Cannot connect to LSMDSOX accelerometer
I bought an Adafruit LSM6DSOX module and I connected to my Rockpi4 board. I installed the provided libraries and tried to follow their examples. However, the
import board
command returns the following error:
NotImplementedError: board not supported None
Is there a way to fix it? Can I connect to the module in other ways?
I think Adafruit only support the Raspberry Pi. What packages have you installed? You need to replace the rpi.gpio package to the rockpi libmraa package. Or you can check if there is support in UPM.
GitHub - eclipse-upm/upm: UPM is a high level repository that provides software drivers for a wide variety of commonly used sensors and actuators. These software drivers interact with the underlying hardware platform through calls to MRAA APIs.
