Cannot install libmraa via radxa apt
I tried to install mraa on Rock Pi S on Ubuntu 20.04 but Radxa Apt cannot install it. Info as following:
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.3 LTS
Release: 20.04
Codename: focal
cat /etc/apt/sources.list.d/apt-radxa-com.list
deb http://apt.radxa.com/focal-stable/ focal main
deb http://apt.radxa.com/focal-testing/ focal main
sudo apt install libmraa
Reading package lists… Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
libmraa : Depends: libjson-c3 but it is not installable
E: Unable to correct problems, you have held broken packages.
apt search libjson-c3
Sorting… Done
Full Text Search… Done
I also tried to compile it using this link:https://github.com/brian541/mraa/blob/master/docs/building.md
But after compiling I got:
mraa-gpio list
No Pins
Thank you very much.
I found one github repo that works:this
