I just powered one of the 5Bs that I purchased during the launch. Only this board has issues. They all have the same USB brick and heatsink/fan from Allnet.
What happens is that I run a few commands then I get a bunch of kernel messages, then it just freezes. Temps seem to be stable at around 32 C.
Is it a hardware issue? If so, how has anyone’s warranty issues been handled? I haven’t heard back from radxa or allnet.
root@rock-5b:~# dmesg
[ 1.714110] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[ 1.714132] Linux version 5.10.66-27-rockchip-gea60d388902d (stephen@lara) (gcc (Ubuntu/Linaro 7.5.0-6ubuntu2) 7.5.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #rockchip SMP Mon Oct 24 08:25:47 UTC 2022
[ 1.723299] Machine model: Radxa ROCK 5B
[ 1.723468] efi: UEFI not found.
[ 1.726493] OF: fdt: Reserved memory: failed to reserve memory for node ‘drm-logo@00000000’: base 0x0000000000000000, size 0 MiB
[ 1.726509] OF: fdt: Reserved memory: failed to reserve memory for node ‘drm-cubic-lut@00000000’: base 0x0000000000000000, size 0 MiB
[ 1.726556] Reserved memory: created CMA memory pool at 0x0000000010000000, size 256 MiB
[ 1.726561] OF: reserved mem: initialized node cma, compatible id shared-dma-pool
[ 1.989614] Zone ranges:
[ 1.989624] DMA [mem 0x0000000000200000-0x00000000ffffffff]
[ 1.989635] DMA32 empty
[ 1.989641] Normal [mem 0x0000000100000000-0x00000003ffefffff]
[ 1.989649] Movable zone start for each node
[ 1.989652] Early memory node ranges
[ 1.989657] node 0: [mem 0x0000000000200000-0x00000000efffffff]
[ 1.989664] node 0: [mem 0x0000000100000000-0x00000003fbffffff]
[ 1.989672] node 0: [mem 0x00000003fc500000-0x00000003ffefffff]
[ 1.989678] Initmem setup node 0 [mem 0x0000000000200000-0x00000003ffefffff]
[ 1.989685] On node 0 totalpages: 4126720
[ 1.989691] DMA zone: 15352 pages used for memmap
[ 1.989695] DMA zone: 0 pages reserved
[ 1.989700] DMA zone: 982528 pages, LIFO batch:63
[ 1.989705] Normal zone: 49148 pages used for memmap
[ 1.989710] Normal zone: 3144192 pages, LIFO batch:63
[ 2.076608] On node 0, zone Normal: 256 pages in unavailable ranges
[ 2.076769] psci: probing for conduit method from DT.
[ 2.076780] psci: PSCIv1.1 detected in firmware.
[ 2.076784] psci: Using standard PSCI v0.2 function IDs
[ 2.076790] psci: MIGRATE_INFO_TYPE not supported.
[ 2.076796] psci: SMC Calling Convention v1.2
[ 2.077177] percpu: Embedded 31 pages/cpu s88680 r8192 d30104 u126976
[ 2.077232] pcpu-alloc: s88680 r8192 d30104 u126976 alloc=31*4096
[ 2.077239] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 2.077404] Detected VIPT I-cache on CPU0
[ 2.077454] CPU features: detected: GIC system register CPU interface
[ 2.077459] CPU features: detected: Virtualization Host Extensions
[ 2.077469] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 2.077476] alternatives: patching kernel code
[ 2.077810] Built 1 zonelists, mobility grouping on. Total pages: 4062220
[ 2.077819] Kernel command line: root=UUID=67ad0e7b-3914-48d6-97c2-c48e5e0e405b console=ttyFIQ0 console=tty1 consoleblank=0 loglevel=0 panic=10 rootwait rw init=/sbin/init rootfstype=ext4 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 irqchip.gicv3_pseudo_nmi=0 switolb=1 coherent_pool=2M
[ 2.079749] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 2.080464] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 2.080471] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 2.086318] software IO TLB: mapped [mem 0x00000000ec000000-0x00000000f0000000] (64MB)
[ 2.100498] BUG: Bad page state in process swapper pfn:020dc
[ 2.100511] page:(ptrval) refcount:0 mapcount:-52224 mapping:0000000000000000 index:0x0 pfn:0x20dc
[ 2.100517] flags: 0x0()
[ 2.100526] raw: 0000000000000000 fffffffeffe83708 fffffffeffe83708 0000000000000000
[ 2.100533] raw: 0000000000000000 0000000000000000 00000000ffff33ff 0000000000000000
[ 2.100537] page dumped because: nonzero mapcount
[ 2.100541] Modules linked in:
[ 2.100554] CPU: 0 PID: 0 Comm: swapper Not tainted 5.10.66-27-rockchip-gea60d388902d #rockchip
[ 2.100558] Hardware name: Radxa ROCK 5B (DT)
[ 2.100563] Call trace:
[ 2.100575] dump_backtrace+0x0/0x1a8
[ 2.100581] show_stack+0x2c/0x38
[ 2.100589] dump_stack_lvl+0xd0/0xfc
[ 2.100594] dump_stack+0x14/0x2c
[ 2.100601] bad_page+0xfc/0x100
[ 2.100606] check_free_page+0x90/0xa8
[ 2.100612] __free_pages_ok+0x1c4/0x1e8
[ 2.100617] __free_pages_core+0xa0/0xbc
[ 2.100623] memblock_free_pages+0x28/0x34
[ 2.100629] memblock_free_all+0x180/0x1e8
[ 2.100636] mem_init+0x64/0x84
[ 2.100642] start_kernel+0x2f4/0x574
[ 2.100646] Disabling lock debugging due to kernel taint
[ 2.100819] BUG: Bad page state in process swapper pfn:030dc
[ 2.100826] page:(ptrval) refcount:0 mapcount:-49152 mapping:0000000000000000 index:0x0 pfn:0x30dc
[ 2.100831] flags: 0x0()
[ 2.100838] raw: 0000000000000000 fffffffeffec3708 fffffffeffec3708 0000000000000000
[ 2.100845] raw: 0000000000000000 0000000000000000 00000000ffff3fff 0000000000000000
[ 2.100848] page dumped because: nonzero mapcount
[ 2.100851] Modules linked in:
[ 2.100861] CPU: 0 PID: 0 Comm: swapper Tainted: G B 5.10.66-27-rockchip-gea60d388902d #rockchip
[ 2.100864] Hardware name: Radxa ROCK 5B (DT)
[ 2.100868] Call trace:
[ 2.100874] dump_backtrace+0x0/0x1a8
[ 2.100880] show_stack+0x2c/0x38
[ 2.100885] dump_stack_lvl+0xd0/0xfc
[ 2.100891] dump_stack+0x14/0x2c
[ 2.100896] bad_page+0xfc/0x100
[ 2.100901] check_free_page+0x90/0xa8
[ 2.100906] __free_pages_ok+0x1c4/0x1e8
[ 2.100912] __free_pages_core+0xa0/0xbc
[ 2.100917] memblock_free_pages+0x28/0x34
[ 2.100922] memblock_free_all+0x180/0x1e8
[ 2.100928] mem_init+0x64/0x84
[ 2.100933] start_kernel+0x2f4/0x574
[ 2.101093] BUG: Bad page state in process swapper pfn:040dc
[ 2.101100] page:(ptrval) refcount:0 mapcount:-49152 mapping:0000000000000000 index:0x0 pfn:0x40dc
[ 2.101105] flags: 0x0()
[ 2.101112] raw: 0000000000000000 fffffffefff03708 fffffffefff03708 0000000000000000
[ 2.101118] raw: 0000000000000000 0000000000000000 00000000ffff3fff 0000000000000000
[ 2.101122] page dumped because: nonzero mapcount
[ 2.101125] Modules linked in:
[ 2.101134] CPU: 0 PID: 0 Comm: swapper Tainted: G B 5.10.66-27-rockchip-gea60d388902d #rockchip
[ 2.101138] Hardware name: Radxa ROCK 5B (DT)
[ 2.101141] Call trace:
[ 2.101147] dump_backtrace+0x0/0x1a8
[ 2.101153] show_stack+0x2c/0x38
[ 2.101158] dump_stack_lvl+0xd0/0xfc
[ 2.101164] dump_stack+0x14/0x2c
[ 2.101169] bad_page+0xfc/0x100
[ 2.101174] check_free_page+0x90/0xa8
[ 2.101179] __free_pages_ok+0x1c4/0x1e8
[ 2.101184] __free_pages_core+0xa0/0xbc
[ 2.101190] memblock_free_pages+0x28/0x34
[ 2.101195] memblock_free_all+0x180/0x1e8
[ 2.101200] mem_init+0x64/0x84
[ 2.101206] start_kernel+0x2f4/0x574
[ 2.101366] BUG: Bad page state in process swapper pfn:050dc
[ 2.101373] page:(ptrval) refcount:0 mapcount:-49152 mapping:0000000000000000 index:0x0 pfn:0x50dc
[ 2.101377] flags: 0x0()
[ 2.101384] raw: 0000000000000000 fffffffefff43708 fffffffefff43708 0000000000000000
[ 2.101391] raw: 0000000000000000 0000000000000000 00000000ffff3fff 0000000000000000
[ 2.101394] page dumped because: nonzero mapcount
[ 2.101397] Modules linked in:
[ 2.101407] CPU: 0 PID: 0 Comm: swapper Tainted: G B 5.10.66-27-rockchip-gea60d388902d #rockchip
[ 2.101411] Hardware name: Radxa ROCK 5B (DT)
[ 2.101414] Call trace:
[ 2.101420] dump_backtrace+0x0/0x1a8
[ 2.101425] show_stack+0x2c/0x38
[ 2.101431] dump_stack_lvl+0xd0/0xfc
[ 2.101436] dump_stack+0x14/0x2c
[ 2.101442] bad_page+0xfc/0x100
[ 2.101447] check_free_page+0x90/0xa8
[ 2.101452] __free_pages_ok+0x1c4/0x1e8
[ 2.101458] __free_pages_core+0xa0/0xbc
[ 2.101463] memblock_free_pages+0x28/0x34
[ 2.101468] memblock_free_all+0x180/0x1e8
[ 2.101474] mem_init+0x64/0x84
[ 2.101479] start_kernel+0x2f4/0x574
[ 2.101639] BUG: Bad page state in process swapper pfn:060dc
[ 2.101646] page:(ptrval) refcount:0 mapcount:-49152 mapping:0000000000000000 index:0x0 pfn:0x60dc
[ 2.101650] flags: 0x0()
[ 2.101657] raw: 0000000000000000 fffffffefff83708 fffffffefff83708 0000000000000000
[ 2.101664] raw: 0000000000000000 0000000000000000 00000000ffff3fff 0000000000000000
[ 2.101667] page dumped because: nonzero mapcount
[ 2.101671] Modules linked in:
[ 2.101680] CPU: 0 PID: 0 Comm: swapper Tainted: G B 5.10.66-27-rockchip-gea60d388902d #rockchip
[ 2.101683] Hardware name: Radxa ROCK 5B (DT)
[ 2.101687] Call trace:
[ 2.101693] dump_backtrace+0x0/0x1a8
[ 2.101698] show_stack+0x2c/0x38
[ 2.101704] dump_stack_lvl+0xd0/0xfc
[ 2.101709] dump_stack+0x14/0x2c
[ 2.101715] bad_page+0xfc/0x100
[ 2.101720] check_free_page+0x90/0xa8
[ 2.101725] __free_pages_ok+0x1c4/0x1e8
[ 2.101730] __free_pages_core+0xa0/0xbc
[ 2.101735] memblock_free_pages+0x28/0x34
[ 2.101741] memblock_free_all+0x180/0x1e8
[ 2.101747] mem_init+0x64/0x84
[ 2.101752] start_kernel+0x2f4/0x574
[ 2.101914] BUG: Bad page state in process swapper pfn:070dc
[ 2.101920] page:(ptrval) refcount:0 mapcount:-49152 mapping:0000000000000000 index:0x0 pfn:0x70dc
[ 2.101925] flags: 0x0()
[ 2.101932] raw: 0000000000000000 fffffffefffc3708 fffffffefffc3708 0000000000000000
[ 2.101938] raw: 0000000000000000 0000000000000000 00000000ffff3fff 0000000000000000
[ 2.101942] page dumped because: nonzero mapcount
[ 2.101945] Modules linked in:
[ 2.101954] CPU: 0 PID: 0 Comm: swapper Tainted: G B 5.10.66-27-rockchip-gea60d388902d #rockchip
[ 2.101958] Hardware name: Radxa ROCK 5B (DT)
[ 2.101961] Call trace:
[ 2.101967] dump_backtrace+0x0/0x1a8
[ 2.101972] show_stack+0x2c/0x38
[ 2.101978] dump_stack_lvl+0xd0/0xfc
[ 2.101983] dump_stack+0x14/0x2c
[ 2.101988] bad_page+0xfc/0x100
[ 2.101993] check_free_page+0x90/0xa8
[ 2.101999] __free_pages_ok+0x1c4/0x1e8
[ 2.102004] __free_pages_core+0xa0/0xbc
[ 2.102009] memblock_free_pages+0x28/0x34
[ 2.102015] memblock_free_all+0x180/0x1e8
[ 2.102021] mem_init+0x64/0x84
[ 2.102026] start_kernel+0x2f4/0x574
[ 2.102187] BUG: Bad page state in process swapper pfn:080dc
[ 2.102194] page:(ptrval) refcount:0 mapcount:-49152 mapping:0000000000000000 index:0x0 pfn:0x80dc
[ 2.102198] flags: 0x0()
[ 2.102205] raw: 0000000000000000 ffffffff00003708 ffffffff00003708 0000000000000000
[ 2.102212] raw: 0000000000000000 0000000000000000 00000000ffff3fff 0000000000000000
[ 2.102215] page dumped because: nonzero mapcount
[ 2.102219] Modules linked in:
[ 2.102228] CPU: 0 PID: 0 Comm: swapper Tainted: G B 5.10.66-27-rockchip-gea60d388902d #rockchip
[ 2.102231] Hardware name: Radxa ROCK 5B (DT)
[ 2.102235] Call trace:
[ 2.102241] dump_backtrace+0x0/0x1a8
[ 2.102246] show_stack+0x2c/0x38
[ 2.102252] dump_stack_lvl+0xd0/0xfc
[ 2.102257] dump_stack+0x14/0x2c
[ 2.102262] bad_page+0xfc/0x100
[ 2.102268] check_free_page+0x90/0xa8
[ 2.102273] __free_pages_ok+0x1c4/0x1e8
[ 2.102278] __free_pages_core+0xa0/0xbc
[ 2.102283] memblock_free_pages+0x28/0x34
[ 2.102289] memblock_free_all+0x180/0x1e8
[ 2.102294] mem_init+0x64/0x84
[ 2.102300] start_kernel+0x2f4/0x574
[ 2.102461] BUG: Bad page state in process swapper pfn:090dc
I’m using the Radxa branded one from Allnet.
I will have chance to test them about june.
