Debian bullseye install libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev
sudo apt install libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev
Reading package lists... Done
Building dependency tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
 libgstreamer-plugins-base1.0-dev : Depends: libgstreamer-plugins-base1.0-0 (= 1.18.4-2+deb11u3) but 1.18.5-1 is to be installed
                                Depends: libgstreamer-gl1.0-0 (= 1.18.4-2+deb11u3) but 1.18.5-1 is to be installed
                                Depends: gir1.2-gst-plugins-base-1.0 (= 1.18.4-2+deb11u3) but 1.18.5-1 is to be installed
 libgstreamer1.0-dev : Depends: libgstreamer1.0-0 (= 1.18.4-2.1+deb11u1) but 1.18.5-1 is to be installed
                   Depends: gir1.2-gstreamer-1.0 (= 1.18.4-2.1+deb11u1) but 1.18.5-1 is to be installed
E: Unable to correct problems, you have held broken packages.
Please help. Its need for build opencv with gstreamer
