I am trying to move from raspberry 3B + SPI HAT to rock 3C + SPI HAT.
My HAT uses what is know as SPI0 on a raspberry board, on pins 19, 21 & 23.
It looks like it’s called SPI1 on a rock3 board, on the same pins.
I have spent countless hours trying to understand how to activate SPI, with no luck.
I have read instructions telling to configure with /boot/uEnv.txt, which is marked obsolote.
I can find overlays in /boot/dtbo and also in /usr/lib/linux-image-4.19.193-4-rk356x (which is the path specified in /boot/extlinux/extlinux.conf).
My software is expecting to find /dev/spidev0.0. I tried to load several (spidev) overlays and never got the expected device.
The signal output to ‘Pins 19, 21, 23, 24’ is the signal from ‘SPI3’.
The ‘SPI0 (/dev/spidev0.0)’ you want is in use for other purposes and cannot be assigned to other purposes by the user.
So you need to substitute with ‘SPI3’.
root@rock-3c:~# uname -a
Linux rock-3c 4.19.193-4-rk356x #24c58c676 SMP Mon Apr 24 03:29:51 UTC 2023 aarch64 GNU/Linux
root@rock-3c:~# ls -la /dev/spi*
crw------- 1 root root 153, 0 May 19 00:12 /dev/spidev3.0
