I have a Rock Pi S Hardware Version 13 and using official Debian image from the website.
I am facing an issue with the stability of the system.
Under normal conditions when Ethernet is not connected, Rock Pi S is stable and we don’t encounter any problem. However, after 1-2 minutes of connecting ethernet cable the Linux crashes and board reboots. For 1-2 minutes the ethernet works perfectly.
I have two boards and it happens in both of the Rock Pi S. So it should not be a hardware problem. I can not also figure out what is causing this issue. As it happens randomly whether there is high load on ethernet or board is sitting idle.
After removing ethernet cable, board works perfectly on WiFi. But my application requires ethernet connectivity.
What I have tried so far:
- Tried both Debian and Ubuntu official images
- Tried images with RK3308B-S image but it won’t boot as the hardware is RK3308B
- Tried with different power supplies: 1A - 5V and 2A - 5V issue happens in both power supplies
When the board crashes, the kernel log received from the serial port is given below.
Please provide a solution
[ 1517.335723] Unable to handle kernel paging request at virtual address 746f6e2e746365
[ 1517.336592] pgd = ffffffc0199ab000
[ 1517.336976] [746f6e2e746365] *pgd=0000000000000000, *pud=0000000000000000
[ 1517.337690] Internal error: Oops: 96000004 [#1] PREEMPT SMP
[ 1517.338258] Modules linked in: usb_f_fs libcomposite hci_uart rtl8723ds
[ 1517.338998] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.143-65-rockchip-g58431d38f8f3 #1
[ 1517.339849] Hardware name: Radxa ROCK Pi S (DT)
[ 1517.340325] task: ffffff8008a2c350 task.stack: ffffff8008a20000
[ 1517.340946] PC is at skb_copy_ubufs+0x138/0x25c
[ 1517.341428] LR is at skb_copy_ubufs+0xc4/0x25c
[ 1517.341898] pc : [] lr : [] pstate: 40000145
[ 1517.342669] sp : ffffffc01ff59c40
[ 1517.343031] x29: ffffffc01ff59c40 x28: ffffffc01e50ac40
[ 1517.343601] x27: ffffffc01f2a0400 x26: 0000000000000000
[ 1517.344168] x25: ffffff8008afb740 x24: 0000000002080020
[ 1517.344735] x23: ffffff8008afb000 x22: 6e6e6f6365646b22
[ 1517.345302] x21: ffffff8008aa8e00 x20: 0000000000000000
[ 1517.345867] x19: 0000000000000022 x18: 0000000030d00800
[ 1517.346433] x17: 0000000000000000 x16: 0000000000000000
[ 1517.346999] x15: 0000000000000000 x14: ffffffffffff8300
[ 1517.347565] x13: 00003d08eb17f300 x12: 0000000000017700
[ 1517.348132] x11: 00000000000005ed x10: 7fffffffffffffff
[ 1517.348697] x9 : 0000000000000000 x8 : ffffff80088d1767
[ 1517.349264] x7 : ffffff80088d1240 x6 : ffffff80088d122f
[ 1517.349831] x5 : ffffffc0197b2ac0 x4 : 0000000000000680
[ 1517.350397] x3 : 0000000000000001 x2 : ffffffc0197b3140
[ 1517.350963] x1 : 69746f6e2e746365 x0 : ffffff8008a2c350
[ 1517.351532]
[ 1517.351532] PC: 0xffffff80085794a4:
[ 1517.352086] 94a4 b9006fa4 2a1803e0 97eed356 aa0003fc b9406fa4 f94033a5 b50001e0 b500013a
[ 1517.353043] 94c4 12800160 a94153f3 a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0
[ 1517.353996] 94e4 f9401b53 aa1a03e0 97eee742 aa1303fa 17fffff3 2a0403e2 8b34d042 8b0200a2
[ 1517.354948] 9504 d5384100 b9401003 f9401841 11000463 b9001003 b947f403 11000463 b907f403
[ 1517.355907] 9524 f9400023 911d02e0 d376fc64 f8647800 b4000060 d36ed463 8b031000 f9400384
[ 1517.356862] 9544 f9400003 90002560 927ef463 f9429c05 d376fc80 cb030021 9346fc21 f8607b23
[ 1517.357817] 9564 d374cc21 cb050021 b25a6421 b4000063 d36ed484 8b041063 f9400060 29470843
[ 1517.358772] 9584 927ef400 cb000380 8b030021 9346fc00 d374cc00 cb050000 b25a6400 97f4b028
[ 1517.359729]
[ 1517.359729] LR: 0xffffff8008579430:
[ 1517.360284] 9430 8b000022 38606833 f9401456 6b13029f 5400026b 52800014 6b13029f 54000d0b
[ 1517.361241] 9450 f94002c2 52800001 aa1603e0 d63f0040 b940cf61 51000673 f9406b60 3100067f
[ 1517.362193] 9470 8b010000 54000cc1 39400401 121c7821 39000401 52800000 14000010 b940cf64
[ 1517.363145] 9490 d2800003 f9406b65 aa1503e2 f90033a5 52800001 b9006fa4 2a1803e0 97eed356
[ 1517.364103] 94b0 aa0003fc b9406fa4 f94033a5 b50001e0 b500013a 12800160 a94153f3 a9425bf5
[ 1517.365059] 94d0 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 f9401b53 aa1a03e0 97eee742
[ 1517.366013] 94f0 aa1303fa 17fffff3 2a0403e2 8b34d042 8b0200a2 d5384100 b9401003 f9401841
[ 1517.366965] 9510 11000463 b9001003 b947f403 11000463 b907f403 f9400023 911d02e0 d376fc64
[ 1517.367923]
[ 1517.367923] SP: 0xffffffc01ff59bc0:
[ 1517.368477] 9bc0 65646b22 6e6e6f63 08afb000 ffffff80 02080020 00000000 08afb740 ffffff80
[ 1517.369433] 9be0 00000000 00000000 1f2a0400 ffffffc0 1e50ac40 ffffffc0 1ff59c40 ffffffc0
[ 1517.370386] 9c00 085794b0 ffffff80 1ff59c40 ffffffc0 08579524 ffffff80 40000145 00000000
[ 1517.371338] 9c20 00000000 00000000 08aa7c00 ffffff80 00000000 00000080 00000001 00000000
[ 1517.372291] 9c40 1ff59cb0 ffffffc0 0858a3c0 ffffff80 188a3d00 ffffffc0 1f2a0400 ffffffc0
[ 1517.373248] 9c60 00000608 00000000 18ae0000 ffffffc0 08a29390 ffffff80 08a26db8 ffffff80
[ 1517.374205] 9c80 02080020 00000000 08a26000 ffffff80 00000000 00000000 02080020 00000000
[ 1517.375159] 9ca0 197b2ac0 ffffffc0 00000000 00000680 1ff59d60 ffffffc0 0858ac04 ffffff80
[ 1517.376123]
[ 1517.376123] X0: 0xffffff8008a2c2d0:
[ 1517.376677] c2d0 08a341c0 ffffff80 00000000 00000000 08749f70 ffffff80 effffffe 00000000
[ 1517.377635] c2f0 00008000 00000000 088d4c31 ffffff80 00000000 00000000 08083198 ffffff80
[ 1517.378591] c310 00000000 00000000 00000000 00000000 08174608 ffffff80 00000000 00000000
[ 1517.379548] c330 08a43070 ffffff80 1f8108e8 ffffffc0 088c704f ffffff80 00000000 00000000
[ 1517.380510] c350 00000002 00000000 ffffffff ffffffff 00000103 00000000 00000000 00000000
[ 1517.381463] c370 08a20000 ffffff80 00000002 00200000 00000000 00000000 00000000 00000000
[ 1517.382416] c390 00000001 00000000 00000003 00000000 0004a4ca 00000001 188fc680 ffffffc0
[ 1517.383372] c3b0 00000000 00000001 00000078 00000078 00000078 00000000 08748170 ffffff80
[ 1517.384331]
[ 1517.384331] X2: 0xffffffc0197b30c0:
[ 1517.384886] 30c0 756c6f76 722e656d 65757165 2c227473 65646b22 6e6e6f63 2e746365 2e736d73
[ 1517.385841] 30e0 7373656d 73656761 6b222c22 6f636564 63656e6e 706d2e74 22736972 646b222c
[ 1517.386800] 3100 6e6f6365 7463656e 6e69662e 70796d64 656e6f68 7165722e 74736575 6b222c22
[ 1517.387755] 3120 6f636564 63656e6e 6f6d2e74 70657375 6b2e6461 6f627965 73647261 65746174
[ 1517.388709] 3140 6b222c22 6f636564 63656e6e 6f632e74 6361746e 722e7374 6f707365 5f65736e
[ 1517.389662] 3160 72616376 2c227364 65646b22 6e6e6f63 2e746365 69746f6e 61636966 6e6f6974
[ 1517.390617] 3180 7165722e 74736575 6b222c22 6f636564 63656e6e 6f6d2e74 70657375 652e6461
[ 1517.391572] 31a0 226f6863 646b222c 6e6f6365 7463656e 756f6d2e 61706573 65722e64 73657571
[ 1517.392536]
[ 1517.392536] X5: 0xffffffc0197b2a40:
[ 1517.393090] 2a40 f90013f5 39401260 7100041f 54000b80 7100081f 54000661 f101029f 54000629
[ 1517.394046] 2a60 39401660 52800095 7100041f 54000b40 7100081f 54000561 321c02b5 d2800b00
[ 1517.395000] 2a80 97ffd6d8 aa0003e2 b4001060 a9007c53 121f02a5 f9000854 b9001855 36080555
[ 1517.395955] 2aa0 f1008e9f 54002769 91008266 121c02a4 36201a95 d2800000 d2800001 d503201f
[ 1517.396912] 2ac0 386068c3 91000400 f100101f aa012061 54ffff81 f9001041 f100c69f 540025a9
[ 1517.397869] 2ae0 b842e261 f100ce9f 79405e60 5ac00821 b9002841 5ac00400 12003c01 92403c00
[ 1517.398827] 2b00 ffff0000 ffffffff 85fdf95c 06081007 00080100 01000406 85fdf95c a8c01007
[ 1517.399780] 2b20 00000101 00000000 0201a8c0 00000000 00000000 00000000 00000000 5ebc0000
[ 1517.400738]
[ 1517.400738] X6: 0xffffff80088d11af:
[ 1517.401293] 11ac 000a2e2e 2074754f 6d20666f 726f6d65 31010079 3a475542 64614220 67617020
[ 1517.402251] 11cc 74732065 3a657461 756c2520 73656d20 65676173 75732073 65727070 64657373
[ 1517.403209] 11ec 3101000a 3a475542 64614220 67617020 74732065 20657461 70206e69 65636f72
[ 1517.404166] 120c 25207373 70202073 253a6e66 786c3530 6f6e000a 72657a6e 616d206f 756f6370
[ 1517.405122] 122c 6e00746e 4e2d6e6f 204c4c55 7070616d 00676e69 7a6e6f6e 206f7265 756f635f
[ 1517.406076] 124c 5000746e 5f454741 47414c46 48435f53 5f4b4345 465f5441 20454552 67616c66
[ 1517.407028] 126c 20297328 00746573 65676170 69747320 63206c6c 67726168 74206465 6763206f
[ 1517.407987] 128c 70756f72 6e6f7a00 773e2d65 5f746961 6c626174 202b2065 34010069 00567025
[ 1517.408947] 12ac 73253401 6170203a 61206567 636f6c6c 6f697461 6166206e 72756c69 6f203a65
[ 1517.409910]
[ 1517.409910] X7: 0xffffff80088d11c0:
[ 1517.410463] 11c0 3a475542 64614220 67617020 74732065 3a657461 756c2520 73656d20 65676173
[ 1517.411417] 11e0 75732073 65727070 64657373 3101000a 3a475542 64614220 67617020 74732065
[ 1517.412372] 1200 20657461 70206e69 65636f72 25207373 70202073 253a6e66 786c3530 6f6e000a
[ 1517.413326] 1220 72657a6e 616d206f 756f6370 6e00746e 4e2d6e6f 204c4c55 7070616d 00676e69
[ 1517.414280] 1240 7a6e6f6e 206f7265 756f635f 5000746e 5f454741 47414c46 48435f53 5f4b4345
[ 1517.415233] 1260 465f5441 20454552 67616c66 20297328 00746573 65676170 69747320 63206c6c
[ 1517.416188] 1280 67726168 74206465 6763206f 70756f72 6e6f7a00 773e2d65 5f746961 6c626174
[ 1517.417139] 12a0 202b2065 34010069 00567025 73253401 6170203a 61206567 636f6c6c 6f697461
[ 1517.418100]
[ 1517.418100] X8: 0xffffff80088d16e7:
[ 1517.418655] 16e4 6d63204b 65722d61 76726573 73256465 0a297325 6d340100 665f6e69 5f656572
[ 1517.419612] 1704 7479626b 69207365 6f6e2073 70752074 65746164 6f742064 20642520 61636562
[ 1517.420563] 1724 20657375 72657375 66656420 64656e69 6c617620 25206575 73692064 65727020
[ 1517.421519] 1744 72726566 000a6465 72463601 6e696565 73252067 6d656d20 3a79726f 646c2520
[ 1517.422476] 1764 50000a4b 5f454741 47414c46 48435f53 5f4b4345 505f5441 20504552 67616c66
[ 1517.423427] 1784 74657320 25360100 61682073 74206873 656c6261 746e6520 73656972 6c25203a
[ 1517.424383] 17a4 6f282064 72656472 6425203a 6c25202c 79622075 29736574 6146000a 64656c69
[ 1517.425342] 17c4 206f7420 6f6c6c61 65746163 20732520 68736168 62617420 000a656c 6e4f3701
[ 1517.426297] 17e4 646f6e20 64252065 746f7420 61706c61 3a736567 756c2520 7026000a 74616467
[ 1517.427265]
[ 1517.427265] X14: 0xffffffffffff8280:
[ 1517.427829] 8280 ******** ******** ******** ******** ******** ******** ******** ********
[ 1517.428793] 82a0 ******** ******** ******** ******** ******** ******** ******** ********
[ 1517.429747] 82c0 ******** ******** ******** ******** ******** ******** ******** ********
[ 1517.430704] 82e0 ******** ******** ******** ******** ******** ******** ******** ********
[ 1517.431658] 8300 ******** ******** ******** ******** ******** ******** ******** ********
[ 1517.432611] 8320 ******** ******** ******** ******** ******** ******** ******** ********
[ 1517.433566] 8340 ******** ******** ******** ******** ******** ******** ******** ********
[ 1517.434522] 8360 ******** ******** ******** ******** ******** ******** ******** ********
[ 1517.435492]
[ 1517.435492] X21: 0xffffff8008aa8d80:
[ 1517.436055] 8d80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.437007] 8da0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.437962] 8dc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.438913] 8de0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.439863] 8e00 08aa7c00 ffffff80 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.440818] 8e20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.441772] 8e40 00000001 00000000 00000200 00000000 0001fe00 00000000 0001fe00 00000000
[ 1517.442728] 8e60 00000000 00000000 00030003 00000000 1893be00 ffffffc0 1893be00 ffffffc0
[ 1517.443689]
[ 1517.443689] X23: 0xffffff8008afaf80:
[ 1517.444252] af80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.445204] afa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.446158] afc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.447107] afe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.448060] b000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.449013] b020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.449965] b040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.450918] b060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.451877]
[ 1517.451877] X25: 0xffffff8008afb6c0:
[ 1517.452440] b6c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.453396] b6e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.454348] b700 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.455301] b720 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.456253] b740 1ffff000 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.457206] b760 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.458163] b780 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.459116] b7a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.460078]
[ 1517.460078] X27: 0xffffffc01f2a0380:
[ 1517.460640] 0380 1980c500 ffffffc0 1decc780 ffffffc0 00001000 00000000 00000000 00000000
[ 1517.461594] 03a0 00000002 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.462546] 03c0 00640008 00420050 00000628 00000680 19668bc0 ffffffc0 19668c44 ffffffc0
[ 1517.463499] 03e0 00008c80 00000001 1f2a03e8 ffffffc0 1f2a03e8 ffffffc0 184f8e38 ffffffc0
[ 1517.464455] 0400 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.465411] 0420 18ae0000 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.466365] 0440 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.467321] 0460 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.468280]
[ 1517.468280] X28: 0xffffffc01e50abc0:
[ 1517.468842] abc0 00000000 00000000 00000000 00000000 00000000 00000000 ffffffff 00000000
[ 1517.469794] abe0 00000100 dead0000 00000200 dead0000 00000000 00000000 00000000 00000000
[ 1517.470746] ac00 00000080 00000000 00000000 00000000 191b0d10 ffffffc0 80170000 00000001
[ 1517.471699] ac20 1e689fc0 ffffffc0 0000001c 0000001c 1f803c00 ffffffc0 00000000 00000000
[ 1517.472658] ac40 00000000 00000000 00000000 00000000 00000000 00000000 ffffffff 00000001
[ 1517.473613] ac60 00000100 dead0000 00000200 dead0000 00000000 00000000 00000000 00000000
[ 1517.474566] ac80 00000000 00000000 00000000 00000000 00000000 00000000 ffffff80 00000000
[ 1517.475519] aca0 1e50dea0 ffffffc0 1e504520 ffffffc0 00000001 00000000 00000000 00000000
[ 1517.476479]
[ 1517.476479] X29: 0xffffffc01ff59bc0:
[ 1517.477042] 9bc0 65646b22 6e6e6f63 08afb000 ffffff80 02080020 00000000 08afb740 ffffff80
[ 1517.477999] 9be0 00000000 00000000 1f2a0400 ffffffc0 1e50ac40 ffffffc0 1ff59c40 ffffffc0
[ 1517.478957] 9c00 085794b0 ffffff80 1ff59c40 ffffffc0 08579524 ffffff80 40000145 00000000
[ 1517.479911] 9c20 00000000 00000000 08aa7c00 ffffff80 00000000 00000080 00000001 00000000
[ 1517.480866] 9c40 1ff59cb0 ffffffc0 0858a3c0 ffffff80 188a3d00 ffffffc0 1f2a0400 ffffffc0
[ 1517.481819] 9c60 00000608 00000000 18ae0000 ffffffc0 08a29390 ffffff80 08a26db8 ffffff80
[ 1517.482778] 9c80 02080020 00000000 08a26000 ffffff80 00000000 00000000 02080020 00000000
[ 1517.483733] 9ca0 197b2ac0 ffffffc0 00000000 00000680 1ff59d60 ffffffc0 0858ac04 ffffff80
[ 1517.484684]
[ 1517.484884] Process swapper/0 (pid: 0, stack limit = 0xffffff8008a20000)
[ 1517.485561] Stack: (0xffffffc01ff59c40 to 0xffffff8008a24000)
[ 1517.486141] Call trace:
[ 1517.486432] Exception stack(0xffffffc01ff59a70 to 0xffffffc01ff59ba0)
[ 1517.487086] 9a60: 0000000000000022 0000008000000000
[ 1517.487913] 9a80: ffffffc01ff59c40 ffffff8008579524 ffffffc01ff59b60 ffffff800812e320
[ 1517.488734] 9aa0: 0000000000000022 0000000000000000 ffffff8008aa8e00 0000000002080020
[ 1517.489558] 9ac0: ffffff8008afb000 0000000000000000 ffffff8008afb740 0000000000000000
[ 1517.490380] 9ae0: ffffffc01f2a0400 0000000002080020 ffffffc01ff59b20 ffffff80080c91c8
[ 1517.491203] 9b00: ffffff80088d121e ffffff8008aa7c00 ffffff8008a2c350 69746f6e2e746365
[ 1517.492026] 9b20: ffffffc0197b3140 0000000000000001 0000000000000680 ffffffc0197b2ac0
[ 1517.492849] 9b40: ffffff80088d122f ffffff80088d1240 ffffff80088d1767 0000000000000000
[ 1517.493673] 9b60: 7fffffffffffffff 00000000000005ed 0000000000017700 00003d08eb17f300
[ 1517.494493] 9b80: ffffffffffff8300 0000000000000000 0000000000000000 0000000000000000
[ 1517.495319] [] skb_copy_ubufs+0x138/0x25c
[ 1517.495907] [] __netif_receive_skb_core+0x60c/0x74c
[ 1517.496567] [] __netif_receive_skb+0x5c/0x60
[ 1517.497172] [] netif_receive_skb_internal+0x90/0x94
[ 1517.497832] [] napi_gro_receive+0x68/0x98
[ 1517.498414] [] stmmac_poll+0x574/0x63c
[ 1517.498972] [] net_rx_action+0x144/0x2d4
[ 1517.499546] [] __do_softirq+0x1d0/0x210
[ 1517.500114] [] irq_exit+0x84/0xd0
[ 1517.500633] [] __handle_domain_irq+0x78/0xac
[ 1517.501234] [] gic_handle_irq+0x64/0xa0
[ 1517.501790] Exception stack(0xffffff8008a23da0 to 0xffffff8008a23ed0)
[ 1517.502449] 3da0: 0000000000000000 ffffff8008a2c350 ffffff80084f4cc0 0000000000000020
[ 1517.503273] 3dc0: 00ffffffffffffff 00000008836d8378 000000000001095c 0000000000000000
[ 1517.504094] 3de0: 00000032b5593519 ffffff8008081800 0000000000001000 0000000000000000
[ 1517.504916] 3e00: 0000000034d5d91d 000000401754f000 ffffff8008a2c350 0000000000000000
[ 1517.505739] 3e20: 0000000000000000 0000000000000000 0000000030d00800 0000016147f1c1a6
[ 1517.506561] 3e40: 0000000000000001 ffffffc018aaf200 ffffff8008a8d240 ffffff8008a8d2b8
[ 1517.507385] 3e60: 0000000000000001 000001614791c723 0000000000d32000 000000000093522c
[ 1517.508207] 3e80: 0000000000bc001c ffffff8008a23ed0 ffffff80084d87d4 ffffff8008a23ed0
[ 1517.509032] 3ea0: ffffff80084d87d8 0000000040000145 000001614791c723 0000000000d32000
[ 1517.509848] 3ec0: ffffffffffffffff ffffff80084d87d4
[ 1517.510362] [] el1_irq+0xb4/0x128
[ 1517.510880] [] cpuidle_enter_state+0x118/0x16c
[ 1517.511495] [] cpuidle_enter+0x18/0x20
[ 1517.512053] [] call_cpuidle+0x4c/0x54
[ 1517.512600] [] cpu_startup_entry+0x1f4/0x204
[ 1517.513205] [] rest_init+0x80/0x8c
[ 1517.513730] [] start_kernel+0x428/0x44c
[ 1517.514293] [] __primary_switched+0x30/0x6c
[ 1517.514889] Code: b9001003 b947f403 11000463 b907f403 (f9400023)
[ 1517.515569] —[ end trace 2e7a76a74bcd0093 ]—
[ 1517.525556] Kernel panic - not syncing: Fatal exception in interrupt
[ 1517.526308] CPU3: stopping
[ 1517.526652] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.4.143-65-rockchip-g58431d38f8f3 #1
[ 1517.527615] Hardware name: Radxa ROCK Pi S (DT)
[ 1517.528086] Call trace:
[ 1517.528390] [] dump_backtrace+0x0/0x1c4
[ 1517.528956] [] show_stack+0x14/0x1c
[ 1517.529493] [] dump_stack+0x98/0xc0
[ 1517.530026] [] handle_IPI+0xe8/0x134
[ 1517.530566] [] gic_handle_irq+0x88/0xa0
[ 1517.531124] Exception stack(0xffffffc01f903de0 to 0xffffffc01f903f10)
[ 1517.531783] 3de0: 0000000000000000 ffffffc01f8f2340 ffffff80084f4cc0 0000000000000020
[ 1517.532608] 3e00: 00ffffffffffffff 0000000883b25c78 0000000000010960 0000000000000003
[ 1517.533431] 3e20: 00000032b5593519 ffffff8008081800 0000000000001000 0000000000000000
[ 1517.534256] 3e40: 0000000034d5d91d 0000004017588000 ffffffc01f8f2340 0000000000000000
[ 1517.535078] 3e60: 0000000000000000 0000000000000000 0000000030d00800 00000161534e8343
[ 1517.535902] 3e80: 0000000000000001 ffffffc018aaf800 ffffff8008a8d240 ffffff8008a8d2b8
[ 1517.536725] 3ea0: 0000000000000001 0000016152ad9d8a 0000000000d32000 0000000000935234
[ 1517.537549] 3ec0: 0000000000000000 ffffffc01f903f10 ffffff80084d87d4 ffffffc01f903f10
[ 1517.538374] 3ee0: ffffff80084d87d8 0000000040000145 0000016152ad9d8a 0000000000d32000
[ 1517.539191] 3f00: ffffffffffffffff ffffff80084d87d4
[ 1517.539705] [] el1_irq+0xb4/0x128
[ 1517.540225] [] cpuidle_enter_state+0x118/0x16c
[ 1517.540841] [] cpuidle_enter+0x18/0x20
[ 1517.541398] [] call_cpuidle+0x4c/0x54
[ 1517.541945] [] cpu_startup_entry+0x1f4/0x204
[ 1517.542549] [] secondary_start_kernel+0x1a0/0x1cc
[ 1517.543187] [<0000000000935178>] 0x935178
[ 1517.543615] CPU1: stopping
[ 1517.543949] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G D 4.4.143-65-rockchip-g58431d38f8f3 #1
[ 1517.544914] Hardware name: Radxa ROCK Pi S (DT)
[ 1517.545385] Call trace:
[ 1517.545681] [] dump_backtrace+0x0/0x1c4
[ 1517.546244] [] show_stack+0x14/0x1c
[ 1517.546778] [] dump_stack+0x98/0xc0
[ 1517.547308] [] handle_IPI+0xe8/0x134
[ 1517.547846] [] gic_handle_irq+0x88/0xa0
[ 1517.548404] Exception stack(0xffffffc01f8fbde0 to 0xffffffc01f8fbf10)
[ 1517.549062] bde0: 0000000000000000 ffffffc01f8f0bc0 ffffff80084f4cc0 0000000000000020
[ 1517.549887] be00: 00ffffffffffffff 0000000883b6c178 0000000000010962 0000000000000001
[ 1517.550710] be20: 00000032b5593519 ffffff8008081800 0000000000001000 0000000000000000
[ 1517.551535] be40: 0000000034d5d91d 0000004017562000 ffffffc01f8f0bc0 0000000000000000
[ 1517.552357] be60: 0000000000000000 0000000000000000 0000000030d00800 00000161534ed304
[ 1517.553181] be80: 0000000000000001 ffffffc018aaf400 ffffff8008a8d240 ffffff8008a8d2b8
[ 1517.554004] bea0: 0000000000000001 00000160fb093073 0000000000d32000 0000000000935234
[ 1517.554828] bec0: 0000000000000000 ffffffc01f8fbf10 ffffff80084d87d4 ffffffc01f8fbf10
[ 1517.555652] bee0: ffffff80084d87d8 0000000040000145 00000160fb093073 0000000000d32000
[ 1517.556469] bf00: ffffffffffffffff ffffff80084d87d4
[ 1517.556981] [] el1_irq+0xb4/0x128
[ 1517.557496] [] cpuidle_enter_state+0x118/0x16c
[ 1517.558113] [] cpuidle_enter+0x18/0x20
[ 1517.558668] [] call_cpuidle+0x4c/0x54
[ 1517.559215] [] cpu_startup_entry+0x1f4/0x204
[ 1517.559817] [] secondary_start_kernel+0x1a0/0x1cc
[ 1517.560452] [<0000000000935178>] 0x935178
[ 1517.560881] CPU2: stopping
[ 1517.561212] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 4.4.143-65-rockchip-g58431d38f8f3 #1
[ 1517.562176] Hardware name: Radxa ROCK Pi S (DT)
[ 1517.562646] Call trace:
[ 1517.562944] [] dump_backtrace+0x0/0x1c4
[ 1517.563508] [] show_stack+0x14/0x1c
[ 1517.564041] [] dump_stack+0x98/0xc0
[ 1517.564572] [] handle_IPI+0xe8/0x134
[ 1517.565108] [] gic_handle_irq+0x88/0xa0
[ 1517.565666] Exception stack(0xffffffc01f8ffde0 to 0xffffffc01f8fff10)
[ 1517.566325] fde0: 0000000000000000 ffffffc01f8f1780 ffffff80084f4cc0 0000000000000020
[ 1517.567150] fe00: 00ffffffffffffff 0000000883b6c178 0000000000010962 0000000000000002
[ 1517.567972] fe20: 00000032b5593519 ffffff8008081800 0000000000001000 0000000000000000
[ 1517.568797] fe40: 0000000034d5d91d 0000004017575000 ffffffc01f8f1780 0000000000000000
[ 1517.569619] fe60: 0000000000000000 0000000000000000 0000000030d00800 00000161534f0649
[ 1517.570443] fe80: 0000000000000001 ffffffc018aaf600 ffffff8008a8d240 ffffff8008a8d2b8
[ 1517.571267] fea0: 0000000000000001 0000016152aea395 0000000000d32000 0000000000935234
[ 1517.572090] fec0: 0000000000000000 ffffffc01f8fff10 ffffff80084d87d4 ffffffc01f8fff10
[ 1517.572916] fee0: ffffff80084d87d8 0000000040000145 0000016152aea395 0000000000d32000
[ 1517.573733] ff00: ffffffffffffffff ffffff80084d87d4
[ 1517.574245] [] el1_irq+0xb4/0x128
[ 1517.574760] [] cpuidle_enter_state+0x118/0x16c
[ 1517.575377] [] cpuidle_enter+0x18/0x20
[ 1517.575932] [] call_cpuidle+0x4c/0x54
[ 1517.576479] [] cpu_startup_entry+0x1f4/0x204
[ 1517.577081] [] secondary_start_kernel+0x1a0/0x1cc
[ 1517.577716] [<0000000000935178>] 0x935178
[ 1517.578143] CRU:
[ 1517.578401] 00000000: 00002044 00001481 00000000 00000007 00007f00 00000000 00000000 00000000
[ 1517.579300] 00000020: 00001145 00001446 00000000 00000007 00007f00 00000000 00000000 00000000
[ 1517.580198] 00000040: 00001062 00000442 004dd2f1 00000007 00007f00 00000000 00000000 00000000
[ 1517.581097] 00000060: 0000104b 00000442 00439581 00000007 00007f00 00000000 00000000 00000000
[ 1517.581994] 00000080: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.582892] 000000a0: 00003955 00000000 00000000 00000000 00000064 00ff0001 00000000 00000000
[ 1517.583789] 000000c0: 00000003 00003a98 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.584688] 000000e0: 00000080 00000000 0000030f 00000000 00002044 00001481 00001100 00000000
[ 1517.585588] 00000100: 00001100 00000040 00000200 0040b71b 00007510 00000006 00000c0c 00000d0d
[ 1517.586485] 00000120: 00000007 00000000 00008000 0000000b 00000000 0000000f 0000000b 00000000
[ 1517.587384] 00000140: 0000000f 0000000b 00000000 0000000f 0000000b 00000000 00006013 0000000b
[ 1517.588281] 00000160: 0755a19a 00000005 00000005 00000005 00000005 0000000b 0000000b 0000000b
[ 1517.589179] 00000180: 0000000b 000001df 00000017 0000001b 00000006 00000c0c 0000000d 0000000c
[ 1517.590078] 000001a0: 0000000c 00000377 0000000d 00008019 00000b1d 00000b0b 0000000f 00000000
[ 1517.590975] 000001c0: 0000000f 00000000 00000003 00000000 00000111 00000000 00000013 00000000
[ 1517.591875] 000001e0: 00000111 00000000 00000013 00000000 00000111 00000000 00000013 00000000
[ 1517.592772] 00000200: 00000111 00000000 00000013 00000000 00000013 00000000 00000013 00000000
[ 1517.593671] 00000220: 00000031 0000001f 0000000b 0000000b 00000000 00000000 00000000 00000000
[ 1517.594568] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.595465] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.596362] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.597260] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.598157] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.599054] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.599954] 00000300: 00000010 0000a9f0 0000e9bb 0000f99d 00000091 0000b98c 0000f47f 00000401
[ 1517.600851] 00000320: 0000b020 00000440 0000fdb8 00002fff 0000fff2 0000000f 000007be 0000000f
[ 1517.601750] 00000340: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.602646] 00000360: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.603543] 00000380: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.604440] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.605337] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.606235] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.607130] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.608029] 00000420: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.608925] 00000440: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.609822] 00000460: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.610720] 00000480: 00000004 00000000 00000004 00000000 00000004 00000000 00000000 00000000
[ 1517.611617] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.612514] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.613411] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.614286] Kernel Offset: disabled
[ 1517.614662] Memory Limit: none
[ 1517.615020] rockchip-thermal ff1f0000.tsadc: channal 1: temperature(40 C)
[ 1517.615696] THERMAL REGS:
[ 1517.616018] 00000000: 00000200 00030133 00000302 00000001 00000000 00000000 00000000 00000000
[ 1517.616915] 00000020: 000001c3 000001c9 00000000 00000000 00000000 000001e5 00000000 00000000
[ 1517.617812] 00000040: 00000293 00000293 00000000 00000000 00000000 00000000 00000000 00000000
[ 1517.618709] 00000060: 00000004 00000004 000000fa 00000032 00000000 00000000 00000000 00000000
[ 1517.619592] 00000080: 00000000 00000000
[ 1517.662781] Rebooting in 10 seconds..
