Cpuidle enable or disable on Orion O6
  • Environment
   Debian12
  • Cpuidle power states
# Power states State Description
1 RUN Working CPU is in running state
2 STANDBY WFI CPU enters WFI, clock is in gating state
3 OFF Poweroff CPU is in off state, no clock and power
  • DTS CONFIG
dete cpu-idle-states in cpuX node:
CPU0: cpu0@0 {
        cpu-idle-states = <&CPU_SLEEP_0 &CLUSTER_SLEEP_0>;
  • Control CPU idle function via cmdline in grub
  1. disable cpuidle: cpuidle.off=1
  2. enable cpuidle: cpuidle.off=0 or delete it
  • User Space Interface
#/sys/devices/system/cpu/cpuX/cpuidle/stateX
root@cix-localhost:/sys/devices/system/cpu/cpu0/cpuidle/state0# ls
above  default_status  disable  name   rejected   time
below  desc            latency  power  residency  usage
- name, name;
- desc, more detailed description;
- disable, reading and setting of cpuidle enable state;
- latency, the time required to exit this state, in us;
- power, power consumption in this state, in mW;
- time, total time spent in this state, in us
- usage, number of times this state was entered.
#/sys/devices/system/cpu/cpuidle# ls
available_governors  current_driver  current_governor  current_governor_ro
@hong.guo Do you mean enable? Can you clarify this?
I have some dumb questions:
  • cpu10 and cpu11 never gets idle state ?
/sys/devices/system/cpu/cpu0/cpuidle/:
driver  state0  state1  state2
/sys/devices/system/cpu/cpu1/cpuidle/:
/sys/devices/system/cpu/cpu2/cpuidle/:
/sys/devices/system/cpu/cpu3/cpuidle/:
/sys/devices/system/cpu/cpu4/cpuidle/:
/sys/devices/system/cpu/cpu5/cpuidle/:
/sys/devices/system/cpu/cpu6/cpuidle/:
/sys/devices/system/cpu/cpu7/cpuidle/:
/sys/devices/system/cpu/cpu8/cpuidle/:
/sys/devices/system/cpu/cpu9/cpuidle/:
DTS
	cpu0@0 {
		compatible = "arm,armv8";
		reg = <0x00 0x00>;
		device_type = "cpu";
		enable-method = "psci";
		clocks = <0x0e 0x02>;
		#cooling-cells = <0x02>;
		cpu-idle-states = <0x0f 0x10>;
		capacity-dmips-mhz = <0x193>;
		phandle = <0x02>;
	cpu1@100 {
		reg = <0x00 0x100>;
		phandle = <0x03>;
	cpu2@200 {
		reg = <0x00 0x200>;
		phandle = <0x04>;
	cpu3@300 {
		reg = <0x00 0x300>;
		phandle = <0x05>;
	cpu4@400 {
		reg = <0x00 0x400>;
		clocks = <0x0e 0x05>;
		cpu-idle-states = <0x11 0x10>;
		capacity-dmips-mhz = <0x400>;
		phandle = <0x06>;
	cpu5@500 {
		reg = <0x00 0x500>;
		phandle = <0x07>;
	cpu6@600 {
		reg = <0x00 0x600>;
		clocks = <0x0e 0x06>;
		phandle = <0x08>;
	cpu7@700 {
		reg = <0x00 0x700>;
		phandle = <0x09>;
	cpu8@800 {
		reg = <0x00 0x800>;
		clocks = <0x0e 0x03>;
		phandle = <0x0a>;
	cpu9@900 {
		reg = <0x00 0x900>;
		phandle = <0x0b>;
	cpu10@a00 {
		reg = <0x00 0xa00>;
		clocks = <0x0e 0x04>;
		phandle = <0x0c>;
	cpu11@b00 {
		reg = <0x00 0xb00>;
		phandle = <0x0d>;
I want to write a small cpufreq + cpu temp monitor , so a little understanding would be helpful.
Sorry,Updated already!
plese help to :
/# cat /sys/devices/system/cpu/online
0-11
this is our platform:
/# ls /sys/devices/system/cpu/cpu*/cpuidle
/sys/devices/system/cpu/cpu0/cpuidle:
/sys/devices/system/cpu/cpu10/cpuidle:
/sys/devices/system/cpu/cpu11/cpuidle:
/sys/devices/system/cpu/cpu1/cpuidle:
/sys/devices/system/cpu/cpu2/cpuidle:
/sys/devices/system/cpu/cpu3/cpuidle:
/sys/devices/system/cpu/cpu4/cpuidle:
/sys/devices/system/cpu/cpu5/cpuidle:
/sys/devices/system/cpu/cpu6/cpuidle:
/sys/devices/system/cpu/cpu7/cpuidle:
/sys/devices/system/cpu/cpu8/cpuidle:
/sys/devices/system/cpu/cpu9/cpuidle:
