it might be a noob question;
I’m booting my zero from MicroSD card. But i would like to see / mount internal eMMC of zero. I cant seemed to do it so far.
Can you let me how it can be done ?
Thank you
Thank you
Share the output of this command.
lsblk
Your emmc is already visible.
mmcblk1
is your emmc.
Which OS do you have on emmc?
i dont have any OS on eMMC. I cleared it in windows with “radxa-zero-erase-emmc” then flashed my OS to MicroSD.
I did try to use disk tool to create a partition in Linux, and it did see the eMMC but i cant copy or create anything inside im not sure how that works, because im not a linux expert too…it might be something that i’ve done or i need to do one more step to make it work maybe?
I see then your Post title is incorrect
Please search online on how to mount drive and use it in linux command line. If you use Linux with graphical interface then you can see it.
also you will have to format the emmc partition in some way before you are able to mount and use it.
ok, got it. sorry about that. but thank you for the information.
