i would also appreciate a configuration utility, i have been unsuccessful in finding a way to autologin to console that would normally be provided by the raspi-config utility
We have created a currently very basic system configuration utility, which will be used for our future system images. Since it made some system level assumptions that is not consistently implemented in our current system image, you are advised against installing it on existing systems. You can find the source code here.
The tool is focused more on our image generation need right now, as we don’t have a real user base for it at this moment.
We also considered to work with Armbian on their new armbian-config replacement to reduce duplicated work. This is not the same one Igor linked above as this one is currently work in progress like our rsetup. We will wait for both tools to mature a bit before deciding what to do.
We just started generating test images for the new build system which include rsetup. You can go to your product’s GitHub release repo, then go to the release page (example) and find the latest pre-release. Download radxa-product_debian_bullseye_kde.img.xz and you can then begin evaluating our new system images.
