Hi, was anyone able to figure out the PWM fan control on the board? I am running Armbian 24.5.1 Bookworm with Linux 6.1.75-vendor-rk35xx and so far I was not able to find any way how to configure the CPU fan.
Sometimes the fan keeps at 100% after a power up but also other times it spins down completely after post and remains off.
In both cases the fan doesn’t seem to be detected. /usr/sbin/pwmconfig: There are no fan-capable sensor modules installed
or
Loading configuration from /etc/fancontrol ...
Error: Can't read configuration file
or
root@rock-5-itx:~$ lshw | grep pwm
root@rock-5-itx:~$ lshw | grep fan
I can confirm this.
On rock5 itx using the method (Guide on how to customize you pwm fan curve) does not work properly.
the lowest set PWM value is used. Values do not change with temperature.
Rock 5 ITX
Armbian 24.5.1 Bookworm with Linux 5.10.160-legacy-rk35xx
