I need some more connection ports for my radxa zero.
https://wiki.radxa.com/Rock3/CM3
On this page are some compute modules who works for the Radxa CM3.
Are they also working for the radxa zero or is there another module who works with it?
I think you are having some misunderstanding here. CM stands for Compute Module so there is no compute module that work for CM3. What you are talking about might be base boards / carrier boards listed on the bottom of the page. Those use 100-pin board to board connectors and Zero does not have such capability.
Zero is a complete package, and if you need more IO, you should look for a different product, or extended it via USB devices.
@RadxaYuntian ah sorry. I thought they are used as expansion for more connection ports.
