Debug Rock5b/rk3588 with SWD/JTAG
Has someone managed to connect a hardware debugger to SWD/JTAG (2 pins: TMS/TCK) on a rock5b rk3588 with openocd? I have been struggling to set this up properly, My openocd always fails to establish a connection to the target.
I connected JTAG_TCK_M0 to Pin 9 on a Arm JTag-20 connector, JTAG_TMS_M0 to Pin 7. And VSS to ground. I am using an sdcard adapter breakout to expose the pins [0].
force_tag is enabled (default), gpio4_d2_sel is 0x1, gpio4_d3_sel is 0x1 (default).
Despite this, i fail to make any connection to the device. The device is in uboot bl33 boot menu when i connect the probe.
Some more context:
Hardware Debugger: Olimex ARM-USB-TINY-H
Openocd configuration as a starting point: target based of rk3328:## Rock-Chip RK3328#adapter_khz 4000transport - Pastebin.com
[0] https://www.aliexpress.us/item/1005006267829221.html?spm=a2g0o.order_list.order_list_main.149.3b5d5c5fWln5Pd&gatewayAdapt=4itemAdapt
TRM: rk3588-TRM-and-Datasheet/Rockchip RK3588 TRM V1.0-Part1-20220309.pdf at master · FanX-Tek/rk3588-TRM-and-Datasheet · GitHub
Thank you for your reply.
Booting the board into maskrom mode does not change the connection issue.
I am still receiving: Error connecting DP: cannot read IDR.
This would make me conclude that there must be a physical connection issue, if you manage to receive a connection from maskrom mode.
  1. (Detour) What version of openocd do you use? In the latest version there is no -ctibase option in target create.
For bug reports, read
	http://openocd.org/doc/doxygen/bugs.html
Info : FTDI SWD mode enabled
DEPRECATED! use 'adapter speed' not 'adapter_khz'
Warn : Transport "swd" was already selected
./rk3328.cfg:16: Error: Unknown param: -ctibase, try one of: -type, -event, -work-area-virt, -work-area-phys, -work-area-size, -work-area-backup, -endian, -coreid, -chain-position, -dbgbase, -rtos, -defer-examine, -gdb-port, or -gdb-max-connections
in procedure 'script'
at file "embedded:startup.tcl", line 28
at file "./rk3328.cfg", line 16
maskrom mode:
sudo rkdeveloptool ld
DevNo=1 Vid=0x2207,Pid=0x350b,LocationID=104 Maskrom
openocd connection issue:
sudo openocd -f ./olimex-arm-usb-tiny-h2.cfg -f ./rk3328.cfg
Open On-Chip Debugger 0.12.0-01004-g9ea7f3d64 (2024-12-27-21:22)
Licensed under GNU GPL v2
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : clock speed 4000 kHz
Error: Error connecting DP: cannot read IDR
target.cfg:
# Rock-Chip RK3328
adapter_khz 4000
transport select swd
set _CHIPNAME rk3328
set _TARGETNAME $_CHIPNAME.cpu
set _ENDIAN little
swd newdap $_CHIPNAME cpu none
dap create $_CHIPNAME.dap -chain-position $_CHIPNAME.cpu
target create ${_TARGETNAME}0 cortex_a -dap $_CHIPNAME.dap \
    -coreid 0 -dbgbase 0x81040000
#  -ctibase 0x81014000
target smp ${_TARGETNAME}0
${_TARGETNAME}0 configure -event reset-assert-post "cortex_a dbginit"
debugger.cfg:
# SPDX-License-Identifier: GPL-2.0-or-later
# Olimex ARM-USB-TINY-H
# http://www.olimex.com/dev/arm-usb-tiny-h.html
adapter driver ftdi
ftdi device_desc "Olimex OpenOCD JTAG ARM-USB-TINY-H"
ftdi vid_pid 0x15ba 0x002a
ftdi layout_init 0x0808 0x0a1b
ftdi layout_signal nSRST -oe 0x0200
ftdi layout_signal nTRST -data 0x0100 -oe 0x0100
ftdi layout_signal LED -data 0x0800
# Map FTDI GPIO pins for SWD
ftdi layout_signal SWCLK -data 0x0100 -oe 0x0100
ftdi layout_signal SWDIO -data 0x0200 -oe 0x0200
ftdi layout_signal SWD_EN -data 0x0000 -oe 0x0000
lsusb:
Bus 001 Device 005: ID 15ba:002a Olimex Ltd. ARM-USB-TINY-H JTAG interface
dmsg:
[190208.771978] usb 1-6: new high-speed USB device number 5 using xhci_hcd
[190208.903042] usb 1-6: New USB device found, idVendor=15ba, idProduct=002a, bcdDevice= 7.00
[190208.903054] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[190208.903064] usb 1-6: Product: Olimex OpenOCD JTAG ARM-USB-TINY-H
[190208.903068] usb 1-6: SerialNumber: OL44653F
[190208.912563] ftdi_sio 1-6:1.1: FTDI USB Serial Device converter detected
[190208.912644] usb 1-6: Detected FT2232H
[190208.912846] usb 1-6: FTDI USB Serial Device converter now attached to ttyUSB0
  1. For the wiring. I currently do not have a multi meter. But it is only 3 pins I am connecting.
Let me walk you through my steps, maybe you have some idea what I forgot.
  • Sdcard Pin1: Data2 → SDMMC_D2/JTAG_TCK_M0 → TTCK on jtag connector → Pin 9
  • Sdcard Pin2: CD/Data3 → SDMMC_D3/JTAG_TMS_M0 → TTMS on jtag connector → Pin 7
  • Connect GPIO ground pin on board with any ground pin on the JTAG connector
Do you have some ideas? Or perhaps a working configuration for your setup you can point me to?
Any help is greatly appreciated.
Thanks. After more try and error I figured it out. The issue was the Olimex itself. I managed to connect SWD with an old raspberry pi used as debugger.
Just out of curiosity, have you ever implemented a software based device reset for the rk3588? U-boot supports device reset with the reset command. I think I will look into how to reset the rk3588 using gdb/openocd with a software based reset hook.
Thanks, awesome. Many thanks! If I already have you here, could you also share your sample debug setup/workflow with me for rk3588? I saw you created rk3588-svd. Do you use plain openocd/gdb or another setup? In what setup do you personally debug with the rk3588.svd file?
So far I resorted to printf. But a more advanced debug setup could save me much time.
Great to hear that an RPi can work as a debug tool! I have an RK3588 I’d like to JTAG straight from MaskROM . So I’m curious if you could share your RPi setup and full OpenOCD configuration for the RK3588? I assume the top of the configuration looks something like this?
adapter driver bcm2835gpio
#SWD pins
bcm2835gpio_swd_nums 24 25
#400khz baud
adapter speed 4000
Sorry for my delayed response. the RPi setup is from one of the first google results – openocd supports it out of the box.
 rp3.cfg:
# rpi2.cfg: OpenOCD interface on RPi v2+
# Use RPi GPIO pins
interface bcm2835gpio
# Base address of I/O port
bcm2835gpio_peripheral_base 0x3F000000
# Clock scaling
bcm2835gpio_speed_coeffs 146203 36
# SWD                swclk swdio
# Header pin numbers 22    18
bcm2835gpio_swd_nums 25    24
# JTAG                tck tms tdi tdo
# Header pin numbers  22  18  16  15
bcm2835gpio_jtag_nums 25  24  23  22
