Hi all,
I’ve spent the last few months getting full GPU acceleration on the Cubie A7A (PowerVR BXM-4-64, BVNC 36.56.104.183) under Fedora 44 KDE on Wayland. I’ve published the result as an image (https://github.com/Rabs9/radxa-a7a-fedora44), and I’m sharing what I found on both drivers, in the hope we can put together the pieces for a fully open-source stack.
1. Imagination’s closed driver (Radxa’s DDK 24.2@6603887)
What it gives:
OpenGL ES 3.2, and Vulkan 1.3.
No desktop OpenGL and no GLX.
The EGL and Vulkan libraries are built for X11 only, with no Wayland window system.
What I did to run a Wayland desktop on it:
Two fixes to the
pvrsrvkmkernel module: an fdinfo NULL guard, and a dma-buf mapping for importers. Without the second one, the display engine’s IOMMU domain got corrupted. -
A Wayland build of the DDK’s Mesa layer, with a lenient EGL config choice.
With those, KWin, Plasma and Qt run on the GPU: a GL test window went from 283 to 2010 fps. Firefox gets hardware WebRender and WebGL 2.0, and SuperTuxKart runs natively at about 30 fps.
Still missing, and only a DDK licensee can build them:
libGL_PVR_MESA.so(desktop OpenGL), -
a Wayland-capable
libVK_IMG.so, -
a fix for
vkcube --wsi xcbcrashing inwsi_common_get_images.
Asked in radxa-pkg/allwinner-prebuilt-extra#24.
2. The open driver (drm/imagination and Mesa’s PowerVR driver)
What it took on the A7A:
The kernel side: I back-ported
drm/imaginationfrom Linux 6.16 into Radxa’s 6.6 kernel, and fixed a recovery bug that wedged the GPU. The GPU is kept powered, because context resets followed runtime power-off. -
The firmware: the A733’s firmware isn’t in linux-firmware yet. The open driver loads the DDK’s own
rgx.fw.36.56.104.183under the upstream namerogue_36.56.104.183_v1.fw, and it runs. -
Mesa 26.1.8’s PowerVR Vulkan driver, with patches for this GPU: scratch-buffer reuse, a render-state cache, a load-op program cache, and a sub-allocator free list.
What works: Vulkan 1.2 with Wayland windows, Wayland and X11 programs on the GPU with no configuration, and KWin composited on the GPU.
What’s missing:
OpenGL comes only through zink: OpenGL 2.1 and OpenGL ES 2.0, and slow.
Compared with the DDK’s Vulkan, the open driver lacks 74 features, 51 extensions and 71 formats.
3. The next pieces for a fully open stack
From a gap report comparing the two drivers on this board (a7a-gpu-gap report, included in the image):
OpenGL ES 3.0 and OpenGL 3.0 are blocked by one feature: Vulkan transform feedback (
VK_EXT_transform_feedback). The hardware has it: the DDK’s GLES 3.0 proves it. That single feature would unlock the GTK 4 GL renderer, Firefox WebRender and WebGL 2, Chromium/Electron, and SuperTuxKart’s modern renderer, all on open drivers. -
OpenGL 3.3 then needs: dual-source blending, the 10-bit vertex formats, and timestamp queries.
The A733’s firmware (
rogue_36.56.104.183_v1.fw) needs to be in linux-firmware, so distributions can ship the open driver as is.
Questions for anyone who can help:
Is anyone else working on the A7A’s GPU, with either driver? I’d gladly compare notes.
Does anyone know whether A733 DDK builds with Wayland or desktop GL are planned?
Is anyone working on transform feedback in Mesa’s PowerVR driver? I can test patches on real A7A hardware and report back.
Does anyone know how GPU firmware gets into linux-firmware for a new chip, Allwinner or Imagination?
If you have an A7A, a7a-gpu-check and a7a-gpu-gap report in the image show where your board stands; I’d love to see results from other boards.
Thanks to Radxa for the board and the BSP,
Rabs9
