I am looking through xorg logs to better understand the problem. Here’s the latest log I have.
[ 404.874]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 404.874] X Protocol Version 11, Revision 0
[ 404.875] Build Operating System: Linux 4.4.0-148-generic aarch64 Ubuntu
[ 404.875] Current Operating System: Linux linux 4.4.154-95-rockchip-gd2ab1f26e1b3 #1 SMP Mon Oct 21 06:42:35 UTC 2019 aarch64
[ 404.875] Kernel command line: earlyprintk console=ttyFIQ0,1500000n8 rw init=/sbin/init rootfstype=ext4 rootwait root=PARTUUID=B921B045-1DF0-41C3-AF44-4C6F280D3FAE
[ 404.875] Build Date: 03 June 2019 08:11:53AM
[ 404.876] xorg-server 2:1.19.6-1ubuntu4.3 (For technical support please see http://www.ubuntu.com/support)
[ 404.876] Current version of pixman: 0.34.0
[ 404.876] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 404.876] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 404.891] (==) Log file: "/home/rock/.local/share/xorg/Xorg.0.log", Time: Thu Feb 13 12:40:06 2020
[ 404.899] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 404.907] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 404.909] (==) No Layout section. Using the first Screen section.
[ 404.909] (==) No screen section available. Using defaults.
[ 404.909] (**) |-->Screen "Default Screen Section" (0)
[ 404.909] (**) | |-->Monitor "<default monitor>"
[ 404.911] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 404.911] (**) | |-->Device "Allwinner A10/A13 FBDEV"
[ 404.911] (**) | |-->GPUDevice "Rockchip Graphics"
[ 404.911] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 404.912] (==) Automatically adding devices
[ 404.912] (==) Automatically enabling devices
[ 404.912] (==) Automatically adding GPU devices
[ 404.912] (==) Automatically binding GPU devices
[ 404.912] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 404.912] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 404.912] Entry deleted from font path.
[ 404.912] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 404.912] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 404.912] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 404.913] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 404.913] Entry deleted from font path.
[ 404.913] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 404.913] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 404.913] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 404.913] (II) Loader magic: 0x557a466010
[ 404.913] (II) Module ABI versions:
[ 404.913] X.Org ANSI C Emulation: 0.4
[ 404.913] X.Org Video Driver: 23.0
[ 404.913] X.Org XInput driver : 24.1
[ 404.913] X.Org Server Extension : 10.0
[ 404.916] (++) using VT number 1
[ 404.925] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 404.927] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 404.933] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[ 404.934] (II) no primary bus or device found
[ 404.934] falling back to /sys/devices/platform/display-subsystem/drm/card0
[ 404.934] (II) LoadModule: "glx"
[ 404.935] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 404.938] (II) Module glx: vendor="X.Org Foundation"
[ 404.938] compiled for 1.19.6, module version = 1.0.0
[ 404.938] ABI class: X.Org Server Extension, version 10.0
[ 404.938] (II) LoadModule: "fbturbo"
[ 404.938] (WW) Warning, couldn't open module fbturbo
[ 404.939] (II) UnloadModule: "fbturbo"
[ 404.939] (II) Unloading fbturbo
[ 404.939] (EE) Failed to load module "fbturbo" (module does not exist, 0)
[ 404.939] (II) LoadModule: "fbdev"
[ 404.939] (WW) Warning, couldn't open module fbdev
[ 404.939] (II) UnloadModule: "fbdev"
[ 404.939] (II) Unloading fbdev
[ 404.939] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 404.939] (==) Matched modesetting as autoconfigured driver 0
[ 404.939] (==) Matched fbdev as autoconfigured driver 1
[ 404.939] (==) Assigned the driver to the xf86ConfigLayout
[ 404.939] (II) LoadModule: "modesetting"
[ 404.939] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 404.940] (II) Module modesetting: vendor="X.Org Foundation"
[ 404.940] compiled for 1.19.6, module version = 1.19.6
[ 404.941] Module class: X.Org Video Driver
[ 404.941] ABI class: X.Org Video Driver, version 23.0
[ 404.941] (II) LoadModule: "fbdev"
[ 404.942] (WW) Warning, couldn't open module fbdev
[ 404.942] (II) UnloadModule: "fbdev"
[ 404.942] (II) Unloading fbdev
[ 404.942] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 404.942] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 404.942] (II) modeset(0): using drv /dev/dri/card0
[ 404.943] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 404.943] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 404.943] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 404.943] (==) modeset(0): RGB weight 888
[ 404.943] (==) modeset(0): Default visual is TrueColor
[ 404.943] (II) Loading sub module "glamoregl"
[ 404.943] (II) LoadModule: "glamoregl"
[ 404.944] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 404.965] (II) Module glamoregl: vendor="X.Org Foundation"
[ 404.965] compiled for 1.19.6, module version = 1.0.0
[ 404.965] ABI class: X.Org ANSI C Emulation, version 0.4
[ 404.965] (II) glamor: OpenGL accelerated X.org driver based.
[ 405.505] (II) glamor: EGL version 1.4:
[ 405.506] EGL_MESA_drm_image required.
[ 405.507] (EE) modeset(0): glamor initialization failed
[ 405.507] (II) modeset(0): ShadowFB: preferred NO, enabled NO
[ 405.636] (II) modeset(0): Output HDMI-1 has no monitor section
[ 405.766] (II) modeset(0): EDID for output HDMI-1
[ 405.766] (II) modeset(0): Manufacturer: ACR Model: 82 Serial#: 2441206962
[ 405.767] (II) modeset(0): Year: 2009 Week: 18
[ 405.768] (II) modeset(0): EDID Version: 1.3
[ 405.768] (II) modeset(0): Digital Display Input
[ 405.769] (II) modeset(0): Max Image Size [cm]: horiz.: 48 vert.: 27
[ 405.769] (II) modeset(0): Gamma: 2.20
[ 405.769] (II) modeset(0): DPMS capabilities: Off
[ 405.770] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 405.770] (II) modeset(0): Default color space is primary color space
[ 405.770] (II) modeset(0): First detailed timing is preferred mode
[ 405.770] (II) modeset(0): redX: 0.644 redY: 0.348 greenX: 0.286 greenY: 0.603
[ 405.770] (II) modeset(0): blueX: 0.143 blueY: 0.070 whiteX: 0.313 whiteY: 0.329
[ 405.771] (II) modeset(0): Supported established timings:
[ 405.771] (II) modeset(0): 720x400@70Hz
[ 405.771] (II) modeset(0): 640x480@60Hz
[ 405.771] (II) modeset(0): 640x480@67Hz
[ 405.771] (II) modeset(0): 640x480@72Hz
[ 405.771] (II) modeset(0): 640x480@75Hz
[ 405.771] (II) modeset(0): 800x600@56Hz
[ 405.771] (II) modeset(0): 800x600@60Hz
[ 405.773] (II) modeset(0): 800x600@72Hz
[ 405.773] (II) modeset(0): 800x600@75Hz
[ 405.773] (II) modeset(0): 832x624@75Hz
[ 405.773] (II) modeset(0): 1024x768@60Hz
[ 405.773] (II) modeset(0): 1024x768@70Hz
[ 405.773] (II) modeset(0): 1024x768@75Hz
[ 405.773] (II) modeset(0): 1280x1024@75Hz
[ 405.773] (II) modeset(0): 1152x864@75Hz
[ 405.773] (II) modeset(0): Manufacturer's mask: 0
[ 405.773] (II) modeset(0): Supported standard timings:
[ 405.773] (II) modeset(0): #0: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 405.773] (II) modeset(0): #1: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 405.774] (II) modeset(0): #2: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 405.774] (II) modeset(0): #3: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 405.774] (II) modeset(0): #6: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 405.774] (II) modeset(0): Supported detailed timing:
[ 405.774] (II) modeset(0): clock: 148.5 MHz Image Size: 476 x 268 mm
[ 405.774] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 405.774] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 405.774] (II) modeset(0): Ranges: V min: 56 V max: 76 Hz, H min: 30 H max: 82 kHz, PixClock max 165 MHz
[ 405.774] (II) modeset(0): Serial No: LF5080024201
[ 405.774] (II) modeset(0): Monitor name: Acer H213H
[ 405.774] (II) modeset(0): clock: 27.0 MHz Image Size: 476 x 268 mm
[ 405.774] (II) modeset(0): h_active: 720 h_sync: 736 h_sync_end 798 h_blank_end 858 h_border: 0
[ 405.775] (II) modeset(0): v_active: 480 v_sync: 489 v_sync_end 495 v_blanking: 525 v_border: 0
[ 405.775] (II) modeset(0): Supported detailed timing:
[ 405.775] (II) modeset(0): clock: 74.2 MHz Image Size: 476 x 268 mm
[ 405.775] (II) modeset(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
[ 405.775] (II) modeset(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[ 405.775] (II) modeset(0): h_active: 1280 h_sync: 1720 h_sync_end 1760 h_blank_end 1980 h_border: 0
[ 405.775] (II) modeset(0): clock: 27.0 MHz Image Size: 476 x 268 mm
[ 405.775] (II) modeset(0): h_active: 720 h_sync: 732 h_sync_end 796 h_blank_end 864 h_border: 0
[ 405.775] (II) modeset(0): v_active: 576 v_sync: 581 v_sync_end 586 v_blanking: 625 v_border: 0
[ 405.775] (II) modeset(0): Number of EDID sections to follow: 1
[ 405.775] (II) modeset(0): EDID (in hex):
[ 405.775] (II) modeset(0): 00ffffffffffff0004728200b2dc8191
[ 405.775] (II) modeset(0): 1213010380301b782ec585a459499a24
[ 405.775] (II) modeset(0): 125054bfef8081c08140714f81800101
[ 405.775] (II) modeset(0): 010181000101023a801871382d40582c
[ 405.776] (II) modeset(0): 4500dc0c1100001e000000fd00384c1e
[ 405.776] (II) modeset(0): 5210000a202020202020000000ff004c
[ 405.776] (II) modeset(0): 46353038303032343230310a000000fc
[ 405.776] (II) modeset(0): 00416365722048323133480a2020012a
[ 405.776] (II) modeset(0): 02031ef24b050403011213142122101f
[ 405.776] (II) modeset(0): 230907078301000065030c0010008c0a
[ 405.776] (II) modeset(0): d08a20e02d10103e9600dc0c11000018
[ 405.776] (II) modeset(0): 011d007251d01e206e285500dc0c1100
[ 405.776] (II) modeset(0): 001e011d00bc52d01e20b8285540dc0c
[ 405.776] (II) modeset(0): 1100001e8c0ad090204031200c405500
[ 405.776] (II) modeset(0): dc0c1100001800000000000000000000
[ 405.776] (II) modeset(0): 00000000000000000000000000000074
[ 405.777] (II) modeset(0): Printing probed modes for output HDMI-1
[ 405.777] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 405.777] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 405.777] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 405.777] (II) modeset(0): Modeline "1920x1080i"x60.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 405.777] (II) modeset(0): Modeline "1920x1080i"x50.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 405.777] (II) modeset(0): Modeline "1920x1080"x30.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[ 405.778] (II) modeset(0): Modeline "1920x1080"x25.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[ 405.778] (II) modeset(0): Modeline "1920x1080i"x59.9 74.18 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[ 405.778] (II) modeset(0): Modeline "1920x1080"x30.0 74.18 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.7 kHz e)
[ 405.778] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 405.778] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 405.778] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 405.778] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 405.778] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 405.778] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 405.778] (II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 405.778] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 405.778] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 405.778] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 405.778] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 405.778] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 405.778] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 405.778] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 405.778] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 405.779] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 405.779] (II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 405.779] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 405.779] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 405.779] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 405.779] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 405.779] (II) modeset(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 405.779] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 405.779] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 405.779] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 405.779] (II) modeset(0): Output HDMI-1 connected
[ 405.779] (II) modeset(0): Using exact sizes for initial modes
[ 405.779] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +0+0
[ 405.779] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 405.779] (==) modeset(0): DPI set to (96, 96)
[ 405.779] (II) Loading sub module "fb"
[ 405.780] (II) LoadModule: "fb"
[ 405.780] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 405.781] (II) Module fb: vendor="X.Org Foundation"
[ 405.781] compiled for 1.19.6, module version = 1.0.0
[ 405.781] ABI class: X.Org ANSI C Emulation, version 0.4
[ 405.781] (==) Depth 24 pixmap format is 32 bpp
[ 405.793] (==) modeset(0): Backing store enabled
[ 405.794] (==) modeset(0): Silken mouse enabled
[ 405.794] (II) modeset(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 405.795] (==) modeset(0): DPMS enabled
[ 405.795] (WW) modeset(0): Option "fbdev" is not used
[ 405.795] (WW) modeset(0): Option "SwapbuffersWait" is not used
[ 405.795] (--) RandR disabled
[ 405.811] (II) SELinux: Disabled on system
[ 405.813] (II) AIGLX: Screen 0 is not DRI2 capable
[ 405.813] (EE) AIGLX: reverting to software rendering
[ 405.820] (II) IGLX: enabled GLX_MESA_copy_sub_buffer
[ 405.824] (II) IGLX: Loaded and initialized swrast
[ 405.824] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 405.826] (II) modeset(0): Damage tracking initialized
[ 405.826] (II) modeset(0): Setting screen physical size to 508 x 285
[ 405.970] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/event1)
[ 405.971] (**) ADS7846 Touchscreen: Applying InputClass "evdev touchscreen catchall"
[ 405.971] (**) ADS7846 Touchscreen: Applying InputClass "libinput touchscreen catchall"
[ 405.971] (**) ADS7846 Touchscreen: Applying InputClass "calibration"
[ 405.971] (II) LoadModule: "evdev"
[ 405.971] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 405.972] (II) Module evdev: vendor="X.Org Foundation"
[ 405.973] compiled for 1.20.1, module version = 2.10.6
[ 405.973] Module class: X.Org XInput Driver
[ 405.973] ABI class: X.Org XInput driver, version 24.1
[ 405.973] (II) Using input driver 'evdev' for 'ADS7846 Touchscreen'
[ 405.987] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 19 paused 0
[ 405.987] (**) ADS7846 Touchscreen: always reports core events
[ 405.987] (**) evdev: ADS7846 Touchscreen: Device: "/dev/input/event1"
[ 405.989] (--) evdev: ADS7846 Touchscreen: Vendor 0 Product 0
[ 405.989] (--) evdev: ADS7846 Touchscreen: Found absolute axes
[ 405.989] (--) evdev: ADS7846 Touchscreen: Found x and y absolute axes
[ 405.989] (--) evdev: ADS7846 Touchscreen: Found absolute touchscreen
[ 405.989] (**) Option "SwapAxes" "1"
[ 405.989] (II) evdev: ADS7846 Touchscreen: Configuring as touchscreen
[ 405.990] (**) Option "EmulateThirdButton" "1"
[ 405.990] (**) Option "EmulateThirdButtonTimeout" "1000"
[ 405.990] (**) Option "EmulateThirdButtonMoveThreshold" "300"
[ 405.990] (**) evdev: ADS7846 Touchscreen: YAxisMapping: buttons 4 and 5
[ 405.990] (**) evdev: ADS7846 Touchscreen: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 405.990] (**) Option "config_info" "udev:/sys/devices/platform/ff1d0000.spi/spi_master/spi32766/spi32766.1/input/input1/event1"
[ 405.991] (II) XINPUT: Adding extended input device "ADS7846 Touchscreen" (type: TOUCHSCREEN, id 6)
[ 405.991] (II) evdev: ADS7846 Touchscreen: initialized for absolute axes.
[ 405.993] (**) ADS7846 Touchscreen: (accel) keeping acceleration scheme 1
[ 405.994] (**) ADS7846 Touchscreen: (accel) acceleration profile 0
[ 405.994] (**) ADS7846 Touchscreen: (accel) acceleration factor: 2.000
[ 405.994] (**) ADS7846 Touchscreen: (accel) acceleration threshold: 4
[... removed lines about keyboard and mouse ...]
[ 406.097] (**) Option "config_info" "udev:/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.9.auto/usb5/5-1/5-1.4/5-1.4:1.2/0003:046D:C52B.000B/0003:046D:406F.000D/input/input4/event4"
[ 406.097] (II) XINPUT: Adding extended input device "Logitech MX Ergo" (type: KEYBOARD, id 12)
[ 406.097] (**) Option "xkb_rules" "evdev"
[ 406.097] (**) Option "xkb_model" "pc105"
[ 406.097] (**) Option "xkb_layout" "us"
[ 406.097] (II) evdev: Logitech MX Ergo: initialized for relative axes.
[ 406.098] (WW) evdev: Logitech MX Ergo: ignoring absolute axes.
[ 406.098] (**) Logitech MX Ergo: (accel) keeping acceleration scheme 1
[ 406.098] (**) Logitech MX Ergo: (accel) acceleration profile 0
[ 406.099] (**) Logitech MX Ergo: (accel) acceleration factor: 2.000
[ 406.099] (**) Logitech MX Ergo: (accel) acceleration threshold: 4
[ 406.263] (II) modeset(0): Disabling kernel dirty updates, not required.
[ 406.491] (II) evdev: Logitech MX Ergo: Close
[ 406.491] (II) UnloadModule: "evdev"
[ 406.491] (II) systemd-logind: releasing fd for 13:68
[ 406.512] (II) evdev: Logitech K400 Plus: Close
[ 406.512] (II) UnloadModule: "evdev"
[ 406.512] (II) systemd-logind: releasing fd for 13:67
[ 406.536] (II) evdev: Microsoft Natural® Ergonomic Keyboard 4000: Close
[ 406.536] (II) UnloadModule: "evdev"
[ 406.536] (II) systemd-logind: releasing fd for 13:70
[ 406.556] (II) evdev: Microsoft Natural® Ergonomic Keyboard 4000: Close
[ 406.556] (II) UnloadModule: "evdev"
[ 406.557] (II) systemd-logind: releasing fd for 13:69
[ 406.580] (II) evdev: Logitech M570: Close
[ 406.580] (II) UnloadModule: "evdev"
[ 406.580] (II) systemd-logind: releasing fd for 13:66
[ 406.612] (II) evdev: Logitech M570: Close
[ 406.612] (II) UnloadModule: "evdev"
[ 406.612] (II) systemd-logind: releasing fd for 13:64
[ 406.640] (II) evdev: ADS7846 Touchscreen: Close
[ 406.640] (II) UnloadModule: "evdev"
[ 406.641] (II) systemd-logind: releasing fd for 13:65
[ 406.822] (II) Server terminated successfully (0). Closing log file.
