What does it mean that the green light is always on and the blue light is flashing?
Does the armbian system have commands to adjust the lights?
You can set them to react on other events
cat /sys/class/leds/rockpis:blue:user/trigger
or
cat /sys/class/leds/rockpis:green:power/trigger
will show you:
none rc-feedback kbd-scrolllock kbd-numlock kbd-capslock kbd-kanalock kbd-shiftlock kbd-altgrlock kbd-ctrllock kbd-altlock kbd-shiftllock kbd-shiftrlock kbd-ctrlllock kbd-ctrlrlock mmc0 mmc1 mmc2 timer oneshot heartbeat [default-on] rfkill0
with
echo heartbeat > /sys/class/leds/rockpis:green:power/trigger
you can change to “cause” the leds lights.
Mmc0, MMC1, mMC2 timer what do these parameters represent respectively?
It seems that once you restart, the previous Settings will be restored.How to save modified lighting Settings?
mmc ist a storage adapter. The led will flash on read/write access.
There is no option to save this. You can simply put these lines into /etc/rc.local “above” the last exit line.
