I have Radxa E25 and two different CM3I modules: the first one with SOC RK3568 and WiFi/BT module AP6256, and the second one with SOC RK3568J and AP6745. In the system i have installed firmware packages broadcom-wifibt-firmware_2.6_all.deb and brcm-patchram-plus1_0.2_arm64.deb. But module with AP6745 doen’t initialize correctly (wlan0 doesn’t appear):
dmesg
[ 17.733100] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 17.738081] hantro-vpu fdee0000.video-codec: Adding to iommu group 1
[ 17.750163] hantro-vpu fdee0000.video-codec: registered rockchip,rk3568-vepu-enc as /dev/video2
[ 17.764261] Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 17.860269] brcmfmac: F1 signature read @0x18000000=0x15294345 [ 17.863979] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9
[ 17.876030] usbcore: registered new interface driver brcmfmac
[ 18.060119] Bluetooth: Core ver 2.22
[ 18.064871] NET: Registered PF_BLUETOOTH protocol family
[ 18.073945] Bluetooth: HCI device and connection manager initialized
[ 18.081570] Bluetooth: HCI socket layer initialized
[ 18.087404] Bluetooth: L2CAP socket layer initialized
[ 18.094264] Bluetooth: SCO socket layer initialized
[ 18.596237] EXT4-fs (mmcblk1p4): mounted filesystem e9c5baaa-9370-4427-929e-cd2d3cff97fe r/w with journalled data mode. Quota mode: none.
[ 18.639392] EXT4-fs (mmcblk1p3): mounted filesystem 717e7229-e94f-4556-be27-9c2bf72a69fb r/w with journalled data mode. Quota mode: none.
[ 18.859256] systemd-journald[198]: Received client request to flush runtime journal.
[ 18.901409] systemd-journald[198]: File /var/log/journal/cd1a1d66391a41cc929daf68f88ec148/system.journal corrupted or uncleanly shut down, renaming and replacing. [ 20.125799] brcmfmac: brcmf_sdio_readshared: unable to obtain sdpcm_shared info: rv=-16 (addr=0x0)
[ 20.792969] btsdio: probe of mmc2:0001:3 failed with error -16
[ 22.319534] RTL8226B_RTL8221B 2.5Gbps PHY r8169-0-100:00: attached PHY driver (mii_bus:phy_addr=r8169-0-100:00, irq=MAC)
[ 22.553246] r8169 0000:01:00.0 eth0: Link is Down
[ 22.579261] RTL8226B_RTL8221B 2.5Gbps PHY r8169-2-100:00: attached PHY driver (mii_bus:phy_addr=r8169-2-100:00, irq=MAC)
[ 22.816991] r8169 0002:01:00.0 eth1: Link is Down
[ 25.261343] r8169 0000:01:00.0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 25.365975] 8021q: 802.1Q VLAN Support v1.8
[ 25.707672] r8169 0002:01:00.0 eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[ 27.275099] EXT4-fs (mmcblk1p1): mounted filesystem b4dd55a2-dee1-4ac2-b14e-435cdc875b7c r/w with ordered data mode. Quota mode: none.
[ 27.288814] ext4 filesystem being mounted at /boot supports timestamps until 2038-01-19 (0x7fffffff)
[ 35.820052] vdd_npu: disabling
[ 35.825861] vdda0v9_image: disabling
[ 35.832249] vcca1v8_image: disabling [ 72.511892] brcmfmac: brcmf_sdio_htclk: Failed access turning clock off: -16
My device tree node properties exact as reference from 5.10-gen-rkr4.1 kernel that you provided, except one property ‘supports-sdio’.
With this reference image, wireless interface doesn’t appear in system too. Log from image radxa-e25_debian_bullseye_cli_b21.img.xz:
dmesg | grep mmc
[ 7.587770] dwmmc_rockchip fe000000.dwmmc: IDMAC supports 32-bit address mode.
[ 7.587781] dwmmc_rockchip fe2b0000.dwmmc: IDMAC supports 32-bit address mode.
[ 7.587802] dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller.
[ 7.587805] dwmmc_rockchip fe000000.dwmmc: Using internal DMA controller.
[ 7.587813] dwmmc_rockchip fe000000.dwmmc: Version ID is 270a
[ 7.587816] dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a
[ 7.587874] dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller at irq 59,32 bit host data width,256 deep fifo
[ 7.587893] dwmmc_rockchip fe000000.dwmmc: DW MMC controller at irq 42,32 bit host data width,256 deep fifo
[ 7.587977] dwmmc_rockchip fe2b0000.dwmmc: Looking up vmmc-supply from device tree
[ 7.587980] dwmmc_rockchip fe000000.dwmmc: Looking up vmmc-supply from device tree
[ 7.587998] dwmmc_rockchip fe000000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe000000 failed
[ 7.588031] dwmmc_rockchip fe000000.dwmmc: Looking up vqmmc-supply from device tree
[ 7.588040] dwmmc_rockchip fe000000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe000000 failed
[ 7.588272] dwmmc_rockchip fe2b0000.dwmmc: Looking up vqmmc-supply from device tree
[ 7.588337] dwmmc_rockchip fe000000.dwmmc: allocated mmc-pwrseq
[ 7.588347] mmc_host mmc3: card is non-removable.
[ 7.599412] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 7.599417] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 7.659124] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 7.661077] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 7.663037] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 7.666315] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 7.670035] mmc3: queuing unknown CIS tuple 0x81 (9 bytes)
[ 7.742527] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 7.748486] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 270
[ 7.751319] mmc3: new ultra high speed SDR104 SDIO card at address 0001
[ 8.223758] mmc1: delay init for 600 ms to enable UHS mode
[ 8.271018] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 8.417434] dwmmc_rockchip fe2b0000.dwmmc: Successfully tuned phase to 225
[ 8.417485] mmc1: new ultra high speed SDR104 SDHC card at address 0007
[ 8.419398] mmcblk1: mmc1:0007 SD8GB 7.42 GiB
[ 8.432118] mmcblk1: p1 p2 p3
[ 8.875446] sdhci-dwcmshc fe310000.sdhci: Looking up vmmc-supply from device tree
[ 8.875474] sdhci-dwcmshc fe310000.sdhci: Looking up vmmc-supply property in node /sdhci@fe310000 failed
[ 8.875525] sdhci-dwcmshc fe310000.sdhci: Looking up vqmmc-supply from device tree
[ 8.875535] sdhci-dwcmshc fe310000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe310000 failed
[ 8.905679] mmc0: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA
[ 8.949811] mmc0: Host Software Queue enabled
[ 8.949846] mmc0: new HS200 MMC card at address 0001
[ 8.950846] mmcblk0: mmc0:0001 88A43A 14.6 GiB
[ 8.951192] mmcblk0boot0: mmc0:0001 88A43A partition 1 4.00 MiB
[ 8.951487] mmcblk0boot1: mmc0:0001 88A43A partition 2 4.00 MiB
[ 8.951757] mmcblk0rpmb: mmc0:0001 88A43A partition 3 4.00 MiB, chardev (236:0)
[ 8.955264] mmcblk0: p1 p2 p3 p4
[ 10.346224] EXT4-fs (mmcblk1p3): mounted filesystem with ordered data mode. Opts: (null)
[ 11.306596] mmcblk1: p1 p2 p3
[ 11.650708] EXT4-fs (mmcblk1p3): mounted filesystem with ordered data mode. Opts: (null)
[ 13.910723] EXT4-fs (mmcblk1p3): re-mounted. Opts: (null)
[ 22.289273] FAT-fs (mmcblk1p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 31.232736] EXT4-fs (mmcblk1p3): resizing filesystem from 486717 to 1860603 blocks
[ 33.563820] EXT4-fs (mmcblk1p3): resized filesystem to 1860603
dmesg (last logs)
[ 21.902457] Adding 1015612k swap on /dev/zram0. Priority:100 extents:1 across:1015612k SS
[ 22.090422] rk817-codec rk817-codec: DMA mask not set
[ 22.090503] clk: failed to reparent i2s1_mclkout_tx to clk_i2s1_8ch_tx: -22 [ 22.128837] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9 [ 22.191159] brcmfmac: brcmf_fw_request_firmware: no board-specific nvram available (ret=-2), device will use brcm/brcmfmac43456-sdio.txt
[ 22.389267] Bluetooth: Core ver 2.22
[ 22.389417] NET: Registered protocol family 31
[ 22.389423] Bluetooth: HCI device and connection manager initialized
[ 22.389449] Bluetooth: HCI socket layer initialized
[ 22.389460] Bluetooth: L2CAP socket layer initialized
[ 22.389489] Bluetooth: SCO socket layer initialized
[ 22.440058] Bluetooth: HCI UART driver ver 2.3
[ 22.440080] Bluetooth: HCI UART protocol H4 registered
[ 22.440084] Bluetooth: HCI UART protocol ATH3K registered
[ 22.440230] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 22.440688] Bluetooth: HCI UART protocol Intel registered
[ 22.443244] hci_uart_bcm serial0-0: Looking up vbat-supply from device tree
[ 22.443522] hci_uart_bcm serial0-0: Looking up vddio-supply from device tree
[ 22.444130] Bluetooth: HCI UART protocol Broadcom registered
[ 22.444211] Bluetooth: HCI UART protocol QCA registered
[ 22.562839] of_dma_request_slave_channel: dma-names property of node ‘/serial@fe6c0000’ missing or empty
[ 22.562938] dw-apb-uart fe6c0000.serial: failed to request DMA, use interrupt mode
[ 22.816601] Bluetooth: hci0: BCM: chip id 130
[ 22.817105] Bluetooth: hci0: BCM: features 0x0f
[ 22.819189] Bluetooth: hci0: BCM4345C5
[ 22.819208] Bluetooth: hci0: BCM4345C5 (003.006.006) build 0000
[ 22.822125] Bluetooth: hci0: BCM4345C5 ‘brcm/BCM4345C5.hcd’ Patch
[ 23.852079] Bluetooth: hci0: BCM4345C5 Ampak_CL1 UART 37.4 MHz BT 5.2 [Version: 1039.1086]
[ 23.852108] Bluetooth: hci0: BCM4345C5 (003.006.006) build 1086
[ 23.853022] Bluetooth: hci0: BCM: Using default device address (43:45:c5:00:1f:ac)
[ 24.198606] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 24.198630] Bluetooth: BNEP filters: protocol multicast
[ 24.198666] Bluetooth: BNEP socket layer initialized
[ 24.272723] enP2p33s0: 0xffff80000afb0000, 00:e0:4c:02:07:e6, IRQ 83
[ 24.356691] enp1s0: 0xffff80000a530000, 00:e0:4c:02:07:e5, IRQ 81
[ 27.090431] r8125: enp1s0: link up
[ 27.090536] IPv6: ADDRCONF(NETDEV_CHANGE): enp1s0: link becomes ready
[ 27.539499] ttyFIQ ttyFIQ0: tty_port_close_start: tty->count = 1 port count = 2
[ 33.419532] r8125 0000:01:00.0 enp1s0: rss get rxnfc
[ 33.424145] r8125 0000:01:00.0 enp1s0: rss get rxnfc
[ 40.520762] r8125 0000:01:00.0 enp1s0: rss get rxnfc [ 76.279236] brcmfmac: brcmf_sdio_htclk: Failed access turning clock off: -16
I think firmware doesn’t loading to the module. On CM3I with AP6256 dmesg always have log message about firmware info: brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/9 wl0: Feb 11 2020 11:54:51 version 7.45.96.61 (be7af2d@shgit) (r745790) FWID 01-a41d86bd es7.c5.n4.a3"
If AP6256 works normally but AP6745 does not, you need to check whether the hardware of AP6745 is normal. We tested AP6256 and AP6745 before the release of radxa-e25_debian_bullseye_cli_b21.img.xz and both of them can work normally.
AP6256 and AP6745 use the same driver and firmware
