Cubie A7S delivered without MIPI CSI connector latch (actuator missing): part number?
My new Cubie A7S arrived with the 31-pin 0.3 mm MIPI CSI connector missing its flip actuator. The contact fingers are directly visible at the rear of the connector body, and there is nothing to close (photo attached). The docs describe this connector as “flip type, bottom contact” and say the latch must be fully closed.
Without the latch, the FPC is held only by friction. With a 15-to-31-pin cable and 2-lane Sony sensors (IMX327, IMX477), the link drops as soon as the cable moves: debugfs mpp/mipi then shows clk_lane or data_lane errors, and no frames arrive.
I use the A7S as an astronomy camera computer with several interchangeable sensors (IMX327/462, IMX477, IMX585/678/662), for planetary imaging, live stacking and all-sky timelapse. Cameras are swapped regularly and the setup sits on a telescope mount outdoors, so a connector that cannot be locked is a real problem.
Questions:
I have also contacted support / the seller (ALI) about a replacement. Is that the right way to go?
Hi, you can seek customer service help at the official flagship store.
