I have tried multiple SD cards and images, and all get similar or worse results. This is the closest I’ve gotten to a boot. I’ve tried the discord but they’re useless.
DDR Version V1.08 20220617
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
Manufacturer ID:0xff
CH0 RX Vref:29.7%, TX Vref:22.8%,22.8%
CH1 RX Vref:28.7%, TX Vref:21.8%,21.8%
CH2 RX Vref:28.7%, TX Vref:22.8%,22.8%
CH3 RX Vref:27.7%, TX Vref:20.8%,20.8%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-557-g9609b9c19:derrick.huang
NOTICE: BL31: Built : 14:29:57, Mar 8 2023
INFO: spec: 0x1
INFO: ext 32k is not valid
INFO: ddr: stride-en 4CH
INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
INFO: system boots from cpu-hwid-0
INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: BL31: Initialising Exception Handling Framework
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMCs destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 [ 7.729178] fiq_debugger fiq_debugger.0: IRQ fiq not found [ 7.729191] fiq_debugger fiq_debugger.0: IRQ wakeup not found [ 7.729199] fiq_debugger_probe: could not install nmi irq handler [ 8.464915] mpp-iep2 fdbb0000.iep: allocate roi buffer failed [ 8.466092] rk-pcie fe170000.pcie: IRQ msi not found [ 8.466130] rk-pcie fe170000.pcie: Missing *config* reg space [ 8.466259] rk-pcie fe170000.pcie: Missing *config* reg space [ 8.466300] rk-pcie fe170000.pcie: invalid resource [ 8.466470] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found! [ 8.466480] rkvdec2_init:1008: No niu aclk reset resource define [ 8.466486] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found! [ 8.466491] rkvdec2_init:1011: No niu hclk reset resource define [ 8.467121] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found! [ 8.467129] rkvdec2_init:1008: No niu aclk reset resource define [ 8.467135] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found! [ 8.467140] rkvdec2_init:1011: No niu hclk reset resource define [ 8.476969] rk-pcie fe150000.pcie: IRQ msi not found [ 8.477008] rk-pcie fe150000.pcie: Missing *config* reg space [ 8.477167] rk-pcie fe150000.pcie: Missing *config* reg space [ 8.477214] rk-pcie fe150000.pcie: invalid resource [ 8.531528] rk806 spi2.0: no sleep-setting state [ 8.531545] rk806 spi2.0: no reset-setting pinctrl state [ 8.531552] rk806 spi2.0: no dvs-setting pinctrl state [ 8.819503] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active. [ 8.831409] rksfc_base v1.1 2016-01-08 [ 8.879758] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate [ 8.879793] rockchip-dmc dmc: failed to get vop pn to msch rl [ 8.882942] rockchip-dmc dmc: could not find power_model node [ 8.890755] rk-pcie fe190000.pcie: IRQ msi not found [ 8.890817] rk-pcie fe190000.pcie: Missing *config* reg space [ 8.891083] rk-pcie fe190000.pcie: Missing *config* reg space [ 8.891221] rk-pcie fe190000.pcie: invalid resource [ 8.894864] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff] [ 8.894920] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff] [ 8.894959] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff] [ 8.900349] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 8.926581] RKNPU fdab0000.npu: failed to find power_model node [ 8.926597] RKNPU fdab0000.npu: RKNPU: failed to initialize power model [ 8.926609] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient DDR Version V1.08 20220617 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB Manufacturer ID:0xff CH0 RX Vref:29.7%, TX Vref:21.8%,22.8% CH1 RX Vref:28.7%, TX Vref:21.8%,22.8% CH2 RX Vref:28.7%, TX Vref:22.8%,22.8% CH3 RX Vref:27.7%, TX Vref:20.8%,20.8% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-557-g9609b9c19:derrick.huang NOTICE: BL31: Built : 14:29:57, Mar 8 2023 INFO: spec: 0x1 INFO: ext 32k is not valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: system boots from cpu-hwid-0 INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMCs destined for OPTEE will return SMC_UNK
INFO: SPSR = 0x3c9
[ 7.734215] fiq_debugger fiq_debugger.0: IRQ fiq not found
[ 7.734229] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[ 7.734237] fiq_debugger_probe: could not install nmi irq handler
[ 8.475260] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
[ 8.475762] rk-pcie fe170000.pcie: IRQ msi not found
[ 8.475788] rk-pcie fe170000.pcie: Missing config reg space
[ 8.475914] rk-pcie fe170000.pcie: Missing config reg space
[ 8.475962] rk-pcie fe170000.pcie: invalid resource
[ 8.476959] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
[ 8.476968] rkvdec2_init:1008: No niu aclk reset resource define
[ 8.476975] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
[ 8.476980] rkvdec2_init:1011: No niu hclk reset resource define
[ 8.477610] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
[ 8.477618] rkvdec2_init:1008: No niu aclk reset resource define
[ 8.477624] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
[ 8.477629] rkvdec2_init:1011: No niu hclk reset resource define
[ 8.486626] rk-pcie fe150000.pcie: IRQ msi not found
[ 8.486665] rk-pcie fe150000.pcie: Missing config reg space
[ 8.486853] rk-pcie fe150000.pcie: Missing config reg space
[ 8.486904] rk-pcie fe150000.pcie: invalid resource
[ 8.543075] rk806 spi2.0: no sleep-setting state
[ 8.543092] rk806 spi2.0: no reset-setting pinctrl state
[ 8.543099] rk806 spi2.0: no dvs-setting pinctrl state
[ 8.863249] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[ 8.870875] rksfc_base v1.1 2016-01-08
[ 8.928276] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 8.928325] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 8.929349] rockchip-dmc dmc: could not find power_model node
[ 8.935079] rk-pcie fe190000.pcie: IRQ msi not found
[ 8.935127] rk-pcie fe190000.pcie: Missing config reg space
[ 8.935337] rk-pcie fe190000.pcie: Missing config reg space
[ 8.935418] rk-pcie fe190000.pcie: invalid resource
[ 8.941236] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdab0000-0xfdabffff]
[ 8.941307] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdac0000-0xfdacffff]
[ 8.941364] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdad0000-0xfdadffff]
[ 8.951107] debugfs: Directory ‘fdab0000.npu-rknpu’ with parent ‘vdd_npu_s0’ already present!
[ 8.982472] RKNPU fdab0000.npu: failed to find power_model node
[ 8.982492] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
[ 8.982503] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
This loops indefinitely. (for easier reading paste into text editor the website formats it weird)
