So I got a Zero for a project, shelved the project, but I have a new project that the Zero (with it’s USB 3, yay!) should be great for. However, I’m trying to convert it over to boot from mSD card, and so trying to flash the radxa-zero-erase-emmc.bin from https://wiki.radxa.com/Zero/dev/maskrom to clear the eMMC, which I believe will then make the currently installed uBoot simply boot from the mSD card.
However, I get this stack trace when I run boot-g12.py
File "/root/./.local/bin/boot-g12.py", line 23, in <module>
socid = dev.identify()
File "/root/.local/share/pipx/venvs/pyamlboot/lib/python3.11/site-packages/pyamlboot/pyamlboot.py", line 304, in identify
ret = self.dev.ctrl_transfer(bmRequestType = 0xc0,
File "/root/.local/share/pipx/venvs/pyamlboot/lib/python3.11/site-packages/usb/core.py", line 1082, in ctrl_transfer
ret = self._ctx.backend.ctrl_transfer(
File "/root/.local/share/pipx/venvs/pyamlboot/lib/python3.11/site-packages/usb/backend/libusb1.py", line 893, in ctrl_transfer
ret = _check(self.lib.libusb_control_transfer(
File "/root/.local/share/pipx/venvs/pyamlboot/lib/python3.11/site-packages/usb/backend/libusb1.py", line 602, in _check
raise USBTimeoutError(_strerror(ret), ret, _libusb_errno[ret])
usb.core.USBTimeoutError: [Errno 110] Operation timed out
I’m running Debian Testing, and installed pyamlboot through pipx. At a guess, seems it can’t detect the board, but I see Bus 003 Device 015: ID 1b8e:c003 Amlogic, Inc. GX-CHIP from lsusb, and I get this in dmesg when I push the boot button and plug it in.
[484411.989264] usb 3-4.4.3: New USB device found, idVendor=1b8e, idProduct=c003, bcdDevice= 0.20
[484411.989273] usb 3-4.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[484411.989277] usb 3-4.4.3: Product: GX-CHIP
[484411.989281] usb 3-4.4.3: Manufacturer: Amlogic
