Hi!
I’m trying to setup a Cubie A5E with Display 8 HD and optional HDMI Output. I’m using the official images radxa-cubie-a5e_bullseye_kde_b1.output_512.img and radxa-cubie-a5e_bullseye_kde_r3.output_512.img. With HDMI they are working fine. To setup the Display 8 HD support I’m using rsetup and reboot the system.
After reboot the display stays black. At least the backlight was not working. Taking a look at Xorg.0.log I can see that the display is detected:
[ 18.196] (II) modeset(0): Printing probed modes for output DSI-1
[ 18.196] (II) modeset(0): Modeline "800x1280"x62.4 70.00 800 818 836 854 1280 1300 1304 1314 (82.0 kHz eP)
The HDMI display show a logon screen. The Display 8 HD touchscreen seems to work. The mouse cursor moves out of sight when I touch the display.
After logging on I can see the KDE plasma starting screen and then ist also stays black and I get the following output on the console:
[ 790.103179] L2 PageTable Invalid
[ 790.106812] 0x0x00000000fc979000 is not mapped!
[ 790.111891] Bug is in DE module, invalid address: 0xfc979000, data:0x0, id:0x20
[ 790.120069] exception record !!!
[ 790.123838] — SUNXI DRM DEBUG —
[ 790.127939] DE-0 exception pos: 266
[ 790.131864] [00] 265 ts 789630215501 plane 0 line 0 format 0x34325258 2720x1280 10880-0-0 0-0-0 0x00000000fc000000 map:0 unmap-ts:789732561417
[ 790.146157] [01] 266 ts 789680901001 plane 0 line 0 format 0x34325258 2720x1280 10880-0-0 0-0-0 0x00000000fd000000 map:0 unmap-ts:789784722626
[ 791.028935] [62] 263 ts 789526342751 plane 0 line 0 format 0x34325258 2720x1280 10880-0-0 0-0-0 0x00000000fd000000 map:0 unmap-ts:789630354626
[ 791.043204] [63] 264 ts 789578131126 plane 0 line 0 format 0x34325258 2720x1280 10880-0-0 0-0-0 0x00000000fa000000 map:0 unmap-ts:789992793376
[ 791.057719] DE-1 exception pos: 267
[ 791.061625] [00] 265 ts 789578338792 plane 0 line 0 format 0x34325258 2720x1280 10880-0-0 0-0-0 0x00000000fa000000 map:0 unmap-ts:789992794376
[ 791.075976] [01] 266 ts 789630285376 plane 0 line 0 format 0x34325258 2720x1280 10880-0-0 0-0-0 0x00000000fc000000 map:0 unmap-ts:789732570542
[ 791.963353] [62] 263 ts 789474323792 plane 0 line 0 format 0x34325258 2720x1280 10880-0-0 0-0-0 0x00000000fc000000 map:0 unmap-ts:789578296084
[ 791.977700] [63] 264 ts 789526394917 plane 0 line 0 format 0x34325258 2720x1280 10880-0-0 0-0-0 0x00000000fd000000 map:0 unmap-ts:789630361834
Any Ideas?
