Hi
Was removing the heatsink with some improper tools when the tool slipped and i ripped of a component.
Anyone have a suggestion what component it is and what values?
This is a user error, but would like to try to fix it instead of throwing away the board.
@laban2k It’s a zero ohm resistance like the other one near to it, try searching for “0 ohm SMD” on eletronic’s store where you live, sadly I can’t help you with other specs like dimensions because I’m not an expert, maybe someone else can chime in.
It should cost literally cents, it shouldn’t be too difficult to resolder for someone with a bit of experience.
thanks for the reply and info.
But if it´s simply a 0ohm resistor cant i just bridge the points?
@laban2k
In theory, yes.
Anyway I took a look at the schematics out of curiosity, it’s a 0 ohm resistor and the size code is 0805 or R0805 which is 2mm long and 1.2mm wide. It should be easy to find a replacement.
