I am currently using Yocto (v3.0.4) to build an image for RK3328-based custom board, and I have generated a GPT image (gpt.img) that is 6.2 GB in size. However, when I try to flash this image using RK Burning Tool (v1.72.9), the tool does not recognize it while other Android and Linux (.img) images get recognized.
I am using this YOCTO setup (ZEUS) for Rock PI E and building radxa-desktop-image.
Any idea what might be the problem over here?? Any help or suggestion is appreciated.
I tried using the RKDevTool v2.86 along with the rk3328_loader_ddr333_v1.16.250.bin loader file, but unfortunately, I encountered the same issue: “Download image failed”, please find below screenshot.
You can burn the image to SD card first, then when the system is up, use the dd command to empty the emmc:
dd if=/dev/zero of=/dev/mmcblk0 bs=4M count=100
I want to flash the image directly to the eMMC without using an SD card.
I apologise for the earlier mistake regarding tools version. Now I have used RKDevTool v2.86. I am able to flash the image successfully but requires to flash the image twice using tool.
On first attempt of flashing only the U-Boot loads, and doesn’t starts the kernel, below logs are attached for you reference. first_attempt.zip (1.7 KB)
However, when I flash the same image again, the board boots correctly. second_attempt.zip (12.3 KB)
Could you please provide any insights on why I need to flash the image twice to work properly?
