Cannot Boot Radxa E23
I tryed all the avable images from here https://github.com/radxa/debos-radxa/releases/tag/main-abfcbf78 for the e23 board but the board doesnt boot, every time it panics, shows this message on the serial output and reboots.
. What can be the causes and how can i fix them?
PARTUUID is not correct.
Check if that error is true, if it is true then save the correct partuuid in boot script file.
Hopefully it should work.
If it is correct and still not working then the kernel is missing needed drivers.
Thanks for the answer, but can you point out where the boot file is located more exactly ? Thanks
@RadxaYuntian
Is the right person to answer that question.
The root filesystem is not found. The cause may be the system image is corrupted when flashing. Or boot device is broken.
What is your boot device? eMMC or SD card?
If it is SD card, try:
  • Flash system image again with etcher tool
  • Use a new SD card
By the way, please show all the boot log from serial tool.
To boot , i tryed using 2 different sd cards, and for flashing i used balena etcher.
Here is the log: https://pastebin.com/4ED4shJd
Today we reproduce your issue.
The problem is caused by Radxa E23 Ubuntu/Debian system images.
We’ll release new system images to fix that.
When is the expected date for the fix release?
@Florin_Baciu Good news. We released new Radxa E23 Ubuntu/Debian images to fix this issue.
Please download images from https://github.com/radxa/debos-radxa/releases/tag/main-723e7c25
