DEBUG \
gst-launch-1.0 libcamerasrc ! fakesink
Result:
DEBUG Camera camera.cpp:1118 streams configuration:
(0) 640x480-SRGGB10_CSI2P
CRITICAL:
Unsupported media type: video/x-bayer
ERROR:
Additional GStreamer errors:
gst_structure_set: assertion 'structure != NULL' failed
gst_caps_get_structure: assertion 'index < GST_CAPS_LEN (caps)' failed
gst_event_new_caps: assertion 'gst_caps_is_fixed (caps)' failed
gst_pad_push_event: assertion 'GST_IS_EVENT (event)' failed
The stream is configured as:
but GStreamer reports that video/x-bayer is unsupported and the pipeline terminates.
Additional Information
The camera is consistently detected as:
imx219 20-0010
and libcamera consistently reports:
Failed to retrieve the camera location
Rotation control not available, default to 0 degrees
Summary
From what I can tell:
IMX219 is detected successfully.
libcamera can configure a raw Bayer stream (
640x480-SRGGB10_CSI2P). -
GStreamer fails during caps negotiation.
video/x-bayerappears to be the common point of failure. -
All tested pipelines end with
not-negotiated (-4).
Has anyone successfully brought up an IMX219 on the Dragon Q6A?
Are there additional kernel packages, firmware files, device-tree changes, ISP components, or newer builds required to get the camera working?
Any guidance would be greatly appreciated.
Thanks.
