sebsd
July 4, 2022, 3:09am
1
Hi, using the CM3 with IO board, how do I configure eDP DTS and timing?
Hello, we have brought up Sharp LQ133T1JW01 EDP LCD on Radxa CM3 IO.
This is the dts. Hope it helps you.
// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
* Copyright (c) 2022 Radxa Limited.
compatible = "radxa,radxa-cm3-io", "rockchip,rk3566";
backlight_edp: backlight-edp {
status = "disabled";
compatible = "pwm-backlight";
pwms = <&pwm5 0 25000 0>;
brightness-levels = <
0 20 20 21 21 22 22 23
23 24 24 25 25 26 26 27
27 28 28 29 29 30 30 31
31 32 32 33 33 34 34 35
35 36 36 37 37 38 38 39
40 41 42 43 44 45 46 47
This file has been truncated. show original
sebsd
July 5, 2022, 9:13am
3
Thanks, I have attempted to compile a .dtbo overlay with the appropriate settings changes and included it in the uEnv.txt but cant get it to work, I might will email you the .dtbo and panel datasheet to help troubleshoot.
yaqwsx
September 7, 2022, 6:54am
4
Hi @sebsd . Did you make any progress? I am also trying to setup eDP panel with not much luck so far.
