Greetings!
I am working on Rock 3A and using ubuntu 20.04 version on that. I’ve connected POE hat on the board, and installed libmraa and poe dependencies. Restarted the rockpi-poe service. But the issue is the fan continuously running even after changes made on poe config file. I checked the service again and got below mentioned error.
rockpi-poe.service - Rockpi PoE-FAN
Loaded: loaded (/lib/systemd/system/rockpi-poe.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2022-03-23 13:29:36 UTC; 1 months 11 days ago
Main PID: 356 (python3)
Tasks: 1 (limit: 4057)
Memory: 8.4M
CGroup: /system.slice/rockpi-poe.service
└─356 /usr/bin/python3 /usr/bin/rockpi-poe.py start
Mar 23 13:29:37 rock-3a libmraa[356]: pwm0 write_duty: Failed to write to duty_cycle: Invalid argument
Mar 23 13:29:47 rock-3a libmraa[356]: pwm0 write_duty: Failed to write to duty_cycle: Invalid argument
May 04 07:05:47 rock-3a libmraa[356]: pwm0 write_duty: Failed to write to duty_cycle: Invalid argument
May 04 07:08:37 rock-3a libmraa[356]: pwm0 write_duty: Failed to write to duty_cycle: Invalid argument
May 04 07:08:47 rock-3a libmraa[356]: pwm0 write_duty: Failed to write to duty_cycle: Invalid argument
May 04 07:08:57 rock-3a libmraa[356]: pwm0 write_duty: Failed to write to duty_cycle: Invalid argument
May 04 07:09:07 rock-3a libmraa[356]: pwm0 write_duty: Failed to write to duty_cycle: Invalid argument
May 04 07:09:17 rock-3a libmraa[356]: pwm0 write_duty: Failed to write to duty_cycle: Invalid argument
Can you please help me with this issue?
I checked my uEnv.txt file also. I mentioned the overlays, please check whether it is correct or not.
verbosity=7
console=ttyFIQ0
overlay_prefix=rockchip
rootfstype=ext4
fdtfile=rockchip/rk3568-rock-3-a.dtb
overlays=rk3568-fiq-debugger-uart2m0 rk3568-can1-m0 rk3568-pwm8-m0-fan rk3568-pwm15-m0 rk3568-uart7-m1 rk3568-uart5-m1
rootuuid=15ccf394-84f6-4e09-9244-2cfbcb109827
initrdsize=0x88f62f
kernelversion=4.19.193-33-rockchip-g5add69115a1c
initrdimg=initrd.img-4.19.193-33-rockchip-g5add69115a1c
kernelimg=vmlinuz-4.19.193-33-rockchip-g5add69115a1c
Thank you.
