Cant boot DietPI from emmc
Hi All,
I am new to the forum and this is my first post!
I am having trouble getting my Radxa Zero to boot DietPI from EMMC. It will boot fine from SD, I have tried various guides from the Radxa wiki with no luck.
Below i have detailed the commands from my most recent attempt all of which complete successfully, any help would be greatly appreciated.
Note: I also attempted the winwoze approach with balena etcher and RZ_USB_Boot_Helper_V1.0.0 ETC.
Thanks,
Adrian
wget https://dl.radxa.com/zero/images/loader/radxa-zero-erase-emmc.bin
wget https://chewitt.libreelec.tv/testing/u-boot/u-boot.bin.sd.bin-radxa-zero
wget https://dietpi.com/downloads/images/DietPi_RadxaZero-ARMv8-Bullseye.7z
7z -x DietPi_RadxaZero-ARMv8-Bullseye.7z
insert usb and hold boot button
sudo boot-g12.py radxa-zero-erase-emmc.bin
sudo dd if=DietPi_RadxaZero-ARMv8-Bullseye.img of=/dev/sdb
sudo dd if=u-boot.bin.sd.bin-radxa-zero of=/dev/sdb conv=fsync,notrunc bs=1 count=444
sudo dd if=u-boot.bin.sd.bin-radxa-zero of=/dev/sdb conv=fsync,notrunc bs=512 seek=1
remove usb then plg rz into monitor keyboard and power. No Boot!
i get the following in serial console which i believe is from u-boot. looking at the message EMMC:0 I would say there doesn’t appear to be a boot image for emmc ? I have no experience of u-boot so not really sure what i’m looking at or how to resolve the issue.
Any help much appreciated. Thanks in advance.
G12A:BL:0253b8:61aa2d;FEAT:E0F83180:2000;POC:F;RCY:0;EMMC:0;READ:0;CHK:1F;READ:0;CHK:1F;READ:0;CHK:1F;SD?:20000;USB:8;
LOOP:1;EMMC:0;READ:0;CHK:1F;READ:0;CHK:1F;READ:0;CHK:1F;SD?:20000;USB:8;
LOOP:2;EMMC:0;READ:0;CHK:1F;READ:0;CHK:1F;READ:0;CHK:1F;SD?:20000;USB:8;
LOOP:3;EMMC:0;READ:0;CHK:1F;READ:0;CHK:1F;READ:0;CHK:1F;SD?:20000;USB:8;
LOOP:4;EMMC:0;READ:0;CHK:1F;READ:0;CHK:1F;READ:0;CHK:1F;SD?:20000;USB:8;
Does DietPi not have a u-boot binary baked in? For most OS images you only have to flash the one image and you should be good to go.
EDIT: Also, your last dd command is missing the of= parameter.
Thanks for the reply, i just forgot to detail the “of=/dev/sdb conv=fsync,notrunc”. i have updated initial post.
My first attempt was to just flash the DietPi image with balena. this did not work.
I have included a full extract of the serial console on boot attempt below and above that a snippet which i believe may relate to the issue, I am using a fairly beefy usb phone charger so don’t think the issue would be power related.
unable to select a mode : -5
starting USB...
G12A:BL:0253b8:61aa2d;FEAT:E0F83180:2000;POC:F;RCY:0;EMMC:0;READ:0;0.0
        l2_stage_i        nit 0x01
bl2_stage_init 0x81
hw id: 0x0001 - pwm id 0x00
bl2_stage_init 0xc0
bl2_stage_init 0x02
L0:00000000
L1:00000703
L2:00008067
L3:04000000
S1:00000000
B2:00002000
B1:e0f83180
TE: 194140
Board ID = 2
Set cpu clk to 24M
Set clk81 to 24M
CPU clk: 1200 MHz
Set clk81 to 166.6M
eMMC boot @ 0
sw8 s
board id: 2
Load FIP HDR from eMMC, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part        : 0
fw parse done
Load ddrfw from eMMC, src: 0x00060200, des: 0xfffd0000, size: 0x0000c000, part:        0
Load ddrfw from eMMC, src: 0x00038200, des: 0xfffd0000, size: 0x00004000, part:        0
PIEI prepare done
fastboot data load
00000000
emmc switch 1 ok
00000000
emmc switch 2 ok
fastboot data verify
verify result: 265
LPDDR4 probe
ddr clk to 792MHz
Load ddrfw from eMMC, src: 0x0003c200, des: 0xfffd0000, size: 0x0000c000, part:        0
00000000
emmc switch 0 ok
dmc_version 0000
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 792MHz
dmc_version 0000
Check phy result
INFO : End of CA training
INFO : End of initialization
Check phy result
Check phy result
1D training succeed
Load ddrfw from eMMC, src: 0x00048200, des: 0xfffd0000, size: 0x0000c000, part:        0
Check phy result
channel==0
RxClkDly_Margin_A0==256 ps 13
TxDqDly_Margin_A0==256 ps 13
RxClkDly_Margin_A1==0 ps 0
TxDqDly_Margin_A1==0 ps 0
TrainedVREFDQ_A0==74
TrainedVREFDQ_A1==0
VrefDac_Margin_A0==31
DeviceVref_Margin_A0==39
VrefDac_Margin_A1==0
DeviceVref_Margin_A1==0
channel==1
RxClkDly_Margin_A0==236 ps 12
TrainedVREFDQ_A0==75
TrainedVREFDQ_A1==0
soc_vref_reg_value 0x 0000001b 0000001d 00000019 0000001b 0000001a 0000001c 0000        001b 0000001b 0000001d 0000001d 0000001c 0000001c 0000001e 0000001d 0000001c 000        0001e 0000001d 0000001d 0000001b 0000001c 0000001f 0000001e 0000001b 0000001c 00        00001b 0000001a 0000001c 0000001c 0000001a 0000001b 0000001a 0000001a dram_vref_        reg_value 0x 00000058
2D training succeed
auto size-- 65535DDR cs0 size: 2048MB
DDR cs1 size: 0MB
DMC_DDR_CTRL: 00c0002cDDR size: 2048MB
cs0 DataBus test pass
cs0 AddrBus test pass
100bdlr_step_size ps== 454
result report
00000000
emmc switch 3 ok
Authentication key not yet programmed
get rpmb counter error 0x00000007
00000000
emmc switch 0 ok
Load FIP HDR from eMMC, src: 0x00010200, des: 0x01700000, size: 0x00004000, part        : 0
Load BL3X from eMMC, src: 0x0006c200, des: 0x0175c000, size: 0x00098000, part: 0
0.0;M3 CHK:0;cm4_sp_mode 0
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x30
ring efuse init
28 0c 30 00 01 17 2f 00 00 15 35 36 32 43 46 50
[0.017149 Inits done]
secure task start!
high task start!
low task start!
run into bl31
NOTICE:  BL31: v1.3(release):4fc40b1
NOTICE:  BL31: Built : 15:57:33, May 22 2019
NOTICE:  BL31: G12A normal boot!
NOTICE:  BL31: BL33 decompress pass
U-Boot 2022.01-armbian (Jun 22 2022 - 07:17:10 +0000) radxa-zero
Model: Radxa Zero
SoC:   Amlogic Meson G12A (S905Y2) Revision 28:c (30:2)
DRAM:  2 GiB
MMC:   sd@ffe03000: 0, sd@ffe05000: 1, mmc@ffe07000: 2
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
starting USB...
Starting the controller
USB XHCI 1.10
scanning bus usb@ff500000 for devices... 1 USB Device(s) found
Device 0: unknown device
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-meson-u200
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
Try wiping and flashing the DietPi image by itself again, and if you get that same boot error, try power cycling until it boots. There was a bug in U-Boot that caused that error sometimes. DietPi might not have the patch that fixed it.
Still nothing sadly. not sure what to do now.
I have created a thread on the DietPI Support forum, will see what comes of that. Thanks for all the help.
https://dietpi.com/forum/t/cant-boot-from-emmc-on-radxazero
How many times did you try power cycling? I’ve had to do it 10+ times in a row before. Sometimes it helps to let it sit unplugged for 15 seconds or so before trying again.
I tried a load of times before, i just gave your approach a go with no luck. I’m not really sure why it would be necessary to do this or why this would allow it to boot.
