I am experiencing some DDR training problems and I suspect it’s one RAM chip that’s affected because of some tests I did. I would like to modify the DDR training blob using ddrbin_tool and boot_merger tools, but have no idea which settings to set to be able to do ddr training for a particular channel or chip. The one that should be disabled is CH2. If there is a hardware solution to disable the channel, I am also open to that. I am not interested in replacing the IC, because one channel is enough for me to continue my tests.
the logs for current ddr training:
`DDR 9fa84341ce typ 24/09/06-09:51:11,fwver: v1.18
ch0 ttot10
ch0 ttot10
ch1 ttot10
ch2 ttot10
ch3 ttot10
ch0 ttot16
LPDDR4, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
ch1 ttot16
channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
ch3 ttot16
channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
Manufacturer ID:0xff
ch:2 dq0 fail,write:0x1,read:0x2
ch:2 dq1 fail,write:0x2,read:0x4
ch:2 dq2 fail,write:0x4,read:0x8
ch:2 dq3 fail,write:0x8,read:0x10
ch:2 dq4 fail,write:0x10,read:0x20
ch:2 dq5 fail,write:0x20,read:0x0
ch:2 dq6 fail,write:0x40,read:0x80
ch:2 dq7 fail,write:0x80,read:0x0
ch:2 dq8 fail,write:0x100,read:0x200
ch:2 dq9 fail,write:0x200,read:0x400
ch:2 dq10 fail,write:0x400,read:0x800
ch:2 dq11 fail,write:0x800,read:0x1000
ch:2 dq12 fail,write:0x1000,read:0x2000
ch:2 dq13 fail,write:0x2000,read:0x4000
ch:2 dq14 fail,write:0x4000,read:0x8000
ch:2 dq15 fail,write:0x8000,read:0x0
ch:2 dq0 fail,write:0xfffffffe,read:0xffbfffbd
ch:2 dq1 fail,write:0xfffffffd,read:0xffbfffbb
ch:2 dq2 fail,write:0xfffffffb,read:0xffbfffb7
ch:2 dq3 fail,write:0xfffffff7,read:0xffbfffaf
ch:2 dq4 fail,write:0xffffffef,read:0xffbfff9f
ch:2 dq5 fail,write:0xffffffdf,read:0xffbfffbf
ch:2 dq6 fail,write:0xffffffbf,read:0xffbfff3f
ch:2 dq7 fail,write:0xffffff7f,read:0x0
ch:2 dq8 fail,write:0xfffffeff,read:0xffbffdbf
ch:2 dq9 fail,write:0xfffffdff,read:0xffbffbbf
ch:2 dq10 fail,write:0xfffffbff,read:0xffbff7bf
ch:2 dq11 fail,write:0xfffff7ff,read:0xffbfefbf
ch:2 dq12 fail,write:0xffffefff,read:0xffbfdfbf
ch:2 dq13 fail,write:0xffffdfff,read:0xffbfbfbf
ch:2 dq14 fail,write:0xffffbfff,read:0xffbf7fbf
ch:2 dq15 fail,write:0xffff7fff,read:0x0
error
ERR`
Any insight is appreciated.
Thanks.
Update: It is possible to mask other DRAM banks using channel mask parameter from the DDR training blob.
Get rkbin tools and binaries from rockchip repo
Extract the parameter files from the DDR loader using ddrbin_tool (manual is in the repo)
Edit the mask for the desired channel (the one to be used) (i.e., channel mask = 1 for ch0)
Generate the modified one using ddrbin_tool.
Build the SPL loader with the modified DDR loader using bootmerger tool.
Next is to modify u-boot and change the maximum allowed SDRAM, found in
"include/configs/rk3588_common.h":SDRAM_MAX_SIZE, I set it toSDRAM_MAX_SIZE = 0x3c000000; -
Build u-boot and flash as (in maskrom):
`rkdeveloptool db modifed_spl_loader_masked_channel.bin
rkdeveloptool wl 64 idbloader.img && rkdeveloptool wl 16384 u-boot.itbPreSerial: 2, raw, 0xfeb50000 This is DRAM: 958 MiB Sysmem: init Relocation Offset: 39a1e000 Relocation fdt: 379f9140 - 379fecb0 CR: M/C/I Bad memblk0: 0x3c000000 - 0xff140000 Using default environment Hotkey: ctrl+ mmc@fe2c0000: 1, mmc@fe2e0000: 0 Bootdev(atags): mmc 0 MMC0: HS200, 200Mhz PartType: EFI DM: v2 No misc partition boot mode: normal FIT: No boot partition No resource partition No resource partition Failed to load DTB, ret=-19 No find valid DTB, ret=-22 Failed to get kernel dtb, ret=-22 In: serial Out: serial Err: serial
I get only 1GB detected instead of 4GB, so it may just be me who messed up something along the way, but I am glad I brought back my board from the dead. I will update once more if I figure it out.
This setup can also workaround boards with DRAM chips of different sizes.
