I’m hoping someone can explain the right way to clone a configures OS on emmc module. I started with the default OS image and have now applied the many changes we need for our project. I initially used a 32GIG emmc but now want to use 64GIG emmc.
I have used clonezilla many times for SD cards and never an issue going small > big. However, with emmc it seems even clonezilla doesn’t work due to a boot EFI file that the backup of the 32GIG image is not getting?
Is the only option to use dd? What is the correct way to burn emmc modules? I need to burn upwards of 50 emmc modules so keen on clonezilla / partimage so the file / burn time is not so long.
Any suggestions as so far I’m bashing my head it seems
I have never used clonezilla but DD or etcher and others which I think use the DD code have no problem with small to big.
You just end up with the smaller partition on a not fully used drive that you then need to resize the partition to the full extent.
So guessing its just clonezilla as it needs to be a complete clone.
Taking your 1st dd clone to a .img and if you google I think you can write to multiple devices at the same time.
What you can do is shrink the file system and then dd to the last block +1 then just resize that so you are only writing out used space.
Trim and then use part or gparted to shrink the partition as small as you can get then
sudo fdisk -l
Disk /dev/sda: 64.0 GB, 64023257088 bytes
255 heads, 63 sectors/track, 7783 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0x0000e4b5
Device Boot Start End Blocks Id System
/dev/sda1 * 1 27 209920 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/sda2 27 525 4000768 5 Extended
Partition 2 does not end on cylinder boundary.
/dev/sda5 27 353 2621440 83 Linux
/dev/sda6 353 405 416768 83 Linux
/dev/sda7 405 490 675840 83 Linux
/dev/sda8 490 525 282624 83 Linux
Yeah your block size bs sector size should be 512 but your count was right.
I think usually is with sd or emmc but fdisk -l is right it was just the example was from a hardrive and not sd or emmc
But before you take an image open up in gparted with ubuntu or a live-usb, resize and pull the partition left so its as small as it can be as much of a DD write is writing blank portions of the disk.
