I need multiple IP-addresses. They have to be fetched from a router using dhcp.
I tried to accomplish this using the RockPiS board running armbian legacy / latest and debian buster.
If i create a single new interface with eg:
ip link add name veth0 address 06:4e:a6:27:01:17 link eth0 type macvlan
and run a dhclient after this no address will be assigned
Creating two interfaces with
ip link add name veth1 address 06:4e:a6:27:01:18 link eth0 type macvlan
and running an dhclient after this will bind a new IP on both interfaces.
The same happens using dhcpcd instead if isc-dhclient.
If i run a tcpdump (to switch the interface in promiscouse mode) it works on a single veth0 too.
Running tcpdump -p (to prevent promiscouse mode) will end like the first try – no ip assigned.
Could this be a driver issue? Sure the “solution” is create more the on veth but im still interressted in the cause of this.
I tried it with the latest armbian trunk from to night too.
Welcome to Armbian 20.11.0-trunk.41 Buster with Linux 5.9.10-rockchip64
uname -a
Linux rockpi-s 5.9.10-rockchip64 #trunk.39 SMP PREEMPT Sun Nov 22 10:36:59 CET 2020 aarch64 GNU/Linux
I bought an usb device to verify this.
As soon as i start dhclient the interface will be set into promiscouse mode.
Deleting the veth will bring it back to normal.
[ 4487.937423] ax88179_178a 2-1.1:1.0 eth1: register ‘ax88179_178a’ at usb-ff440000.usb-1.1, ASIX AX88179 USB 3.0 Gigabit Ethernet, 00:0a:cd:37:50:e4
[ 4487.965043] ax88179_178a 2-1.1:1.0 enx000acd3750e4: renamed from eth1
root@rockpis:~# ip link add name veth1 address 06:4e:a6:27:02:27 link enx000acd3750e4 type macvlan
root@rockpis:~# dhclient
