You can test with any Linux. My x4 was able to boot and install Windows but I couldn’t install display driver at all. I also tried with Linux and came across to the same issue. It turned out it’s a faulty hardware. It can be the same for you. It’s a shame that availability of the device is very low so you can’t easily replace. Scalpers are buying quicker than end users and selling after clearing the stocks for 3x price or more.
First you need to make sure the board is powered on.
the red LED on the motherboard is on?
the keyboard light is on when the keyboard is plugged in?
the CPU is hot?
It would be better if you can check the input voltage and current.
We are very sorry that the X4 is out of stock due to its good sales. We have just produced a new batch and are now selling it on the official store. The quantity is limited.
Led is on and fan moving
2. Yes, showing in blue
the CPU is hot?
It has the heat sink and the fan… it feels normal
As said previously… power source 12v @ 6 amps, tried official allnetchine power source (2 of them)
Tried all usb ports, 2 different cards too…
Anything else I can try or I got a faulty board from radxa/allnetchina?
