Cixbuilder noe sdk install failed!
when I install the sdk ,it shows some error :
I just download the file cix_noe_sdk_25_q3_release.tar.gz and unzip it
I get some files like
CixBuilder-6.1.3407.2-cp310-none-linux_x86_64.whl cix-npu-driver_2.0.1_arm64.deb npu_sdk_last_manifest_list.xml
cix-noe-umd_2.0.2_arm64.deb env_setup.sh requirements.txt
and I use bash env_setup.sh to install
it get errors
ERROR: CixBuilder-6.1.3407.2-cp310-none-linux_x86_64.whl is not a supported wheel on this platform.
why I get a x86_64.whl file in the cix_noe_sdk_25_q3_release.tar.gz and how can I install on o6n, is it not a arm platform ?
now I know it should install on a host pc ,not on the board …
so strange
This is only the SDK, which is used to convert models to the NPU/AIPU format. So, it may be installed on a Dev machine (x86_64).
