Debian 13 missing cix driver gpg key
what to do ?
sh cix-repo-community.sh
$✅ Debian 13 (trixie) detected$
Please select the driver package version to install:
  1. cix-debian13-k6.6.89-driver (Closed-source solution, Linux 6.6)
  2. cix-debian13-k7.0-driver-opensource (Open-source solution, Linux 7.0)
  3. cix-debian13-k6.6.89-driver-full (Full closed-source solution, Linux 6.6)
  4. Uninstall CIX packages and configuration
Enter your choice [1-4, default 2]: 1
:right_arrow: Downloading and installing GPG key
curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: curl - SSL CA Certificates
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the webpage mentioned above.
gpg: Keine gültigen OpenPGP-Daten gefunden.
$❌ Failed to download or install GPG key from https://archive.cixtech.com/ppa-gpg-public-key.asc$
Have the same here. Is an issue with the certificate (checked with www.ssl.org) It will not affect websites, but causes issues with curl and apt
I know it is a cerfiticate issue.
It it up to Radxa to resolve it.
If they put it into their documentation wrong, they have to correct it.
It worked month ago.
But Radxa is strange.
Well it is NOT Radxa responsible for that repo, but cixtech :slight_smile:
I submitted a ticke: Certificate issue for archive.cixtech.com · Issue #53 · cixtech/cix-linux-main · GitHub
Thanks.
But Radxa is responsible for their documentation!
It’s working again
