CM3 I2S 8ch out?
Please are all I2S1_DO0-3 data out lines (i.e. full 8ch) available on any of the CM3 connectors?
Thanks.
Yes, all routed on the 3rd b2b connector:
Thanks, which pins are I2S1_SDO1 and I2S1_SDO3?
IIUC I see:
MCLK (41)
LRCK_TX (26)
SCLK_TX(49)
LRCK_RX (29)
SDO0 (25)
SDO2 (34)
SDI0 (27)
SDI1 (45)
SDI2 (47)
SDI3 (54)
Thanks a lot,
Pavel.
I2S1_SDO1 is muxed with SPI3_MOSI
U13A connector
I2S1_SDO3 is muxed with I2C2_SCL
U13A connector
Jack, thanks a lot. Please can you point me to some docs where the pin muxes are described? Thank you.
Jack, please is complete I2S3 available? I cannot find I2S3_SCLK_xxx in https://wiki.radxa.com/Rock3/CM/CM3/pinout, only LRCLK and DI/DO.
Thanks a lot,
Pavel.
