[Fixes and New Features] Fixed disk usage display, disk temperatures, disk and network activity, fan speed percentage display on OLED display, improved uptime format
Hi all!
I added some extra function to the OLED display (network and disk activity in one sec). And it’s also fixing the “Only Disk: root percentage show storage” problem. You can see them on the images:
1.0. Network:
The network interfaces are automatically recognized and only those will be show up on the OLED which status is UP. Eg. if you only use wired network (eth0), you will only see that on the OLED display. If you use wired (eth0) and wireless (wlan0), you can see both of them. And so on.
1.1. Network OLED explanation:
Network (interface_name): Which interface is measured.
rx: receive (download) speed in MB/s.
tx: transmit (upload) soeed in MB/s.
2.0. Disks:
For the disk, you have to edit the /etc/rockpi-sata.conf file (use sudo to edit it).
You have to add your mount points (where you mount your hdds/ssds) separated with | (pipe character).
You don’t have to add the root (/) device (the SD card) separately, it show always up!
Only the disks.
2.1. Edit the configuration file with sudo: /etc/rockpi-sata.conf
[disk]
# Mount points for disks (separated with |)
mnt_points = /mnt/mount1|/mnt/mount2
2.2. In my case example:
I have 4 HDDs (two of them is in RAID1) so actually I have 3 devices.
I check out their mount points with the df -h command:
pi@raspberry-pi-4:~ $ df -h
Filesystem      Size  Used Available Use% Mounted on
/dev/root        56G   15G       39G  28% /
devtmpfs        1,7G     0      1,7G   0% /dev
tmpfs           1,8G   28K      1,8G   1% /dev/shm
tmpfs           1,8G  9,0M      1,8G   1% /run
tmpfs           5,0M  4,0K      5,0M   1% /run/lock
tmpfs           1,8G     0      1,8G   0% /sys/fs/cgroup
mergerfs        1,8T  1,5T      274G  85% /mnt/torrents
/dev/loop1       46M   46M         0 100% /snap/core18/1937
/dev/loop0       65M   65M         0 100% /snap/gtk-common-themes/1514
/dev/mmcblk0p6  253M   46M      207M  18% /boot
tmpfs           365M     0      365M   0% /run/user/109
/dev/md0        916G  703G      167G  81% /mnt/raid1
/dev/sdc1       916G  624G      247G  72% /mnt/torrent2
/dev/sdd1       916G  842G       28G  97% /mnt/torrent
tmpfs           365M     0      365M   0% /run/user/1000
I have /dev/md0 /dev/sdc1 and /dev/sdd1 (in sdc1 and sdd1 the number means the partition number).
Now we just have to read out these disks mount points.
/dev/md0: /mnt/raid1
/dev/sdc1: /mnt/torrent2
/dev/sdd1: /mnt/torrent
I would like to see all three disks used space percentage.
Separation character for mount points is: |
My rockpi-sata.conf file:
[fan]
# When the temperature is above lv0 (35'C), the fan at 25% power,
# and lv1 at 50% power, lv2 at 75% power, lv3 at 100% power.
# When the temperature is below lv0, the fan is turned off.
# You can change these values if necessary.
lv0 = 35
lv1 = 40
lv2 = 45
lv3 = 50
[key]
# You can customize the function of the key, currently available functions are
# slider: oled display next page
# switch: fan turn on/off switch
# reboot, poweroff
# If you have any good suggestions for key functions,
# please add an issue on https://setq.me/rockpi-sata
click = slider
twice = switch
press = poweroff
[time]
# twice: maximum time between double clicking (seconds)
# press: long press time (seconds)
twice = 0.7
press = 1.8
[slider]
# Whether the oled auto display next page and the time interval (seconds)
auto = true
time = 10
[oled]
# Whether rotate the text of oled 180 degrees, whether use Fahrenheit
rotate = true
f-temp = false
[disk]
mnt_points = /mnt/raid1|/mnt/torrent|/mnt/torrent2
2.4. Other example:
We have two HDD (sda, sdb). These names (sda, sdb) could change for the HDD devices, eg. when we reboot the rpi, it maybe rename them, this is why we use the mount points (they only change if we modify them manually).
We mount sda to /mnt/hdd1 and sdb to /mnt/hdd2.
The /etc/rockpi-sata.conf should contain the following:
[disk]
mnt_points = /mnt/hdd1|/mnt/hdd2
You will see these two devices.
2.5. Disk OLED explanation:
Disk (disk_name): Which disk is measured.
R: read speed in MB/s.
W: write speed in MB/s.
3.0. Update the service files
We have to replace two service files.
3.1. Backing up the service files
Please create a backup from these files (they will be replaced completly):
/usr/bin/rockpi-sata/misc.py
/usr/bin/rockpi-sata/oled.py
3.2. Replace the files
And finally, you have to replace these two files which are using the rockpi-sata service (use sudo to edit them):
3.3. /usr/bin/rockpi-sata/misc.py:
#!/usr/bin/env python3
import re
import os
import sys
import time
import subprocess
import RPi.GPIO as GPIO
import multiprocessing as mp
from collections import defaultdict
from configparser import ConfigParser
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO.setup(17, GPIO.OUT)
GPIO.output(17, GPIO.HIGH)
cmds = {
    'blk': "lsblk | awk '{print $1}'",
    'up': "echo Uptime: `uptime | sed 's/.*up \\([^,]*\\), .*/\\1/'`",
    'temp': "cat /sys/class/thermal/thermal_zone0/temp",
    'ip': "hostname -I | awk '{printf \"IP %s\", $1}'",
    'cpu': "uptime | tr , . | awk '{printf \"CPU Load: %.2f%%\", $(NF-2)}'",
    'men': "free -m | awk 'NR==2{printf \"Mem: %s/%s MB\", $3,$2}'",
    'disk': "df -h | awk '$NF==\"/\"{printf \"Disk: %d/%d GB %s\", $3,$2,$5}'"
lv2dc = {'lv3': 100, 'lv2': 75, 'lv1': 50, 'lv0': 25}
# pin37(bcm26) sata0, pin22(bcm25) sata1
def set_mode(pin, mode):
    try:
        GPIO.setup(pin, GPIO.OUT)
        GPIO.output(pin, mode)
    except Exception as ex:
        print(ex)
def disk_turn_on():
    #blk1 = get_blk()
    set_mode(26, GPIO.HIGH)
    time.sleep(0.5)
    set_mode(25, GPIO.HIGH)
    wait_blk(10)
    #blk2 = get_blk()
    #conf['disk'] = sorted(list(set(blk2) - set(blk1)))
def disk_turn_off():
    set_mode(26, GPIO.LOW)
    time.sleep(0.5)
    set_mode(25, GPIO.LOW)
def check_output(cmd):
    return subprocess.check_output(cmd, shell=True).decode().strip()
def check_call(cmd):
    return subprocess.check_call(cmd, shell=True)
def wait_blk(t1=10):
    t = 0
    while t <= t1:
        try:
            check_call('lsblk /dev/sda > /dev/null 2>&1')
            check_call('lsblk /dev/sdb > /dev/null 2>&1')
            check_call('lsblk /dev/sdc > /dev/null 2>&1')
            check_call('lsblk /dev/sdd > /dev/null 2>&1')
        except Exception:
            time.sleep(0.1)
            t += 0.1
            continue
        else:
            time.sleep(0.5)
            break
def get_blk():
    return check_output(cmds['blk']).strip().split('\n')
def get_info(s):
    return check_output(cmds[s])
def get_cpu_temp():
    t = float(get_info('temp')) / 1000
    if conf['oled']['f-temp']:
        temp = "CPU Temp: {:.0f}°F".format(t * 1.8 + 32)
    else:
        temp = "CPU Temp: {:.1f}°C".format(t)
    return temp
def read_conf():
    conf = defaultdict(dict)
    try:
        cfg = ConfigParser()
        cfg.read('/etc/rockpi-sata.conf')
        # fan
        conf['fan']['lv0'] = cfg.getfloat('fan', 'lv0')
        conf['fan']['lv1'] = cfg.getfloat('fan', 'lv1')
        conf['fan']['lv2'] = cfg.getfloat('fan', 'lv2')
        conf['fan']['lv3'] = cfg.getfloat('fan', 'lv3')
        # key
        conf['key']['click'] = cfg.get('key', 'click')
        conf['key']['twice'] = cfg.get('key', 'twice')
        conf['key']['press'] = cfg.get('key', 'press')
        # time
        conf['time']['twice'] = cfg.getfloat('time', 'twice')
        conf['time']['press'] = cfg.getfloat('time', 'press')
        # other
        conf['slider']['auto'] = cfg.getboolean('slider', 'auto')
        conf['slider']['time'] = cfg.getfloat('slider', 'time')
        conf['oled']['rotate'] = cfg.getboolean('oled', 'rotate')
        conf['oled']['f-temp'] = cfg.getboolean('oled', 'f-temp')
        # disk
        conf['disk']['mnt_points'] = cfg.get('disk', 'mnt_points').split('|')
        #conf['disk']['disks'] = get_disk_list()
    except Exception:
        # fan
        conf['fan']['lv0'] = 35
        conf['fan']['lv1'] = 40
        conf['fan']['lv2'] = 45
        conf['fan']['lv3'] = 50
        # key
        conf['key']['click'] = 'slider'
        conf['key']['twice'] = 'switch'
        conf['key']['press'] = 'none'
        # time
        conf['time']['twice'] = 0.7  # second
        conf['time']['press'] = 1.8
        # other
        conf['slider']['auto'] = True
        conf['slider']['time'] = 10  # second
        conf['oled']['rotate'] = False
        conf['oled']['f-temp'] = False
        # disk
        conf['disk']['mnt_points'] = []
        #conf['disk']['disks'] = []
    return conf
def read_key(pattern, size):
    s = ''
    while True:
        s = s[-size:] + str(GPIO.input(17))
        for t, p in pattern.items():
            if p.match(s):
                return t
        time.sleep(0.1)
def watch_key(q=None):
    size = int(conf['time']['press'] * 10)
    wait = int(conf['time']['twice'] * 10)
    pattern = {
        'click': re.compile(r'1+0+1{%d,}' % wait),
        'twice': re.compile(r'1+0+1+0+1{3,}'),
        'press': re.compile(r'1+0{%d,}' % size),
    while True:
        q.put(read_key(pattern, size))
def get_interface_list():
    interfaces = []
    cmd = "ip -o link show | awk '{print $2,$9}'"
    list = check_output(cmd).split('\n')
    for x in list:
        name_status = x.split(': ')
        if "UP" in name_status[1]:
            interfaces.append(name_status[0])
    interfaces.sort()
    return interfaces
def get_interface_rx_info(interface):
    cmd = "R1=$(cat /sys/class/net/" + interface + "/statistics/rx_bytes); sleep 1; R2=$(cat /sys/class/net/" + interface + "/statistics/rx_bytes); echo | awk -v r1=$R1 -v r2=$R2 '{printf \"rx: %.5f MB/s\", (r2 - r1) / 1024 / 1024}';"
    output = check_output(cmd)
    return output
def get_interface_tx_info(interface):
    cmd = "T1=$(cat /sys/class/net/" + interface + "/statistics/tx_bytes); sleep 1; T2=$(cat /sys/class/net/" + interface + "/statistics/tx_bytes); echo | awk -v t1=$T1 -v t2=$T2 '{printf \"tx: %.5f MB/s\", (t2 - t1) / 1024 / 1024}';"
    return output
def delete_disk_partition_number(disk):
    if "sd" in disk:
        disk = disk[:-1]
    return disk
def get_disk_list():
    disks = []
    for x in conf['disk']['mnt_points']:
        cmd = "df -Bg | awk '$6==\"{}\" {{printf \"%s\", $1}}'".format(x)
        output = check_output(cmd).split('/')[-1]
        if output != '':
            disks.append(output)
    #if len(disks) < 3:
    #    disks = ['md0', 'sdc1', 'sdd1']
    disks.sort()
    return disks
def get_disk_io_read_info(disk):
    cmd = "R1=$(cat /sys/block/" + disk + "/stat | awk '{print $3}'); sleep 1; R2=$(cat /sys/block/" + disk + "/stat | awk '{print $3}'); echo | awk -v r1=$R1 -v r2=$R2 '{printf \"R: %.5f MB/s\", (r2 - r1) / 2 / 1024}';"
    return output
def get_disk_io_write_info(disk):
    cmd = "W1=$(cat /sys/block/" + disk + "/stat | awk '{print $7}'); sleep 1; W2=$(cat /sys/block/" + disk + "/stat | awk '{print $7}'); echo | awk -v w1=$W1 -v w2=$W2 '{printf \"W: %.5f MB/s\", (w2 - w1) / 2 / 1024}';"
    return output
def get_disk_info(cache={}):
    if not cache.get('time') or time.time() - cache['time'] > 30:
        info = {}
        cmd = "df -h | awk '$NF==\"/\"{printf \"%s\", $5}'"
        info['root'] = check_output(cmd)
        for x in conf['disk']['disks']:
            delete_disk_partition_number(x)
            cmd = "df -Bg | awk '$1==\"/dev/{}\" {{printf \"%s\", $5}}'".format(x)
            info[x] = check_output(cmd)
        cache['info'] = list(zip(*info.items()))
        cache['time'] = time.time()
    return cache['info']
def slider_next(pages):
    conf['idx'].value += 1
    return pages[conf['idx'].value % len(pages)]
def slider_sleep():
    time.sleep(conf['slider']['time'])
def fan_temp2dc(t):
    for lv, dc in lv2dc.items():
        if t >= conf['fan'][lv]:
            return dc
    return 0
def fan_switch():
    conf['run'].value = not(conf['run'].value)
def get_func(key):
    return conf['key'].get(key, 'none')
def open_w1_i2c():
    with open('/boot/config.txt', 'r') as f:
        content = f.read()
    if 'dtoverlay=w1-gpio' not in content:
        with open('/boot/config.txt', 'w') as f:
            f.write(content.strip() + '\ndtoverlay=w1-gpio')
    if 'dtparam=i2c1=on' not in content:
            f.write(content.strip() + '\ndtparam=i2c1=on')
    os.system('/sbin/modprobe w1-gpio')
    os.system('/sbin/modprobe w1-therm')
    os.system('/sbin/modprobe i2c-dev')
conf = {'disk': [], 'idx': mp.Value('d', -1), 'run': mp.Value('d', 1)}
conf.update(read_conf())
if __name__ == '__main__':
    if sys.argv[-1] == 'open_w1_i2c':
        open_w1_i2c()
3.4. /usr/bin/rockpi-sata/oled.py:
#!/usr/bin/python3
import time
import misc
import Adafruit_SSD1306
from PIL import Image
from PIL import ImageDraw
from PIL import ImageFont
font = {
    '10': ImageFont.truetype('fonts/DejaVuSansMono-Bold.ttf', 10),
    '11': ImageFont.truetype('fonts/DejaVuSansMono-Bold.ttf', 11),
    '12': ImageFont.truetype('fonts/DejaVuSansMono-Bold.ttf', 12),
    '14': ImageFont.truetype('fonts/DejaVuSansMono-Bold.ttf', 14),
misc.set_mode(23, 0)
time.sleep(0.2)
misc.set_mode(23, 1)
def disp_init():
    disp = Adafruit_SSD1306.SSD1306_128_32(rst=None)
    [getattr(disp, x)() for x in ('begin', 'clear', 'display')]
    return disp
try:
    disp = disp_init()
except Exception:
    misc.open_w1_i2c()
    time.sleep(0.2)
    disp = disp_init()
image = Image.new('1', (disp.width, disp.height))
draw = ImageDraw.Draw(image)
def disp_show():
    im = image.rotate(180) if misc.conf['oled']['rotate'] else image
    disp.image(im)
    disp.display()
    draw.rectangle((0, 0, disp.width, disp.height), outline=0, fill=0)
def welcome():
    draw.text((0, 0), 'ROCK Pi SATA HAT', font=font['14'], fill=255)
    draw.text((32, 16), 'Loading...', font=font['12'], fill=255)
    disp_show()
def goodbye():
    draw.text((32, 8), 'Exiting...', font=font['14'], fill=255)
    disp_show()
    time.sleep(2)
    disp_show()  # clear
def put_disk_info():
    k, v = misc.get_disk_info()
    text1 = 'Disk: {} {}'.format(k[0], v[0])
    if len(k) == 5:
        text2 = '{} {}  {} {}'.format(k[1], v[1], k[2], v[2])
        text3 = '{} {}  {} {}'.format(k[3], v[3], k[4], v[4])
        page = [
            {'xy': (0, -2), 'text': text1, 'fill': 255, 'font': font['11']},
            {'xy': (0, 10), 'text': text2, 'fill': 255, 'font': font['11']},
            {'xy': (0, 21), 'text': text3, 'fill': 255, 'font': font['11']},
    elif len(k) == 4:
        text3 = '{} {}'.format(k[3], v[3])
        page = [
    elif len(k) == 3:
        page = [
            {'xy': (0, 2), 'text': text1, 'fill': 255, 'font': font['12']},
            {'xy': (0, 18), 'text': text2, 'fill': 255, 'font': font['12']},
    elif len(k) == 2:
        text2 = '{} {}'.format(k[1], v[1])
        page = [
    else:
        page = [{'xy': (0, 2), 'text': text1, 'fill': 255, 'font': font['14']}]
    return page
def put_disk_io_info(pages_len):
    pages = {}
    start_key = pages_len
    disks = misc.get_disk_list()
    for x in disks:
        x = misc.delete_disk_partition_number(x)
        pages[start_key] = [
            {'xy': (0, -2), 'text': 'Disk (' + x + '):', 'fill': 255, 'font': font['11']},
            {'xy': (0, 10), 'text': misc.get_disk_io_read_info(x), 'fill': 255, 'font': font['11']},
            {'xy': (0, 21), 'text': misc.get_disk_io_write_info(x), 'fill': 255, 'font': font['11']}
        start_key = start_key + 1
    return pages
def put_interface_info(pages_len):
    pages = {}
    interfaces = misc.get_interface_list()
    for x in interfaces:
            {'xy': (0, -2), 'text': 'Network (' + x + '):', 'fill': 255, 'font': font['11']},
            {'xy': (0, 10), 'text': misc.get_interface_rx_info(x), 'fill': 255, 'font': font['11']},
            {'xy': (0, 21), 'text': misc.get_interface_tx_info(x), 'fill': 255, 'font': font['11']}
    return pages
def gen_pages():
    pages = {
        0: [
            {'xy': (0, -2), 'text': misc.get_info('up'), 'fill': 255, 'font': font['11']},
            {'xy': (0, 10), 'text': misc.get_cpu_temp(), 'fill': 255, 'font': font['11']},
            {'xy': (0, 21), 'text': misc.get_info('ip'), 'fill': 255, 'font': font['11']}
        1: [
            {'xy': (0, 2), 'text': misc.get_info('cpu'), 'fill': 255, 'font': font['12']},
            {'xy': (0, 18), 'text': misc.get_info('men'), 'fill': 255, 'font': font['12']}
        2: put_disk_info()
    pages.update(put_interface_info(len(pages)))
    pages.update(put_disk_io_info(len(pages)))
    return pages
def slider(lock):
    with lock:
        for item in misc.slider_next(gen_pages()):
            draw.text(**item)
        disp_show()
def auto_slider(lock):
    while misc.conf['slider']['auto']:
        slider(lock)
        misc.slider_sleep()
    else:
        slider(lock)
4.0. After the edit, reboot your rpi (sudo reboot).
5.0. Notes:
I tested it on “Linux raspberry-pi-4 5.4.83-v7l+ #1379 SMP Mon Dec 14 13:11:54 GMT 2020 armv7l GNU/Linux” with HUN language.
Eg. in Hungarian the system in decimal fraction use , (comma) for separation instead of . (dot).
As I see, nothing else is different, but please try it with your own risk!
I changed some texts on the OLED display (eg. “Goodbye ~” text to “Exiting…”).
You have to write it back in the oled.py file if you want.
Sorry for my English, if you have any question or idea what I can add to extra function, please ask/tell me.
Nice. Let’s merge it :smiley:
Thank you! I think @setq has to check this and do the merge.
Fantastic. This will bring us comfort about the dire construction of the sata hat…
Thank you! Please try it and share your experiences and feedback with me/us! :blush:
I took a look in the other topics and improved the uptime display and now you can see the fan speed in percentage.
You have to do everything like in the first post.
The difference is only in 3.3 and 3.4 steps (the improved code).
import re
import os
import sys
import time
import subprocess
cmds = {
    #'up': "echo Uptime: `uptime | sed 's/.*up \\([^,]*\\), .*/\\1/'`",
    'up': "echo Up: $(uptime -p | sed 's/ years,/y/g;s/ year,/y/g;s/ months,/m/g;s/ month,/m/g;s/ weeks,/w/g;s/ week,/w/g;s/ days,/d/g;s/ day,/d/g;s/ hours,/h/g;s/ hour,/h/g;s/ minutes/m/g;s/ minute/m/g' | cut -d ' ' -f2-)",
    try:
        print(ex)
def disk_turn_on():
    #blk1 = get_blk()
    time.sleep(0.5)
    wait_blk(10)
    #blk2 = get_blk()
    time.sleep(0.5)
    t = 0
    while t <= t1:
        try:
        except Exception:
            time.sleep(0.1)
            t += 0.1
            continue
        else:
            time.sleep(0.5)
            break
def get_blk():
def get_info(s):
def get_cpu_temp():
    else:
    return temp
def read_conf():
    try:
        # fan
        # key
        # time
        # other
        # disk
    except Exception:
        # fan
        # key
        # time
        # other
        # disk
    return conf
    s = ''
    while True:
            if p.match(s):
                return t
        time.sleep(0.1)
    pattern = {
    while True:
    interfaces = []
    for x in list:
    interfaces.sort()
    return interfaces
    return output
    return output
    if "sd" in disk:
        disk = disk[:-1]
    return disk
    disks = []
        if output != '':
    #if len(disks) < 3:
    disks.sort()
    return disks
    return output
    return output
        info = {}
def slider_sleep():
def fan_temp2dc(t):
            return dc
    return 0
def fan_switch():
def get_func(key):
def open_w1_i2c():
        content = f.read()
        open_w1_i2c()
#!/usr/bin/python3
import time
import misc
import fan
font = {
time.sleep(0.2)
def disp_init():
    return disp
try:
    disp = disp_init()
except Exception:
    misc.open_w1_i2c()
    time.sleep(0.2)
    disp = disp_init()
def disp_show():
    disp.image(im)
    disp.display()
def welcome():
    disp_show()
def goodbye():
    draw.text((30, 8), 'Power off...', font=font['14'], fill=255)
    disp_show()
    time.sleep(2)
    disp_show()  # clear
    if len(k) == 5:
        page = [
    elif len(k) == 4:
        page = [
    elif len(k) == 3:
        page = [
    elif len(k) == 2:
        page = [
    else:
    return page
    pages = {}
    for x in disks:
    return pages
    pages = {}
    return pages
def gen_pages():
    pages = {
        0: [
        1: [
            #{'xy': (0, 2), 'text': misc.get_info('cpu'), 'fill': 255, 'font': font['12']},
            #{'xy': (0, 18), 'text': misc.get_info('men'), 'fill': 255, 'font': font['12']}
            {'xy': (0, -2), 'text': 'Fan speed: ' + str(fan.get_dc()) + '%', 'fill': 255, 'font': font['11']},
            {'xy': (0, 10), 'text': misc.get_info('cpu'), 'fill': 255, 'font': font['11']},
            {'xy': (0, 21), 'text': misc.get_info('men'), 'fill': 255, 'font': font['11']},
        2: put_disk_info()
    return pages
def slider(lock):
    with lock:
            draw.text(**item)
        disp_show()
        slider(lock)
        misc.slider_sleep()
    else:
        slider(lock)
Nice addition RayMondDrakon! I couldn’t find a pull request for this on github. Did you create one already or do you need help creating one? Would be cool to see this added to the standard installer
Thank you @frantic!
I have not created a pull request yet.
But now you motivated me to further develop this code. Now it’s more user friendly:
  • Disk space usage and disk I/O usage is separated.
  • You can select manually via mount points which disks should display space usage.
  • You can select manually via mount points which disks should display the I/O usage, or you can disable this feature.
  • You can select manually which network interface usage should display, or you can let the program to choose automatically by the link status of interface (UP is selected) or you can disable this feature.
1.0 Updated rockpi-sata.conf example:
[fan]
lv0 = 35
lv1 = 40
lv2 = 45
lv3 = 50
[key]
# reboot, poweroff
click = slider
twice = switch
press = poweroff
[time]
twice = 0.7
press = 1.8
[slider]
auto = true
time = 10
[oled]
rotate = true
f-temp = false
[disk]
# Mount points for disks to show space usage (separated with |)
space_usage_mnt_points = /mnt/raid1|/mnt/torrent|/mnt/torrent2
# Mount points for disks to show I/O usage (separated with |)
# Leave it blank (after the =) if you don't want to use it
io_usage_mnt_points =
[network]
# Name of the interfaces which should be measured (separated with |)
# Option 'auto' means select them automatically by their link status (every interface which link status is UP)
interfaces =
1.1. In this config file we can see the following:
I wanted to display disks space usage which are mounted to:
/mnt/raid1
/mnt/torrent
/mnt/torrent2
I only want to display one disk I/O usage which is mounted to:
/mnt/raid1
And I don’t want to display any network activity.
1.2 More disk I/O usage examples:
To display two disks I/O usage which are mounted to /mnt/torrent and /mnt/torrent2:
io_usage_mnt_points = /mnt/torrent|/mnt/torrent2
To disable this feature:
1.3 More interface examples:
To display them automatically by their status:
interfaces = auto
To display only wlan0:
interfaces = wlan0
To display eth0 and wlan0:
interfaces = eth0|wlan0
interfaces =
2.0. Updated misc.py:
import re
import os
import sys
import time
import subprocess
cmds = {
    try:
        print(ex)
def disk_turn_on():
    #blk1 = get_blk()
    time.sleep(0.5)
    wait_blk(10)
    #blk2 = get_blk()
    time.sleep(0.5)
    t = 0
    while t <= t1:
        try:
        except Exception:
            time.sleep(0.1)
            t += 0.1
            continue
        else:
            time.sleep(0.5)
            break
def get_blk():
def get_info(s):
def get_cpu_temp():
    else:
    return temp
def read_conf():
    try:
        # fan
        # key
        # time
        # other
        # disk
        conf['disk']['space_usage_mnt_points'] = cfg.get('disk', 'space_usage_mnt_points').split('|')
        conf['disk']['io_usage_mnt_points'] = cfg.get('disk', 'io_usage_mnt_points').split('|')
        # network
        conf['network']['interfaces'] = cfg.get('network', 'interfaces').split('|')
    except Exception:
        # fan
        # key
        # time
        # other
        # disk
        conf['disk']['space_usage_mnt_points'] = []
        conf['disk']['io_usage_mnt_points'] = []
        # network
        conf['network']['interfaces'] = []
    return conf
    s = ''
    while True:
            if p.match(s):
                return t
        time.sleep(0.1)
    pattern = {
    while True:
    if len(conf['network']['interfaces']) == 1 and conf['network']['interfaces'][0] == '':
        return []
    if len(conf['network']['interfaces']) == 1 and conf['network']['interfaces'][0] == 'auto':
        interfaces = []
        for x in list:
        interfaces.sort()
    else:
        interfaces = conf['network']['interfaces']
    return interfaces
    return output
    return output
    if "sd" in disk:
        disk = disk[:-1]
    return disk
def get_disk_list(type):
    if len(conf['disk'][type]) == 1 and conf['disk'][type][0] == '':
        return []
    disks = []
    for x in conf['disk'][type]:
        if output != '':
    disks.sort()
    return disks
    return output
    return output
        info = {}
        conf['disk']['disks'] = get_disk_list('space_usage_mnt_points')
def slider_sleep():
def fan_temp2dc(t):
            return dc
    return 0
def fan_switch():
def get_func(key):
def open_w1_i2c():
        content = f.read()
        open_w1_i2c()
3.0. Updated oled.py:
#!/usr/bin/python3
import time
import misc
import fan
font = {
time.sleep(0.2)
def disp_init():
    return disp
try:
    disp = disp_init()
except Exception:
    misc.open_w1_i2c()
    time.sleep(0.2)
    disp = disp_init()
def disp_show():
    disp.image(im)
    disp.display()
def welcome():
    disp_show()
def goodbye():
    disp_show()
    time.sleep(2)
    disp_show()  # clear
    if len(k) == 5:
        page = [
    elif len(k) == 4:
        page = [
    elif len(k) == 3:
        page = [
    elif len(k) == 2:
        page = [
    else:
    return page
    pages = {}
    page_index = pages_len
    disks = misc.get_disk_list('io_usage_mnt_points')
    for x in disks:
        pages[page_index] = [
        page_index = page_index + 1
    return pages
    pages = {}
    return pages
def gen_pages():
    pages = {
        0: [
        1: [
        2: put_disk_info()
    return pages
def slider(lock):
    with lock:
            draw.text(**item)
        disp_show()
        slider(lock)
        misc.slider_sleep()
    else:
        slider(lock)
I hope I could make it more user friendly for everyone who wants to bring out more from this NAS kit.
@frantic let me know what do you think about these modifications (and try them out ^-^)!
Nice Job!
The disc IO is a nice addition.
I think it’s really cool. maybe setq will consider including this so that less enthusiast people who don’t browse the forum can use it as well.
Great. Thank you for your work.
Thank you and welcome back over there!
Should I have to send a pull request or will you implement these functions and fiyes on your own way?
Do you need a list what are the fixes or the new functions?
Hi RayMondDrakon,
I saw your message in jack, thank you for remembering.
If it is convenient, please send me a PR and I will update it to the installation script in the near future.
Hi setq,
Okay I created one if I did everything right.
My mounted hard drive is in /media, and I can’t display the speed of the drive according to your configuration above.
In addition, I found that switching the screen display information with the key does not work anymore.
Looking forward to your answer!
47
It’s seems you don’t have any partition on your disks?
You should see sda1 and sdb1 in df output.
Or did you mount the whole disk, not only a partition (is it possible)?
The code didn’t prepare to that, I fixed it, thanks for your reply!
About the switching key: It works, but is has a delay (sometimes really big), because of to take a speed measure, it should wait 1 sec, and this cause delay in the button press detection. Still, I don’t know how can I fix this issue.
misc.py:
import re
import os
import sys
import time
import subprocess
cmds = {
    try:
        print(ex)
def disk_turn_on():
    #blk1 = get_blk()
    time.sleep(0.5)
    wait_blk(10)
    #blk2 = get_blk()
    time.sleep(0.5)
    t = 0
    while t <= t1:
        try:
        except Exception:
            time.sleep(0.1)
            t += 0.1
            continue
        else:
            time.sleep(0.5)
            break
def get_blk():
def get_info(s):
def get_cpu_temp():
    else:
    return temp
def read_conf():
    try:
        # fan
        # key
        # time
        # other
        # disk
        # network
    except Exception:
        # fan
        # key
        # time
        # other
        # disk
        # network
    return conf
    s = ''
    while True:
            if p.match(s):
                return t
        time.sleep(0.1)
    pattern = {
    while True:
        return []
        interfaces = []
        for x in list:
        interfaces.sort()
    else:
    return interfaces
    return output
    return output
    if "sd" in disk and any(char.isdigit() for char in disk):
        disk = disk[:-1]
    return disk
        return []
    disks = []
        if output != '':
    disks.sort()
    return disks
    return output
    return output
        info = {}
def slider_sleep():
def fan_temp2dc(t):
            return dc
    return 0
def fan_switch():
def get_func(key):
def open_w1_i2c():
        content = f.read()
        open_w1_i2c()
I didn’t partition, I didn’t build a raid, I used the whole hard drive, I have 2 hard drives.
Thank you very much for your answer, I will test it.
Don’t you have any partition on your disk?
I think at least you have to be one existing partition.
Let me know is it working or not.
In fact, I formatted the entire drive in ext4. According to the latest mirsc.py you provided, the drive transfer speed is now displayed.
There are 2 known problems:
  1. the button still doesn’t work, it’s not a latency problem, I think it’s a conflict between conf and misc.py or with oled.py, the button can’t switch to the next item, but pressing and holding the button can shut down or reboot.
  2. oled screen information such as network information - hard drive transfer speed, etc. can not be updated in real time, you need to switch all the information a back and forth before there will be an update.
Do you have these problems there?
I am glad it worked!
  1. It’s working for me. If you replaced your:
  • rockpi-sata.conf
  • oled.py
  • misc.py
    It should work.
  1. I am not sure what are you thinking.
    Before you can see the info, the program take two measures:
    2.1. Check the read bytes on that disk
    2.2. Wait a second
    2.3. And check it again.
    The delta will be the speed in bytes, so it does a little conversion into MB.
    It’s real time info, but this cause delays on the auto scroll and button press detection.
I have replaced the 3 files rockpi-sata.conf oled.py misc.py, after I repeatedly tested, I found that if the io_usage_mnt_points in rockpi-sata.conf is not filled, then all functions are normal.
If io_usage_mnt_points is filled in, the button is disabled and the page cannot be switched.
