Hello
How to completely disable the Wi-Fi module on the X4? Is there an option in the BIOS for this?
I don’t use a wireless connection, so the module unnecessarily draws power. Also, I would like to disconnect the antennas and I want to be sure that the module won’t get damaged that way.
Hello friend, BIOS can not disable wifi module. you can try to disable wifi in OS.
You can disconnect the antennas from the module, search the instruction from internet, just be careful
I know how to physically detach the antennas, but my concern is if active module without antennas won’t get damaged.
I know that this is a dead topic, but … how feasible is desoldering the module, and then soldering on an m.2 interface in its place?
Only that PCIe3X2 interface is suddenly SUPER attractive now that RTL8127 exists.
