Compiling error
Hi, i do not understand this compiling error.
Can anyone help
thanks
[ 81%] Built target opencv_perf_stitching
[ 81%] Built target opencv_perf_superres_pch_dephelp
[ 81%] Built target pch_Generate_opencv_perf_superres
[ 81%] Built target opencv_superres_pch_dephelp
[ 81%] Built target pch_Generate_opencv_superres
[ 81%] Processing OpenCL kernels (superres)
Scanning dependencies of target opencv_superres
[ 81%] Building CXX object modules/superres/CMakeFiles/opencv_superres.dir/src/btv_l1.cpp.o
c++: internal compiler error: Segmentation fault signal terminated program cc1plus
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-8/README.Bugs> for instructions.
modules/superres/CMakeFiles/opencv_superres.dir/build.make:67: recipe for target ‘modules/superres/CMakeFiles/opencv_superres.dir/src/btv_l1.cpp.o’ failed
make[2]: *** [modules/superres/CMakeFiles/opencv_superres.dir/src/btv_l1.cpp.o] Error 4
CMakeFiles/Makefile2:24259: recipe for target ‘modules/superres/CMakeFiles/opencv_superres.dir/all’ failed
make[1]: *** [modules/superres/CMakeFiles/opencv_superres.dir/all] Error 2
Makefile:162: recipe for target ‘all’ failed
make: *** [all] Error 2
inst-opencv401.sh: 84: inst-opencv401.sh: Syntax error: word unexpected (expecting “)”)
  • An Older versio show same bug ver 7 of gcc
– Version info
rock@worker-02:~$ gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/aarch64-linux-gnu/8/lto-wrapper
Target: aarch64-linux-gnu
Configured with: …/src/configure -v --with-pkgversion=‘Ubuntu 8.2.0-1ubuntu2~18.04’ --with-bugurl=file:///usr/share/doc/gcc-8/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++ --prefix=/usr --with-gcc-major-version-only --program-suffix=-8 --program-prefix=aarch64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libquadmath --disable-libquadmath-support --enable-plugin --enable-default-pie --with-system-zlib --disable-libphobos --enable-multiarch --enable-fix-cortex-a53-843419 --disable-werror --enable-checking=release --build=aarch64-linux-gnu --host=aarch64-linux-gnu --target=aarch64-linux-gnu
Thread model: posix
gcc version 8.2.0 (Ubuntu 8.2.0-1ubuntu2~18.04)
  • dsik space
rock@worker-02:~$ df -k
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 29704240 18025960 10431160 64% /
devtmpfs 1951344 0 1951344 0% /dev
tmpfs 1951920 0 1951920 0% /dev/shm
tmpfs 1951920 880 1951040 1% /run
tmpfs 5120 0 5120 0% /run/lock
tmpfs 1951920 0 1951920 0% /sys/fs/cgroup
tmpfs 390384 0 390384 0% /run/user/0
tmpfs 390384 16 390368 1% /run/user/1000
[ 2310.417978] systemd[1]: Starting Journal Service…
[ 2343.313058] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 2400.625833] systemd[1]: systemd-journald.service: Start operation timed out. Terminating.
[ 2406.370368] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 2464.774027] systemd-journald[10439]: File /var/log/journal/ff7847b4271046ee959e832ff1bf63b3/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 2469.364915] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 2490.873403] systemd[1]: systemd-journald.service: State ‘stop-sigterm’ timed out. Killing.
[ 2490.873624] systemd[1]: systemd-journald.service: Killing process 10439 (systemd-journal) with signal SIGKILL.
[ 2532.367414] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 2540.071824] systemd[1]: systemd-journald.service: Main process exited, code=killed, status=9/KILL
[ 2540.071961] systemd[1]: systemd-journald.service: Failed with result ‘timeout’.
[ 2540.072417] systemd[1]: Failed to start Journal Service.
[ 2540.073006] systemd[1]: Dependency failed for Flush Journal to Persistent Storage.
[ 2540.073049] systemd[1]: systemd-journal-flush.service: Job systemd-journal-flush.service/start failed with result ‘dependency’.
[ 2540.074169] systemd[1]: systemd-journald.service: Service has no hold-off time, scheduling restart.
[ 2540.074275] systemd[1]: systemd-journald.service: Scheduled restart job, restart counter is at 2.
[ 2540.074453] systemd[1]: Stopped Journal Service.
[ 2540.078074] systemd[1]: Starting Journal Service…
[ 2630.119959] systemd[1]: systemd-journald.service: Start operation timed out. Terminating.
[ 2658.314523] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 2703.089404] systemd-journald[10957]: File /var/log/journal/ff7847b4271046ee959e832ff1bf63b3/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 2720.367819] systemd[1]: systemd-journald.service: State ‘stop-sigterm’ timed out. Killing.
[ 2720.368073] systemd[1]: systemd-journald.service: Killing process 10957 (systemd-journal) with signal SIGKILL.
[ 2721.306505] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 2784.346005] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 2810.760160] systemd[1]: systemd-journald.service: Processes still around after SIGKILL. Ignoring.
[ 2818.101162] systemd[1]: systemd-journald.service: Main process exited, code=killed, status=9/KILL
[ 2818.101192] systemd[1]: systemd-journald.service: Failed with result ‘timeout’.
[ 2818.102405] systemd[1]: Failed to start Journal Service.
[ 2818.111099] systemd[1]: systemd-journald.service: Service has no hold-off time, scheduling restart.
[ 2818.111361] systemd[1]: systemd-journald.service: Scheduled restart job, restart counter is at 3.
[ 2818.118391] systemd[1]: Stopped Journal Service.
[ 2818.126854] systemd[1]: Starting Journal Service…
[ 2826.940007] systemd-journald[11545]: File /var/log/journal/ff7847b4271046ee959e832ff1bf63b3/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 2826.984009] systemd[1]: Started Journal Service.
[ 2847.363041] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 2902.838049] swirl invoked oom-killer: gfp_mask=0x24000c0, order=0, oom_score_adj=0
[ 2902.838064] swirl cpuset=/ mems_allowed=0
[ 2902.838081] CPU: 2 PID: 11149 Comm: swirl Not tainted 4.4.154-ge0ce80a-dirty #6
[ 2902.838086] Hardware name: ROCK PI 4B (DT)
[ 2902.838092] Call trace:
[ 2902.838109] [] dump_backtrace+0x0/0x220
[ 2902.838118] [] show_stack+0x24/0x30
[ 2902.838128] [] dump_stack+0x98/0xc0
[ 2902.838138] [] dump_header.isra.6+0x50/0x15c
[ 2902.838148] [] oom_kill_process+0xcc/0x3d4
[ 2902.838154] [] out_of_memory+0x290/0x2a4
[ 2902.838161] [] __alloc_pages_nodemask+0x6b8/0x710
[ 2902.838172] [] alloc_skb_with_frags+0x124/0x1b0
[ 2902.838179] [] sock_alloc_send_pskb+0x184/0x1d4
[ 2902.838188] [] unix_stream_sendmsg+0x18c/0x2c4
[ 2902.838198] [] sock_sendmsg+0x34/0x4c
[ 2902.838204] [] sock_write_iter+0x84/0xb4
[ 2902.838212] [] do_iter_readv_writev+0x60/0x84
[ 2902.838219] [] do_readv_writev+0xa4/0x1b8
[ 2902.838226] [] vfs_writev+0x4c/0x6c
[ 2902.838233] [] SyS_writev+0x54/0x98
[ 2902.838240] [] el0_svc_naked+0x24/0x28
[ 2902.838244] Mem-Info:
[ 2902.838258] active_anon:923551 inactive_anon:22716 isolated_anon:0
active_file:2641 inactive_file:2749 isolated_file:0
unevictable:8 dirty:16 writeback:2695 unstable:0
slab_reclaimable:7300 slab_unreclaimable:6219
mapped:23177 shmem:22954 pagetables:3666 bounce:0
free:1928 free_pcp:322 free_cma:0
[ 2902.838284] DMA free:7712kB min:7900kB low:9872kB high:11848kB active_anon:3694204kB inactive_anon:90864kB active_file:10564kB inactive_file:10996kB unevictable:32kB isolated(anon):0kB isolated(file):0kB present:4061184kB managed:3903840kB mlocked:32kB dirty:64kB writeback:10780kB mapped:92708kB shmem:91816kB slab_reclaimable:29200kB slab_unreclaimable:24876kB kernel_stack:7456kB pagetables:14664kB unstable:0kB bounce:0kB free_pcp:1288kB local_pcp:576kB free_cma:0kB writeback_tmp:0kB pages_scanned:135060 all_unreclaimable? yes
[ 2902.838288] lowmem_reserve[]: 0 0 0
[ 2902.838297] DMA: 11124kB (UE) 3778kB (UE) 016kB 032kB 064kB 0128kB 0256kB 0512kB 01024kB 02048kB 0*4096kB = 7464kB
[ 2902.838326] 28413 total pagecache pages
[ 2902.838335] 0 pages in swap cache
[ 2902.838339] Swap cache stats: add 0, delete 0, find 0/0
[ 2902.838343] Free swap = 0kB
[ 2902.838346] Total swap = 0kB
[ 2902.838350] 1015296 pages RAM
[ 2902.838354] 0 pages HighMem/MovableOnly
[ 2902.838358] 39336 pages reserved
[ 2902.838362] [ pid ] uid tgid total_vm rss nr_ptes nr_pmds swapents oom_score_adj name
[ 2902.838423] [ 209] 0 209 4022 713 9 4 0 -1000 systemd-udevd
[ 2902.838434] [ 274] 62583 274 20986 213 11 3 0 0 systemd-timesyn
[ 2902.838444] [ 278] 102 278 2670 220 8 3 0 0 systemd-resolve
[ 2902.838453] [ 320] 0 320 57799 307 16 4 0 0 accounts-daemon
[ 2902.838463] [ 321] 110 321 1535 203 7 3 0 0 avahi-daemon
[ 2902.838473] [ 323] 103 323 1908 408 9 3 0 -900 dbus-daemon
[ 2902.838483] [ 326] 110 326 1489 85 7 3 0 0 avahi-daemon
[ 2902.838493] [ 361] 0 361 2316 253 9 4 0 0 wpa_supplicant
[ 2902.838502] [ 363] 0 363 99577 856 28 3 0 0 NetworkManager
[ 2902.838512] [ 364] 0 364 77962 391 20 4 0 0 ModemManager
[ 2902.838522] [ 365] 106 365 54992 375 14 3 0 0 rsyslogd
[ 2902.838531] [ 367] 0 367 24233 2049 16 3 0 0 networkd-dispat
[ 2902.838540] [ 369] 0 369 20086 173 8 4 0 0 irqbalance
[ 2902.838550] [ 370] 0 370 919 121 6 4 0 0 cron
[ 2902.838559] [ 371] 0 371 2628 261 9 4 0 0 systemd-logind
[ 2902.838569] [ 372] 0 372 96659 577 24 3 0 0 udisksd
[ 2902.838578] [ 380] 0 380 58355 760 16 5 0 0 polkitd
[ 2902.838587] [ 442] 0 442 1573 188 8 4 0 0 login
[ 2902.838597] [ 456] 0 456 76199 337 16 4 0 0 lightdm
[ 2902.838606] [ 463] 0 463 640 32 6 3 0 0 agetty
[ 2902.838615] [ 466] 0 466 2602 174 9 3 0 -1000 sshd
[ 2902.838626] [ 512] 0 512 2023 354 10 4 0 0 dhclient
[ 2902.838635] [ 578] 0 578 3087 323 10 3 0 0 systemd
[ 2902.838645] [ 581] 0 581 3799 515 12 4 0 0 (sd-pam)
[ 2902.838654] [ 598] 0 598 1172 392 6 3 0 0 bash
[ 2902.838664] [ 707] 0 707 61108 333 18 3 0 0 upowerd
[ 2902.838674] [ 717] 107 717 38091 104 10 4 0 0 rtkit-daemon
[ 2902.838683] [ 745] 113 745 59628 1328 19 4 0 0 colord
[ 2902.838693] [ 765] 0 765 1777 152 8 4 0 0 bluetoothd
[ 2902.838701] [ 998] 0 998 170623 16633 100 5 0 0 Xorg
[ 2902.838711] [ 1144] 0 1144 39819 316 14 3 0 0 lightdm
[ 2902.838720] [ 1163] 1000 1163 3121 355 10 4 0 0 systemd
[ 2902.838730] [ 1166] 1000 1166 3899 538 12 4 0 0 (sd-pam)
[ 2902.838739] [ 1187] 1000 1187 60726 555 21 5 0 0 lxsession
[ 2902.838749] [ 1202] 1000 1202 1748 244 8 4 0 0 dbus-daemon
[ 2902.838758] [ 1246] 1000 1246 979 110 5 4 0 0 ssh-agent
[ 2902.838768] [ 1261] 1000 1261 58049 293 14 4 0 0 gvfsd
[ 2902.838777] [ 1266] 1000 1266 94255 158 18 3 0 0 gvfsd-fuse
[ 2902.838787] [ 1277] 1000 1277 13474 1003 19 4 0 0 openbox
[ 2902.838796] [ 1280] 1000 1280 42685 298 18 4 0 0 lxpolkit
[ 2902.838806] [ 1282] 1000 1282 196463 2237 42 3 0 0 lxpanel
[ 2902.838815] [ 1283] 1000 1283 99957 1435 29 4 0 0 pcmanfm
[ 2902.838824] [ 1284] 1000 1284 1718 232 8 3 0 0 xscreensaver
[ 2902.838834] [ 1290] 1000 1290 979 74 5 4 0 0 ssh-agent
[ 2902.838844] [ 1292] 1000 1292 76062 232 16 4 0 0 at-spi-bus-laun
[ 2902.838853] [ 1304] 1000 1304 1650 163 7 4 0 0 dbus-daemon
[ 2902.838863] [ 1306] 1000 1306 103381 1790 37 5 0 0 nm-applet
[ 2902.838872] [ 1312] 1000 1312 106693 1435 30 4 0 0 clipit
[ 2902.838882] [ 1349] 1000 1349 63241 1144 26 5 0 0 light-locker
[ 2902.838891] [ 1350] 1000 1350 39806 283 13 3 0 0 at-spi2-registr
[ 2902.838901] [ 1362] 1000 1362 207215 861 22 4 0 0 pulseaudio
[ 2902.838911] [ 1372] 1000 1372 38674 198 11 5 0 0 dconf-service
[ 2902.838920] [ 1378] 1000 1378 38826 194 12 5 0 0 menu-cached
[ 2902.838930] [ 1383] 1000 1383 58195 310 15 4 0 0 gvfs-udisks2-vo
[ 2902.838939] [ 1390] 1000 1390 57686 147 13 4 0 0 gvfs-gphoto2-vo
[ 2902.838949] [ 1396] 1000 1396 57185 116 12 3 0 0 gvfs-mtp-volume
[ 2902.838958] [ 1400] 1000 1400 77254 293 18 4 0 0 gvfs-afc-volume
[ 2902.838967] [ 1405] 1000 1405 57222 216 13 3 0 0 gvfs-goa-volume
[ 2902.838977] [ 1409] 1000 1409 125529 1352 48 4 0 0 goa-daemon
[ 2902.838987] [ 1416] 1000 1416 58387 206 17 3 0 0 goa-identity-se
[ 2902.838996] [ 1422] 1000 1422 76556 216 18 3 0 0 gvfsd-trash
[ 2902.839087] [ 1443] 1000 1443 105544 3956 40 4 0 0 lxterminal
[ 2902.839102] [ 1446] 1000 1446 1185 398 6 3 0 0 bash
[ 2902.839117] [ 1471] 1000 1471 484344 44430 264 5 0 0 firefox
[ 2902.839140] [ 1557] 1000 1557 355543 19353 160 4 0 0 Web Content
[ 2902.839159] [ 1647] 1000 1647 327664 7533 100 4 0 0 WebExtensions
[ 2902.839172] [ 1717] 1000 1717 370098 45367 192 4 0 0 Web Content
[ 2902.839187] [ 1775] 1000 1775 318903 4338 85 4 0 0 Web Content
[ 2902.839212] [ 1834] 1000 1834 1215 413 8 4 0 0 bash
[ 2902.839230] [ 2020] 0 2020 1613 176 7 3 0 0 sudo
[ 2902.839246] [ 2024] 0 2024 478 65 5 4 0 0 sh
[ 2902.839260] [ 2404] 0 2404 67718 513 22 3 0 0 packagekitd
[ 2902.839276] [ 5208] 0 5208 1613 175 8 4 0 0 sudo
[ 2902.839289] [ 5212] 0 5212 735 273 5 4 0 0 make
[ 2902.839305] [ 5215] 0 5215 1312 871 6 3 0 0 make
[ 2902.839318] [11147] 1000 11147 1357 170 7 3 0 0 popsquares
[ 2902.839334] [11149] 1000 11149 3641 2449 11 4 0 0 swirl
[ 2902.839348] [11467] 0 11467 745 294 5 3 0 0 make
[ 2902.839364] [11477] 0 11477 478 17 4 4 0 0 sh
[ 2902.839378] [11478] 0 11478 741 17 4 3 0 0 c++
[ 2902.839391] [11479] 0 11479 207905 201108 410 4 0 0 cc1plus
[ 2902.839400] [11484] 0 11484 478 18 5 3 0 0 sh
[ 2902.839409] [11485] 0 11485 741 18 6 3 0 0 c++
[ 2902.839418] [11486] 0 11486 191095 184769 378 3 0 0 cc1plus
[ 2902.839427] [11508] 0 11508 478 18 4 4 0 0 sh
[ 2902.839437] [11509] 0 11509 741 17 4 3 0 0 c++
[ 2902.839446] [11510] 0 11510 177928 170578 350 4 0 0 cc1plus
[ 2902.839455] [11545] 0 11545 4479 196 12 4 0 0 systemd-journal
[ 2902.839465] [11584] 0 11584 478 17 4 4 0 0 sh
[ 2902.839474] [11585] 0 11585 741 18 5 3 0 0 c++
[ 2902.839483] [11586] 0 11586 89673 82437 177 4 0 0 cc1plus
[ 2902.839491] [11591] 0 11591 478 17 5 4 0 0 sh
[ 2902.839500] [11592] 0 11592 741 17 5 3 0 0 c++
[ 2902.839509] [11593] 0 11593 91349 84591 179 3 0 0 cc1plus
[ 2902.839518] [11599] 0 11599 558 115 5 3 0 0 make
[ 2902.839526] [11608] 0 11608 478 17 5 4 0 0 sh
[ 2902.839535] [11609] 0 11609 741 17 6 3 0 0 c++
[ 2902.839544] [11610] 0 11610 78918 70917 157 3 0 0 cc1plus
[ 2902.839550] Out of memory: Kill process 11479 (cc1plus) score 200 or sacrifice child
[ 2902.840272] Killed process 11479 (cc1plus) total-vm:831620kB, anon-rss:799840kB, file-rss:4592kB
[ 2910.786538] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 2974.832181] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 3038.324692] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 3101.355590] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 3164.335926] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 3227.303593] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 3290.298682] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 3353.334464] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 3416.346432] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 3479.340355] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 3542.327449] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 3605.305219] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 3668.339953] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 3731.292413] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 3794.334041] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 3857.329422] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 3920.286030] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 3983.337777] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 4046.328919] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 4109.316562] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 4172.315838] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 4235.289680] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 4298.319897] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 4424.312794] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 4487.325909] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 4550.287630] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 4613.324151] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 4676.308585] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 4739.264478] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 4802.319813] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 4865.313398] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 4928.310049] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 4991.315161] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 5054.279780] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 5117.260407] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 5180.293321] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 5243.308371] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 5306.292740] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 5369.310165] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 5432.268042] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 5495.304953] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 5558.252717] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 5621.255908] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 5684.300306] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 5747.276317] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 5810.296626] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 5873.288455] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 5936.279579] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 6377.234648] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 6755.293755] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 7070.292710] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 7511.231229] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 7574.291176] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 7826.241537] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 7889.286896] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 7952.270182] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 8015.284957] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 8078.284680] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 8141.252477] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 8204.277785] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 8267.279926] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 8330.277963] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 8393.277342] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 8456.261411] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 8519.275165] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 8582.272492] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 8645.270584] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 8647.632435] BUG: spinlock wrong CPU on CPU#1, dhd_dpc/162
[ 8647.633007] lock: 0xffffffc0ecd580d8, .magic: dead4ead, .owner: dhd_dpc/162, .owner_cpu: 0
[ 8647.633764] CPU: 1 PID: 162 Comm: dhd_dpc Not tainted 4.4.154-ge0ce80a-dirty #6
[ 8647.634416] Hardware name: ROCK PI 4B (DT)
[ 8647.634788] Call trace:
[ 8647.635039] [] dump_backtrace+0x0/0x220
[ 8647.635538] [] show_stack+0x24/0x30
[ 8647.636004] [] dump_stack+0x98/0xc0
[ 8647.636468] [] spin_dump+0x84/0xa4
[ 8647.636930] [] spin_bug+0x30/0x3c
[ 8647.637380] [] do_raw_spin_unlock+0xac/0xd0
[ 8647.637903] [] _raw_spin_unlock_irqrestore+0x24/0x34
[ 8647.638494] [] dhd_rx_frame+0x43c/0x5a4
[ 8647.638992] [] dhdsdio_readframes+0x1320/0x1358
[ 8647.639546] [] dhd_bus_dpc+0x804/0xb34
[ 8647.640029] [] dhd_dpc_thread+0x118/0x16c
[ 8647.640537] [] kthread+0xe0/0xf0
[ 8647.640976] [] ret_from_fork+0x10/0x20
[ 8834.269192] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 9590.256778] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[ 9716.253014] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[10220.189207] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[10472.226637] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[10598.243400] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[10724.226470] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[10787.184510] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[10850.218855] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[10913.239174] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[10976.223576] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[11039.181140] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[11102.232108] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[11165.225648] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[11228.219992] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[11291.232113] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[11354.229924] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[11417.175322] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[11480.224616] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[11543.212708] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[11606.175971] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[11669.215605] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[11732.174833] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[11795.207206] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[11858.210326] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[12110.202765] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[12236.189965] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[13055.151238] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[13118.137479] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[13181.152124] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[13307.121696] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[13370.128820] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[13433.175059] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[13496.157702] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[13559.121723] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[13622.171753] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[13685.123204] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[13748.168639] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[13811.108767] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[13874.131626] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[13937.129919] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[14000.148127] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[14063.113842] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[14126.120069] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[14189.140323] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[14252.143677] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[14315.103939] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[14378.104885] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[14441.128614] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[14504.139824] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[14567.105352] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[14630.103836] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[14693.153520] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[14756.134338] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[15008.132027] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[15260.125263] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[15323.092102] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[30064.875393] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[30127.863856] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[30190.880276] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[30316.824115] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[38569.727720] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[42160.662641] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[42223.653859] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
[42286.630429] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
– dump
