Can't get panfork to work on Debian
Hi there. I can’t get the panfork mesa to work on clean Debian rootfs with radxa’s kernel, bootloader and updated mali firmware. The ubuntu image with panfork ppa does work however, so that’s not a hardware issue. I’ve tried both radxa’s xorg, upstream xorg without luck. In case of armbian, I see [ 76.648365] mali fb000000.gpu: Loading Mali firmware 0x1010000 in dmesg, but with debian - not. I pass the LD_LIBRARY_PATH to my panfork installation dir, still, llvmpipe is used. Did anyone encounter similar problem on Debian image? I’m attaching dmesg outputs from both systems, timestamps stripped, but I did not spot any oddities with vimdiff:
Debian, mali not working
https://termbin.com/7h2s2
Kinetic, working
https://termbin.com/8lqys
