Hello Friends!
We are developing with a Radxa Zero v1.51 D2EH-T. We are using the following GPIO pins for LED control:
- 490, GPIOA_14
- 491, GPIOA_15
- 412, GPIOAO_0
The problem is that in the first bootloader stage (pre U-Boot, SPL) is causing this LEDs to blink. Probably the output via UART is causing them to blink.
Is it possible to suppress this output? What changes needs to be made in FIP code?
Corresponding output is:
G12A:BL:0253b8:61aa2d;FEAT:E0F83180:2000;POC:F;RCY:0;EMMC:0;READ:0;CHK:1F;READ:0;0.0
l2_stage_init 0x01
bl2_stage_init 0x81
hw id: 0x0001 - pwm id 0x00
bl2_stage_init 0xc0
bl2_stage_init 0x02
L0:00000000
L1:00000703
L2:00008067
L3:04000000
S1:00000000
B2:00002000
B1:e0f83180
TE: 188984
Board ID = 2
Set cpu clk to 24M
Set clk81 to 24M
CPU clk: 1200 MHz
Set clk81 to 166.6M
eMMC boot @ 1
sw8 s
board id: 2
Load FIP HDR from eMMC, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 1
fw parse done
Load ddrfw from eMMC, src: 0x00060200, des: 0xfffd0000, size: 0x0000c000, part: 1
Load ddrfw from eMMC, src: 0x00038200, des: 0xfffd0000, size: 0x00004000, part: 1
PIEI prepare done
fastboot data load
00000000
emmc switch 2 ok
00000000
emmc switch 0 ok
fastboot data verify
verify result: 265
LPDDR4 probe
ddr clk to 792MHz
Load ddrfw from eMMC, src: 0x0003c200, des: 0xfffd0000, size: 0x0000c000, part: 1
00000000
emmc switch 1 ok
dmc_version 0000
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 792MHz
dmc_version 0000
Check phy result
INFO : End of CA training
INFO : End of initialization
Check phy result
Check phy result
1D training succeed
Load ddrfw from eMMC, src: 0x00048200, des: 0xfffd0000, size: 0x0000c000, part: 1
Check phy result
channel==0
RxClkDly_Margin_A0==236 ps 12
TxDqDly_Margin_A0==256 ps 13
RxClkDly_Margin_A1==0 ps 0
TxDqDly_Margin_A1==0 ps 0
TrainedVREFDQ_A0==74
TrainedVREFDQ_A1==0
VrefDac_Margin_A0==31
DeviceVref_Margin_A0==40
VrefDac_Margin_A1==0
DeviceVref_Margin_A1==0
channel==1
TrainedVREFDQ_A0==75
TrainedVREFDQ_A1==0
VrefDac_Margin_A0==32
DeviceVref_Margin_A0==39
soc_vref_reg_value 0x 0000001b 0000001c 0000001a 00000019 0000001a 0000001b 00000019 0000001a 0000001a 0000001b 0000001b 0000001d 0000001c 0000001a 0000001a 0000001c 0000001b 0000001b 00000c
2D training succeed
auto size-- 65535DDR cs0 size: 2048MB
DDR cs1 size: 0MB
DMC_DDR_CTRL: 00c0002cDDR size: 2048MB
cs0 DataBus test pass
cs0 AddrBus test pass
100bdlr_step_size ps== 460
result report
00000000
emmc switch 3 ok
Authentication key not yet programmed
get rpmb counter error 0x00000007
00000000
emmc switch 1 ok
Load FIP HDR from eMMC, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 1
Load BL3X from eMMC, src: 0x0006c200, des: 0x0175c000, size: 0x000e0000, part: 1
0.0;M3 CHK:0;cm4_sp_mode 0
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x30
ring efuse init
28 0c 30 00 01 19 31 00 00 02 34 37 38 50 4b 50
[0.017150 Inits done]
secure task start!
high task start!
low task start!
run into bl31
NOTICE: BL31: v1.3(release):4fc40b1
NOTICE: BL31: Built : 15:57:33, May 22 2019
NOTICE: BL31: G12A normal boot!
U-Boot output is already disabled.
Thank you in advance!
