Cubie A7Z: IMX219 responds with correct chip ID (0x0219) but driver rejects sensor ("chip found is not target chip")
Board :
  1. Board: Radxa Cubie A7Z (A733)
  2. OS: Debian 11
  3. Kernel:
    5.15.147-21-a733
  4. Camera:
    Waveshare IMX219 Camera Module (Sony IMX219)
Problem :
The IMX219 sensor is detected on the I²C bus and responds with the correct chip ID (0x0219), but the kernel driver fails during probe and never registers the sensor with the VIN/media framework.
During boot the kernel reports:
sunxi:vin:[INFO]: [VIN_DEV_I2C]imx219 read retry 3, read addr is 0x0
sunxi:vin:[ERR]: [imx219]chip found is not an target chip.
sunxi:vin:[ERR]: registering imx219, No such device!
Evidence collected :
1. IMX219 responds correctly over I²C
sudo i2ctransfer -f -y 3 w2@0x10 0x00 0x00 r1
0x02
sudo i2ctransfer -f -y 3 w2@0x10 0x00 0x01 r1
0x19
Chip ID:
0x0219
which matches Sony IMX219.
Additional registers can also be read successfully:
0x016A = 0x09
0x016B = 0x9F
2. I²C device is reachable
sudo i2cdetect -y -r 3
shows
10
indicating the sensor responds at address 0x10.
3. Device Tree
The running device tree contains:
sensor0_mname = "imx219";
status = "okay";
sensor0_twi_addr = <0x20>;
sensor0_twi_cci_id = <3>;
4. Driver exists
imx219.ko
is present in
/lib/modules/5.15.147-21-a733/...
5. VIN framework initializes
/dev/video0
/dev/video1
/dev/media0
exist.
6. Media graph
The media graph contains CSI/ISP/Scaler nodes but no IMX219 sensor entity.
7. Driver binding
The driver does not remain bound after probe.
readlink -f /sys/bus/i2c/devices/3-0010/driver
returns nothing.
Question :
Since the sensor reports the correct Sony IMX219 chip ID (0x0219), why does the A733 BSP reject it with:
Is this:
  • a known BSP bug?
  • incorrect reset/MCLK sequencing?
  • an issue with the IMX219 driver in kernel 5.15.147-21-a733?
  • or is a different device tree/overlay required for the Waveshare IMX219 module?
Not sure if this is helpful and this post is kind of old, but I tried to configure a pi v2 camera (IMX219) with the A7Z. While I eventually got it work, I had to configure everything manually and it still looked bad, so I bought Radxa’s own version of the IMX219 and all the problems went away. I guess it’s pre calibrated for their own camera.
